Version 7.6.2 released
General:
This fixes broken browsing on some devices.
Soon we will be start our 8.0.0 pre-release cycle, which usually involves releasing alpha/beta versions so we can get feedback on the new features and any bugs before the full release.
This one will be centered around web feeds like podcasts and web streaming.
We will continue to release 7.x.x builds in parallel with bugfixes and minor updates, so please continue to report any bugs you find. We are really focusing on stability lately and will continue to.
Changes since 7.6.1:
  • General:
    • Fixed broken browsing on some devices
Compatibility notes:
a15995
Re: Version 7.6.2 released
Post by a15995 »
Haven't worked on my system since 7.5.0. Does not launch, have tried 7.6.0 and 7.6.2. Have also reinstalled Java to no avail. Back on 7.5.0 and working.
My system is Win7x64, Java 8 (update 191) - further below.
/Søren
squadjot
Post by squadjot »
a15995 wrote: Thu Nov 22, 2018 9:10 pm Haven't worked on my system since 7.5.0. Does not launch, have tried 7.6.0 and 7.6.2. Have also reinstalled Java to no avail. Back on 7.5.0 and working.
A wild shot... have you tried opening the application with "run as administrator" enabled?
a15995
Post by a15995 »
squadjot wrote: Fri Nov 23, 2018 3:21 am
Yes I have. No success.
This happened with a previous version as well but was corrected shortly after with a minor release.
But still strange that 7.5.0 is working...
/Søren
Which operating system is that on?
erick diangilis
Post by erick diangilis »
hi subjunk i had no trouble with the 7.6.0 but but i will test this to help anyway i aprecciate the update. :D
i hope you can help people that are having issues with the lastest versions.
thanks and keep up with the good work.
a15995
Post by a15995 »
SubJunk wrote: Fri Nov 23, 2018 9:28 am Which operating system is that on?
Win7x64.
Thanks for your great work by the way.
/Søren
tedel2000
Post by tedel2000 »
hello,
UMS is not playing video_ts files on any device after 7.4.0.7.4.0 works fine and after that its not working for me anymore?
greetings tedel2000
tedel2000
Post by tedel2000 »
I have another question on my Mac I have never could play video_ts folders but on my windows machine I can except after 7.4.0 I also can't stream video_ts files.
So I am using 7.4.0 on my windows but its a shame the updates won't work for me!
Greetings tedel2000
tedel2000
Post by tedel2000 »
The last question if I stream the video-ts files is a little bit lacking how can I fix that? I have fast internet!
