Sony KDL-EX725 doesn't see UMS
Re: Sony KDL-EX725 doesn't see UMS
Do you mean the latest version (UMS 1.0.1) is working fine without PMSEncoder, or the test version I gave?
Also, are you using the latest PMSEncoder, version 1.6? Older versions can cause bugs like this.
eva01
Post by eva01 »
The version 1.0.1 isn't working. The test version after i install the plugin works only in the first run, if i close the application y then i open again, dont. The version of the plugin is 1.6
Clarification: On the first run, UMS test see the tv, but the tv dont see UMS. PMS 1.52 SB71 is working fine with the plugin
OK I've made a few changes, not sure if they will fix this bug but we can hope link
eva01
Post by eva01 »
I test the new version of the test file. Im attaching 1 file with the results so you can examine them.
The tv does not appear
The debug:
DEBUG 2012-06-08 13:51:28.441 [main] Java version: 1.7.0_04
DEBUG 2012-06-08 13:51:28.441 [main] Java vendor: Oracle Corporation
DEBUG 2012-06-08 13:51:28.441 [main] Java class path: update.jar;ums.jar
DEBUG 2012-06-08 13:51:28.441 [main] Operating system name: Windows 7
DEBUG 2012-06-08 13:51:28.441 [main] Operating system architecture: x86
DEBUG 2012-06-08 13:51:28.441 [main] Operating system version: 6.1
DEBUG 2012-06-08 13:51:28.488 [main] SUN 1.7: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
DEBUG 2012-06-08 13:51:28.488 [main] SunRsaSign 1.7: Sun RSA signature provider
DEBUG 2012-06-08 13:51:28.488 [main] SunEC 1.7: Sun Elliptic Curve provider (EC, ECDSA, ECDH)
DEBUG 2012-06-08 13:51:28.488 [main] SunJSSE 1.7: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
DEBUG 2012-06-08 13:51:28.488 [main] SunJCE 1.7: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
DEBUG 2012-06-08 13:51:28.488 [main] SunJGSS 1.7: Sun (Kerberos v5, SPNEGO)
DEBUG 2012-06-08 13:51:28.488 [main] SunSASL 1.7: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5, NTLM; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5, NTLM)
DEBUG 2012-06-08 13:51:28.488 [main] XMLDSig 1.0: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
DEBUG 2012-06-08 13:51:28.488 [main] SunPCSC 1.7: Sun PC/SC provider
DEBUG 2012-06-08 13:51:28.488 [main] SunMSCAPI 1.7: Sun's Microsoft Crypto API provider
DEBUG 2012-06-08 13:51:28.488 [main] Set parameter http.useragent = Jakarta Commons-HttpClient/3.1
DEBUG 2012-06-08 13:51:28.488 [main] Set parameter http.protocol.version = HTTP/1.1
DEBUG 2012-06-08 13:51:28.488 [main] Set parameter http.connection-manager.class = class org.apache.commons.httpclient.SimpleHttpConnectionManager
DEBUG 2012-06-08 13:51:28.488 [main] Set parameter http.protocol.cookie-policy = default
DEBUG 2012-06-08 13:51:28.488 [main] Set parameter http.protocol.element-charset = US-ASCII
DEBUG 2012-06-08 13:51:28.488 [main] Set parameter http.protocol.content-charset = ISO-8859-1
DEBUG 2012-06-08 13:51:28.488 [main] Set parameter http.method.retry-handler = org.apache.commons.httpclient.DefaultHttpMethodRetryHandler@17138f4
DEBUG 2012-06-08 13:51:28.488 [main] Set parameter http.dateparser.patterns = [EEE, dd MMM yyyy HH:mm:ss zzz, EEEE, dd-MMM-yy HH:mm:ss zzz, EEE MMM d HH:mm:ss yyyy, EEE, dd-MMM-yyyy HH:mm:ss z, EEE, dd-MMM-yyyy HH-mm-ss z, EEE, dd MMM yy HH:mm:ss z, EEE dd-MMM-yyyy HH:mm:ss z, EEE dd MMM yyyy HH:mm:ss z, EEE dd-MMM-yyyy HH-mm-ss z, EEE dd-MMM-yy HH:mm:ss z, EEE dd MMM yy HH:mm:ss z, EEE,dd-MMM-yy HH:mm:ss z, EEE,dd-MMM-yyyy HH:mm:ss z, EEE, dd-MM-yyyy HH:mm:ss z]
DEBUG 2012-06-08 13:51:28.659 [pool-2-thread-1] Open connection to universal-media-server.googlecode.com:80
DEBUG 2012-06-08 13:51:28.675 [pool-2-thread-1] >> "GET /git/src/main/external-resources/update/update_3.properties?currentVersion=1.1.0&operatingSystem=windows&cacheBuster=0.6140006220945088 HTTP/1.1[\r][\n]"
DEBUG 2012-06-08 13:51:28.675 [pool-2-thread-1] Adding Host request header
DEBUG 2012-06-08 13:51:28.675 [pool-2-thread-1] >> "User-Agent: Jakarta Commons-HttpClient/3.1[\r][\n]"
DEBUG 2012-06-08 13:51:28.675 [pool-2-thread-1] >> "Host: universal-media-server.googlecode.com[\r][\n]"
DEBUG 2012-06-08 13:51:28.675 [pool-2-thread-1] >> "[\r][\n]"
INFO  2012-06-08 13:51:29.299 [main] Starting Universal Media Server 1.1.0
INFO  2012-06-08 13:51:29.314 [main] Based on PS3 Media Server (ps3mediaserver.org) by shagrath, copyright 2008-2012
INFO  2012-06-08 13:51:29.314 [main] http://www.universalmediaserver.com
INFO  2012-06-08 13:51:29.314 [main] Build: 1b1382c13 (2012-06-08)
INFO  2012-06-08 13:51:29.314 [main] Java: 1.7.0_04-Oracle Corporation
INFO  2012-06-08 13:51:29.330 [main] OS: Windows 7 x86 6.1
INFO  2012-06-08 13:51:29.330 [main] Encoding: UTF-8
INFO  2012-06-08 13:51:29.330 [main] Memory: 742 MB
INFO  2012-06-08 13:51:29.330 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-06-08 13:51:29.330 [main] Temp folder: C:\Users\NUESTR~1\AppData\Local\Temp\ps3mediaserver
INFO  2012-06-08 13:51:29.330 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2012-06-08 13:51:29.330 [main] debug.log: C:\Program Files (x86)\Universal Media Server\debug.log
INFO  2012-06-08 13:51:29.330 [main] Profile directory: C:\ProgramData\UMS
