[Solved] Ums after 10.8.2 doesn't display in renderer
Hi, just tried updating to 10.10 and UMS wont show itself to renderer
There are multiple instances of below error
Exception in thread "HTTPv1 Request Worker 7" java.lang.NullPointerException
13:01:48 INFO at net.pms.network.RequestHandler.run(RequestHandler.java:109)
13:01:48 INFO at java.lang.Thread.run(Thread.java:748)
This is on Linux (Fedora 34)
Same issue with 10.9, 10.8.2 works fine
Weirdly the web frontend works
Re: Ums after 10.8.2 doesn't display in renderer - Update
Checking the http v2 option makes things work again.
Has http v1 been disabled?
Hi redtux, thanks for posting. We are currently working on this at https://github.com/UniversalMediaServer ... /pull/2613
Please let us know if this build fixes it https://www.universalmediaserver.com/up ... x86_64.tgz
Seems to have fixed the issue
Re: [Solved] Ums after 10.8.2 doesn't display in renderer
Thanks for confirming, I will do a release later today