INFO  2012-06-08 13:51:29.330 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2012-06-08 13:51:29.330 [main] Profile status: rw
INFO  2012-06-08 13:51:29.330 [main] Profile name: NuestraPC-PC
INFO  2012-06-08 13:51:29.330 [main] Loading MediaInfo library
INFO  2012-06-08 13:51:29.439 [main] Loaded MediaInfoLib - v0.7.58
INFO  2012-06-08 13:51:29.439 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2012-06-08 13:51:29.439 [main] Loading configuration file: AirPlayer.conf
DEBUG 2012-06-08 13:51:29.439 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/AirPlayer.conf
INFO  2012-06-08 13:51:29.439 [main] Loading configuration file: Android.conf
DEBUG 2012-06-08 13:51:29.439 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Android.conf
INFO  2012-06-08 13:51:29.439 [main] Loading configuration file: Bravia4500.conf
DEBUG 2012-06-08 13:51:29.439 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Bravia4500.conf
INFO  2012-06-08 13:51:29.439 [main] Loading configuration file: Bravia5500.conf
DEBUG 2012-06-08 13:51:29.439 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Bravia5500.conf
INFO  2012-06-08 13:51:29.439 [main] Loading configuration file: BraviaEX.conf
DEBUG 2012-06-08 13:51:29.439 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/BraviaEX.conf
INFO  2012-06-08 13:51:29.439 [main] Loading configuration file: DLinkDSM510.conf
DEBUG 2012-06-08 13:51:29.439 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/DLinkDSM510.conf
INFO  2012-06-08 13:51:29.439 [main] Loading configuration file: FreeboxHD.conf
DEBUG 2012-06-08 13:51:29.439 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/FreeboxHD.conf
INFO  2012-06-08 13:51:29.439 [main] Loading configuration file: FreecomMusicPal.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/FreecomMusicPal.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: iPad-iPhone.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/iPad-iPhone.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: Kuro.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Kuro.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: LGST600.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/LGST600.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: N900.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/N900.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: OPPOBDP83.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/OPPOBDP83.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: OPPOBDP93.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/OPPOBDP93.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: Panasonic.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Panasonic.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: Philips.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Philips.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: PhilipsPFL.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PhilipsPFL.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: PopcornHour.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PopcornHour.conf
INFO  2012-06-08 13:51:29.455 [main] Loading configuration file: PS3.conf
DEBUG 2012-06-08 13:51:29.455 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PS3.conf
INFO  2012-06-08 13:51:29.470 [main] Loading configuration file: Realtek.conf
DEBUG 2012-06-08 13:51:29.470 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Realtek.conf
INFO  2012-06-08 13:51:29.470 [main] Loading configuration file: SamsungAllShare.conf
DEBUG 2012-06-08 13:51:29.470 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SamsungAllShare.conf
INFO  2012-06-08 13:51:29.470 [main] Loading configuration file: SamsungWiseLink.conf
DEBUG 2012-06-08 13:51:29.470 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SamsungWiseLink.conf
INFO  2012-06-08 13:51:29.470 [main] Loading configuration file: Showtime3.conf
DEBUG 2012-06-08 13:51:29.470 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Showtime3.conf
INFO  2012-06-08 13:51:29.470 [main] Loading configuration file: SonyBluray.conf
DEBUG 2012-06-08 13:51:29.470 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SonyBluray.conf
INFO  2012-06-08 13:51:29.470 [main] Loading configuration file: Streamium.conf
DEBUG 2012-06-08 13:51:29.470 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Streamium.conf
INFO  2012-06-08 13:51:29.470 [main] Loading configuration file: WDTVLive.conf
DEBUG 2012-06-08 13:51:29.470 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/WDTVLive.conf
INFO  2012-06-08 13:51:29.470 [main] Loading configuration file: WMP.conf
DEBUG 2012-06-08 13:51:29.470 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/WMP.conf
INFO  2012-06-08 13:51:29.470 [main] Loading configuration file: XBMC.conf
DEBUG 2012-06-08 13:51:29.470 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/XBMC.conf
INFO  2012-06-08 13:51:29.470 [main] Loading configuration file: Xbox360.conf
DEBUG 2012-06-08 13:51:29.470 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Xbox360.conf
INFO  2012-06-08 13:51:29.486 [main] Loading configuration file: YamahaRXV671.conf
DEBUG 2012-06-08 13:51:29.486 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/YamahaRXV671.conf
INFO  2012-06-08 13:51:29.486 [main] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-06-08 13:51:29.486 [main] launching: win32/mplayer.exe
DEBUG 2012-06-08 13:51:29.846 [main] launching: win32/mplayer.exe
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "HTTP/1.1 200 OK[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "ETag: "36393333343738666262383332316438383030356437306666336663306531343363646631626161/src/main/external-resources/update/update_3.properties"[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "Date: Fri, 08 Jun 2012 16:51:21 GMT[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "Cache-Control: public,max-age=60[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "Accept-Ranges: none[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "Content-Type: text/plain; charset=ISO-8859-1[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "X-Content-Type-Options: nosniff[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "Server: git_frontend[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "X-XSS-Protection: 1; mode=block[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "Transfer-Encoding: chunked[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "[\r][\n]"
WARN  2012-06-08 13:51:30.003 [pool-2-thread-1] Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] Buffering response body
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "6"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "f"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "[\r]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "[\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "LatestVersion="1.0.1"[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "DownloadUrl.windows="http://universal-media-server.googlecode.com/files/UMS-1.0.1.exe"[\r][\n]"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] << "0"
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] Resorting to protocol version default close connection policy
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] Should NOT close connection, using HTTP/1.1
DEBUG 2012-06-08 13:51:30.003 [pool-2-thread-1] Releasing connection back to connection manager.
INFO  2012-06-08 13:51:30.050 [main] Done!
INFO  2012-06-08 13:51:30.050 [main] Found AviSynth plugins dir: C:\Program Files (x86)\AviSynth\plugins
INFO  2012-06-08 13:51:30.050 [main] Found VideoLAN version 2.0.1 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-06-08 13:51:30.050 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2012-06-08 13:51:30.050 [main] Found plugin: com.chocolatey.pmsencoder.Plugin
INFO  2012-06-08 13:51:30.065 [main] PMSEncoder: initializing PMSEncoder 1.6.0
INFO  2012-06-08 13:51:30.096 [main] PMSEncoder: log directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-06-08 13:51:30.096 [main] PMSEncoder: loading built-in log4j config file: jar:file:/C:/Program%20Files%20(x86)/Universal%20Media%20Server/plugins/pmsencoder.jar!/log4j_default.xml
INFO  2012-06-08 13:51:31.235 [main] Registering transcoding engine: PMSEncoder
INFO  2012-06-08 13:51:31.235 [main] PMSEncoder: checking engine list: [mencoder, tsmuxer, ffmpegaudio, mplayeraudio, tsmuxeraudio, vlcvideo, mencoderwebvideo, mplayervideodump, vlcaudio, mplayerwebaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-06-08 13:51:31.235 [main] PMSEncoder: enabled engine: [pmsencoder, mencoder, tsmuxer, ffmpegaudio, mplayeraudio, tsmuxeraudio, vlcvideo, mencoderwebvideo, mplayervideodump, vlcaudio, mplayerwebaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-06-08 13:51:31.235 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2012-06-08 13:51:31.235 [main] Registering transcoding engine: FFmpeg Audio
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: MEncoder
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: AviSynth/MEncoder
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: MPlayer Audio
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: MEncoder Web
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: MPlayer Web
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: tsMuxeR
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2012-06-08 13:51:31.251 [main] Found VLC version 2.0.1 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: VLC Audio Streaming
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: VLC Video Streaming
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2012-06-08 13:51:31.251 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-06-08 13:51:31.313 [main] Using forced address 192.168.1.117
INFO  2012-06-08 13:51:31.313 [main] Created socket: /192.168.1.117:5001
INFO  2012-06-08 13:51:31.329 [HTTP Server] Starting DLNA Server on host 192.168.1.117 and port 5001...
INFO  2012-06-08 13:51:31.329 [main] Checking shared folder: E:\Musica
INFO  2012-06-08 13:51:31.329 [main] Checking shared folder: E:\Series
INFO  2012-06-08 13:51:31.329 [main] Checking shared folder: E:\Peliculas
INFO  2012-06-08 13:51:31.329 [main] Checking shared folder: D:\Peliculas 3D
INFO  2012-06-08 13:51:31.329 [main] Checking shared folder: D:\Peliculas HD
INFO  2012-06-08 13:51:31.329 [main] Checking shared folder: D:\Series HD
DEBUG 2012-06-08 13:51:31.360 [main] Sending ALIVE...
INFO  2012-06-08 13:51:31.438 [main] Using the following UUID configured in UMS.conf: c26252f3-b2f9-49eb-9aff-e430b5cc032f
INFO  2012-06-08 13:51:35.159 [main] The server should now appear on your renderer
DEBUG 2012-06-08 13:51:45.174 [UPNP-AliveMessageSender] Sending ALIVE...
print screen
print screen
eva01
Post by eva01 »
This is the debug file from PMS, the tv is here,
INFO  2012-06-08 14:07:12.457 [main] Starting PS3 Media Server 1.52.2-SB71
INFO  2012-06-08 14:07:12.457 [main] by shagrath / 2008-2012
INFO  2012-06-08 14:07:12.472 [main] http://ps3mediaserver.org
INFO  2012-06-08 14:07:12.472 [main] https://github.com/ps3mediaserver/ps3mediaserver
INFO  2012-06-08 14:07:12.472 [main] Custom build by SubJunk, http://www.spirton.com
INFO  2012-06-08 14:07:12.472 [main] Build: b4e8b14fb (2012-04-15)
INFO  2012-06-08 14:07:12.472 [main] Java: 1.7.0_04-Oracle Corporation
INFO  2012-06-08 14:07:12.472 [main] OS: Windows 7 x86 6.1
INFO  2012-06-08 14:07:12.472 [main] Encoding: UTF-8
INFO  2012-06-08 14:07:12.472 [main] Working directory: C:\Program Files (x86)\PS3 Media Server
INFO  2012-06-08 14:07:12.488 [main] Temp folder: C:\Users\NUESTR~1\AppData\Local\Temp\ps3mediaserver
INFO  2012-06-08 14:07:12.488 [main] Logging config file: C:\Program Files (x86)\PS3 Media Server\logback.xml
INFO  2012-06-08 14:07:12.488 [main] debug.log: C:\Program Files (x86)\PS3 Media Server\debug.log
INFO  2012-06-08 14:07:12.488 [main] Profile directory: C:\ProgramData\PMS
INFO  2012-06-08 14:07:12.488 [main] Profile path: C:\ProgramData\PMS\PMS.conf
INFO  2012-06-08 14:07:12.488 [main] Profile status: rw
INFO  2012-06-08 14:07:12.488 [main] Profile name: NuestraPC-PC
INFO  2012-06-08 14:07:12.488 [main] Loading MediaInfo library
INFO  2012-06-08 14:07:12.613 [main] Loaded MediaInfoLib - v0.7.56
INFO  2012-06-08 14:07:12.613 [main] Loading renderer configurations from C:\Program Files (x86)\PS3 Media Server\renderers
INFO  2012-06-08 14:07:12.613 [main] Loading configuration file: AirPlayer.conf
DEBUG 2012-06-08 14:07:12.613 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/AirPlayer.conf
INFO  2012-06-08 14:07:12.613 [main] Loading configuration file: Android.conf
DEBUG 2012-06-08 14:07:12.628 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Android.conf
INFO  2012-06-08 14:07:12.628 [main] Loading configuration file: Bravia4500.conf
DEBUG 2012-06-08 14:07:12.628 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Bravia4500.conf
INFO  2012-06-08 14:07:12.628 [main] Loading configuration file: Bravia5500.conf
DEBUG 2012-06-08 14:07:12.628 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Bravia5500.conf
INFO  2012-06-08 14:07:12.628 [main] Loading configuration file: BraviaEX.conf
DEBUG 2012-06-08 14:07:12.628 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/BraviaEX.conf
INFO  2012-06-08 14:07:12.628 [main] Loading configuration file: FreeboxHD.conf
DEBUG 2012-06-08 14:07:12.628 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/FreeboxHD.conf
INFO  2012-06-08 14:07:12.628 [main] Loading configuration file: FreecomMusicPal.conf
DEBUG 2012-06-08 14:07:12.628 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/FreecomMusicPal.conf
INFO  2012-06-08 14:07:12.628 [main] Loading configuration file: iPad-iPhone.conf
DEBUG 2012-06-08 14:07:12.628 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/iPad-iPhone.conf
INFO  2012-06-08 14:07:12.628 [main] Loading configuration file: Kuro.conf
DEBUG 2012-06-08 14:07:12.628 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Kuro.conf
INFO  2012-06-08 14:07:12.628 [main] Loading configuration file: N900.conf
DEBUG 2012-06-08 14:07:12.628 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/N900.conf
INFO  2012-06-08 14:07:12.628 [main] Loading configuration file: Panasonic.conf
DEBUG 2012-06-08 14:07:12.628 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Panasonic.conf
INFO  2012-06-08 14:07:12.628 [main] Loading configuration file: Philips.conf
DEBUG 2012-06-08 14:07:12.644 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Philips.conf
INFO  2012-06-08 14:07:12.644 [main] Loading configuration file: PhilipsPFL.conf
DEBUG 2012-06-08 14:07:12.644 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/PhilipsPFL.conf
INFO  2012-06-08 14:07:12.644 [main] Loading configuration file: PopcornHour.conf
DEBUG 2012-06-08 14:07:12.644 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/PopcornHour.conf
INFO  2012-06-08 14:07:12.644 [main] Loading configuration file: PS3.conf
DEBUG 2012-06-08 14:07:12.644 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/PS3.conf
INFO  2012-06-08 14:07:12.644 [main] Loading configuration file: Realtek.conf
DEBUG 2012-06-08 14:07:12.644 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Realtek.conf
INFO  2012-06-08 14:07:12.644 [main] Loading configuration file: Samsung.conf
DEBUG 2012-06-08 14:07:12.644 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Samsung.conf
INFO  2012-06-08 14:07:12.644 [main] Loading configuration file: SamsungAllShare.conf
DEBUG 2012-06-08 14:07:12.644 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/SamsungAllShare.conf
INFO  2012-06-08 14:07:12.644 [main] Loading configuration file: SamsungWiseLink.conf
DEBUG 2012-06-08 14:07:12.644 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/SamsungWiseLink.conf
INFO  2012-06-08 14:07:12.644 [main] Loading configuration file: Showtime3.conf
DEBUG 2012-06-08 14:07:12.644 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Showtime3.conf
INFO  2012-06-08 14:07:12.644 [main] Loading configuration file: SonyBluray.conf
DEBUG 2012-06-08 14:07:12.644 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/SonyBluray.conf
INFO  2012-06-08 14:07:12.659 [main] Loading configuration file: Streamium.conf
DEBUG 2012-06-08 14:07:12.659 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Streamium.conf
INFO  2012-06-08 14:07:12.659 [main] Loading configuration file: WDTVLive.conf
DEBUG 2012-06-08 14:07:12.659 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/WDTVLive.conf
INFO  2012-06-08 14:07:12.659 [main] Loading configuration file: WMP.conf
DEBUG 2012-06-08 14:07:12.659 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/WMP.conf
INFO  2012-06-08 14:07:12.659 [main] Loading configuration file: XBMC.conf
DEBUG 2012-06-08 14:07:12.659 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/XBMC.conf
INFO  2012-06-08 14:07:12.659 [main] Loading configuration file: XBOX360.conf
DEBUG 2012-06-08 14:07:12.659 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/XBOX360.conf
INFO  2012-06-08 14:07:12.659 [main] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-06-08 14:07:12.659 [main] launching: win32/mplayer.exe
DEBUG 2012-06-08 14:07:15.144 [main] launching: win32/mplayer.exe
INFO  2012-06-08 14:07:15.629 [main] Done!
INFO  2012-06-08 14:07:15.629 [main] Found AviSynth plugins dir: C:\Program Files (x86)\AviSynth\plugins
INFO  2012-06-08 14:07:15.629 [main] Found VideoLAN version 2.0.1 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-06-08 14:07:15.629 [main] Searching for plugins in C:\Program Files (x86)\PS3 Media Server\plugins
INFO  2012-06-08 14:07:15.629 [main] Found plugin: net.pms.external.LastFMScrobbler
INFO  2012-06-08 14:07:15.629 [main] Found plugin: com.chocolatey.pmsencoder.Plugin
INFO  2012-06-08 14:07:15.644 [main] PMSEncoder: initializing PMSEncoder 1.6.0
INFO  2012-06-08 14:07:15.675 [main] PMSEncoder: log directory: C:\Program Files (x86)\PS3 Media Server
INFO  2012-06-08 14:07:15.675 [main] PMSEncoder: loading built-in log4j config file: jar:file:/C:/Program%20Files%20(x86)/PS3%20Media%20Server/plugins/pmsencoder.jar!/log4j_default.xml
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: PMSEncoder
INFO  2012-06-08 14:07:16.799 [main] PMSEncoder: checking engine list: [pmsencoder, mencoder, tsmuxer, mplayeraudio, ffmpegaudio, tsmuxeraudio, mencoderwebvideo, vlcvideo, mplayervideodump, mplayerwebaudio, vlcaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-06-08 14:07:16.799 [main] PMSEncoder: engine enabled
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: FFmpeg Audio
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: MEncoder
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: Avisynth/MEncoder
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: MPlayer Audio
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: MEncoder Web
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: MPlayer Web
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: tsMuxeR
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2012-06-08 14:07:16.799 [main] Found VLC version 2.0.1 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: VLC Audio Streaming
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: VLC Video Streaming
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2012-06-08 14:07:16.799 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-06-08 14:07:16.845 [main] Using forced address 192.168.1.117
INFO  2012-06-08 14:07:16.845 [main] Created socket: /192.168.1.117:5001
INFO  2012-06-08 14:07:16.861 [HTTP Server] Starting DLNA Server on host 192.168.1.117 and port 5001...
INFO  2012-06-08 14:07:16.861 [main] Checking shared folder: E:\Peliculas
INFO  2012-06-08 14:07:16.861 [main] Checking shared folder: D:\Peliculas 3D
INFO  2012-06-08 14:07:16.861 [main] Checking shared folder: D:\Peliculas HD
INFO  2012-06-08 14:07:16.861 [main] Checking shared folder: D:\Series HD
INFO  2012-06-08 14:07:16.861 [main] Checking shared folder: E:\Series
INFO  2012-06-08 14:07:16.861 [main] Checking shared folder: C:\Users\NuestraPC\Music
INFO  2012-06-08 14:07:16.861 [main] Checking shared folder: E:\Musica
INFO  2012-06-08 14:07:16.877 [main] Checking shared folder: E:\Privado
DEBUG 2012-06-08 14:07:16.892 [main] Sending ALIVE...
INFO  2012-06-08 14:07:16.970 [main] Using the following UUID configured in PMS.conf: b1e89f9e-c103-3e87-8f4b-65df46097700
INFO  2012-06-08 14:07:19.328 [HTTP Server] Access granted to /192.168.1.145 by rule: 192.168.1.145
INFO  2012-06-08 14:07:19.436 [pool-4-thread-1] Checking IP: 192.168.1.145 for Sony Bravia EX
INFO  2012-06-08 14:07:21.108 [main] The server should now appear on your renderer
INFO  2012-06-08 14:07:24.665 [pool-4-thread-1] Renderer Sony Bravia EX found on this address: 192.168.1.145
DEBUG 2012-06-08 14:07:24.665 [pool-4-thread-1] Starting ping -n 3 -l 64000 192.168.1.145
DEBUG 2012-06-08 14:07:26.678 [SpeedStats Failsafe] Stopping process: ping-0
INFO  2012-06-08 14:07:26.678 [pool-4-thread-1] Address /192.168.1.145 has an estimated network speed of: 25 Mb/s
DEBUG 2012-06-08 14:07:31.124 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-08 14:07:56.288 [UPNP-AliveMessageSender] Sending ALIVE...
It looks like you are using some custom IP settings in PMS but not in UMS. Please compare the Network settings in the General Configuration tab
eva01
Post by eva01 »
The same in both cases
eva01
Post by eva01 »
As you can see is the same, i took a print screen in both cases and i copied both debug logs to compare. Check the date and time and you see that the difference is one minute or less (what it took me closed ums last version, and open PMS). UMS dont see the tv, PMS yes.
If I can help you with more, tell me, I dont have any problem ;)
Sorry for my english, I am from Argentine, we speak spanish
UMS debug
DEBUG 2012-06-09 19:25:24.382 [main] Java version: 1.7.0_04
DEBUG 2012-06-09 19:25:24.382 [main] Java vendor: Oracle Corporation
DEBUG 2012-06-09 19:25:24.382 [main] Java class path: update.jar;ums.jar
DEBUG 2012-06-09 19:25:24.382 [main] Operating system name: Windows 7
DEBUG 2012-06-09 19:25:24.382 [main] Operating system architecture: x86
DEBUG 2012-06-09 19:25:24.382 [main] Operating system version: 6.1
DEBUG 2012-06-09 19:25:24.429 [main] SUN 1.7: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
DEBUG 2012-06-09 19:25:24.429 [main] SunRsaSign 1.7: Sun RSA signature provider
DEBUG 2012-06-09 19:25:24.429 [main] SunEC 1.7: Sun Elliptic Curve provider (EC, ECDSA, ECDH)
DEBUG 2012-06-09 19:25:24.429 [main] SunJSSE 1.7: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
DEBUG 2012-06-09 19:25:24.429 [main] SunJCE 1.7: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
DEBUG 2012-06-09 19:25:24.429 [main] SunJGSS 1.7: Sun (Kerberos v5, SPNEGO)
DEBUG 2012-06-09 19:25:24.429 [main] SunSASL 1.7: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5, NTLM; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5, NTLM)
DEBUG 2012-06-09 19:25:24.429 [main] XMLDSig 1.0: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
DEBUG 2012-06-09 19:25:24.429 [main] SunPCSC 1.7: Sun PC/SC provider
DEBUG 2012-06-09 19:25:24.429 [main] SunMSCAPI 1.7: Sun's Microsoft Crypto API provider
DEBUG 2012-06-09 19:25:24.429 [main] Set parameter http.useragent = Jakarta Commons-HttpClient/3.1
DEBUG 2012-06-09 19:25:24.429 [main] Set parameter http.protocol.version = HTTP/1.1
DEBUG 2012-06-09 19:25:24.429 [main] Set parameter http.connection-manager.class = class org.apache.commons.httpclient.SimpleHttpConnectionManager
DEBUG 2012-06-09 19:25:24.429 [main] Set parameter http.protocol.cookie-policy = default
DEBUG 2012-06-09 19:25:24.429 [main] Set parameter http.protocol.element-charset = US-ASCII
DEBUG 2012-06-09 19:25:24.429 [main] Set parameter http.protocol.content-charset = ISO-8859-1
DEBUG 2012-06-09 19:25:24.429 [main] Set parameter http.method.retry-handler = org.apache.commons.httpclient.DefaultHttpMethodRetryHandler@1fac3a2
DEBUG 2012-06-09 19:25:24.429 [main] Set parameter http.dateparser.patterns = [EEE, dd MMM yyyy HH:mm:ss zzz, EEEE, dd-MMM-yy HH:mm:ss zzz, EEE MMM d HH:mm:ss yyyy, EEE, dd-MMM-yyyy HH:mm:ss z, EEE, dd-MMM-yyyy HH-mm-ss z, EEE, dd MMM yy HH:mm:ss z, EEE dd-MMM-yyyy HH:mm:ss z, EEE dd MMM yyyy HH:mm:ss z, EEE dd-MMM-yyyy HH-mm-ss z, EEE dd-MMM-yy HH:mm:ss z, EEE dd MMM yy HH:mm:ss z, EEE,dd-MMM-yy HH:mm:ss z, EEE,dd-MMM-yyyy HH:mm:ss z, EEE, dd-MM-yyyy HH:mm:ss z]
DEBUG 2012-06-09 19:25:24.616 [pool-2-thread-1] Open connection to universal-media-server.googlecode.com:80
DEBUG 2012-06-09 19:25:24.632 [pool-2-thread-1] >> "GET /git/src/main/external-resources/update/update_3.properties?currentVersion=1.1.0&operatingSystem=windows&cacheBuster=0.8636408087297204 HTTP/1.1[\r][\n]"
DEBUG 2012-06-09 19:25:24.632 [pool-2-thread-1] Adding Host request header
DEBUG 2012-06-09 19:25:24.632 [pool-2-thread-1] >> "User-Agent: Jakarta Commons-HttpClient/3.1[\r][\n]"
DEBUG 2012-06-09 19:25:24.632 [pool-2-thread-1] >> "Host: universal-media-server.googlecode.com[\r][\n]"
DEBUG 2012-06-09 19:25:24.632 [pool-2-thread-1] >> "[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "HTTP/1.1 200 OK[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "ETag: "32323437356236376533363236653161346263326137363238346130356365376665306366303963/src/main/external-resources/update/update_3.properties"[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "Date: Sat, 09 Jun 2012 22:25:14 GMT[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "Cache-Control: public,max-age=60[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "Accept-Ranges: none[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "Content-Type: text/plain; charset=ISO-8859-1[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "X-Content-Type-Options: nosniff[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "Server: git_frontend[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "X-XSS-Protection: 1; mode=block[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "Transfer-Encoding: chunked[\r][\n]"
DEBUG 2012-06-09 19:25:25.022 [pool-2-thread-1] << "[\r][\n]"
WARN  2012-06-09 19:25:25.038 [pool-2-thread-1] Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] Buffering response body
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] << "6"
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] << "f"
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] << "[\r]"
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] << "[\n]"
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] << "LatestVersion="1.1.0"[\r][\n]"
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] << "DownloadUrl.windows="http://universal-media-server.googlecode.com/files/UMS-1.1.0.exe"[\r][\n]"
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] << "0"
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] << "[\r][\n]"
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] Resorting to protocol version default close connection policy
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] Should NOT close connection, using HTTP/1.1
DEBUG 2012-06-09 19:25:25.038 [pool-2-thread-1] Releasing connection back to connection manager.
INFO  2012-06-09 19:25:25.256 [main] Starting Universal Media Server 1.1.0
INFO  2012-06-09 19:25:25.256 [main] Based on PS3 Media Server (ps3mediaserver.org) by shagrath, copyright 2008-2012
INFO  2012-06-09 19:25:25.256 [main] http://www.universalmediaserver.com
INFO  2012-06-09 19:25:25.256 [main] Build: 4e3acd40a (2012-06-09)
INFO  2012-06-09 19:25:25.272 [main] Java: 1.7.0_04-Oracle Corporation
INFO  2012-06-09 19:25:25.272 [main] OS: Windows 7 x86 6.1
INFO  2012-06-09 19:25:25.272 [main] Encoding: UTF-8
INFO  2012-06-09 19:25:25.272 [main] Memory: 742 MB
INFO  2012-06-09 19:25:25.272 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-06-09 19:25:25.272 [main] Temp folder: C:\Users\NUESTR~1\AppData\Local\Temp\ps3mediaserver
INFO  2012-06-09 19:25:25.272 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2012-06-09 19:25:25.272 [main] debug.log: C:\Program Files (x86)\Universal Media Server\debug.log
INFO  2012-06-09 19:25:25.272 [main] Profile directory: C:\ProgramData\UMS
INFO  2012-06-09 19:25:25.272 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2012-06-09 19:25:25.272 [main] Profile status: rw
INFO  2012-06-09 19:25:25.272 [main] Profile name: NuestraPC-PC
INFO  2012-06-09 19:25:25.272 [main] Loading MediaInfo library
INFO  2012-06-09 19:25:25.365 [main] Loaded MediaInfoLib - v0.7.58
INFO  2012-06-09 19:25:25.381 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2012-06-09 19:25:25.381 [main] Loading configuration file: AirPlayer.conf
DEBUG 2012-06-09 19:25:25.381 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/AirPlayer.conf
INFO  2012-06-09 19:25:25.381 [main] Loading configuration file: Android.conf
DEBUG 2012-06-09 19:25:25.381 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Android.conf
INFO  2012-06-09 19:25:25.381 [main] Loading configuration file: Bravia4500.conf
DEBUG 2012-06-09 19:25:25.381 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Bravia4500.conf
INFO  2012-06-09 19:25:25.381 [main] Loading configuration file: Bravia5500.conf
DEBUG 2012-06-09 19:25:25.381 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Bravia5500.conf
INFO  2012-06-09 19:25:25.381 [main] Loading configuration file: BraviaEX.conf
DEBUG 2012-06-09 19:25:25.381 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/BraviaEX.conf
INFO  2012-06-09 19:25:25.381 [main] Loading configuration file: DLinkDSM510.conf
DEBUG 2012-06-09 19:25:25.381 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/DLinkDSM510.conf
INFO  2012-06-09 19:25:25.381 [main] Loading configuration file: FreeboxHD.conf
DEBUG 2012-06-09 19:25:25.381 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/FreeboxHD.conf
INFO  2012-06-09 19:25:25.381 [main] Loading configuration file: FreecomMusicPal.conf
DEBUG 2012-06-09 19:25:25.381 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/FreecomMusicPal.conf
INFO  2012-06-09 19:25:25.381 [main] Loading configuration file: iPad-iPhone.conf
DEBUG 2012-06-09 19:25:25.381 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/iPad-iPhone.conf
INFO  2012-06-09 19:25:25.381 [main] Loading configuration file: Kuro.conf
DEBUG 2012-06-09 19:25:25.381 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Kuro.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: LGST600.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/LGST600.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: N900.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/N900.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: OPPOBDP83.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/OPPOBDP83.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: OPPOBDP93.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/OPPOBDP93.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: Panasonic.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Panasonic.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: Philips.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Philips.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: PhilipsPFL.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PhilipsPFL.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: PopcornHour.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PopcornHour.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: PS3.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PS3.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: Realtek.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Realtek.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: SamsungAllShare.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SamsungAllShare.conf
INFO  2012-06-09 19:25:25.396 [main] Loading configuration file: SamsungWiseLink.conf
DEBUG 2012-06-09 19:25:25.396 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SamsungWiseLink.conf
INFO  2012-06-09 19:25:25.412 [main] Loading configuration file: Showtime3.conf
DEBUG 2012-06-09 19:25:25.412 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Showtime3.conf
INFO  2012-06-09 19:25:25.412 [main] Loading configuration file: SonyBluray.conf
DEBUG 2012-06-09 19:25:25.412 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SonyBluray.conf
INFO  2012-06-09 19:25:25.412 [main] Loading configuration file: Streamium.conf
DEBUG 2012-06-09 19:25:25.412 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Streamium.conf
INFO  2012-06-09 19:25:25.412 [main] Loading configuration file: WDTVLive.conf
DEBUG 2012-06-09 19:25:25.412 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/WDTVLive.conf
INFO  2012-06-09 19:25:25.412 [main] Loading configuration file: WMP.conf
DEBUG 2012-06-09 19:25:25.412 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/WMP.conf
INFO  2012-06-09 19:25:25.412 [main] Loading configuration file: XBMC.conf
DEBUG 2012-06-09 19:25:25.412 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/XBMC.conf
INFO  2012-06-09 19:25:25.412 [main] Loading configuration file: Xbox360.conf
DEBUG 2012-06-09 19:25:25.412 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Xbox360.conf
INFO  2012-06-09 19:25:25.412 [main] Loading configuration file: YamahaRXV671.conf
DEBUG 2012-06-09 19:25:25.412 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/YamahaRXV671.conf
INFO  2012-06-09 19:25:25.412 [main] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-06-09 19:25:25.412 [main] launching: win32/mplayer.exe
DEBUG 2012-06-09 19:25:25.872 [main] launching: win32/mplayer.exe
INFO  2012-06-09 19:25:26.029 [main] Done!
INFO  2012-06-09 19:25:26.029 [main] Found AviSynth plugins dir: C:\Program Files (x86)\AviSynth\plugins
INFO  2012-06-09 19:25:26.029 [main] Found VideoLAN version 2.0.1 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-06-09 19:25:26.029 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2012-06-09 19:25:26.029 [main] Found plugin: com.chocolatey.pmsencoder.Plugin
INFO  2012-06-09 19:25:26.045 [main] PMSEncoder: initializing PMSEncoder 1.6.0
INFO  2012-06-09 19:25:26.076 [main] PMSEncoder: log directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-06-09 19:25:26.076 [main] PMSEncoder: loading built-in log4j config file: jar:file:/C:/Program%20Files%20(x86)/Universal%20Media%20Server/plugins/pmsencoder.jar!/log4j_default.xml
INFO  2012-06-09 19:25:27.246 [main] Registering transcoding engine: PMSEncoder
INFO  2012-06-09 19:25:27.246 [main] PMSEncoder: checking engine list: [pmsencoder, mencoder, avsmencoder, tsmuxer, avsffmpeg, ffmpegaudio, mplayeraudio, tsmuxeraudio, vlcvideo, mencoderwebvideo, mplayervideodump, vlcaudio, mplayerwebaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-06-09 19:25:27.246 [main] PMSEncoder: engine enabled
INFO  2012-06-09 19:25:27.246 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2012-06-09 19:25:27.246 [main] Registering transcoding engine: FFmpeg Audio
INFO  2012-06-09 19:25:27.246 [main] Registering transcoding engine: MEncoder
INFO  2012-06-09 19:25:27.246 [main] Registering transcoding engine: AviSynth/MEncoder
INFO  2012-06-09 19:25:27.246 [main] Registering transcoding engine: MPlayer Audio
INFO  2012-06-09 19:25:27.246 [main] Registering transcoding engine: MEncoder Web
INFO  2012-06-09 19:25:27.246 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2012-06-09 19:25:27.246 [main] Registering transcoding engine: MPlayer Web
INFO  2012-06-09 19:25:27.246 [main] Registering transcoding engine: tsMuxeR
INFO  2012-06-09 19:25:27.262 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2012-06-09 19:25:27.262 [main] Found VLC version 2.0.1 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-06-09 19:25:27.262 [main] Registering transcoding engine: VLC Audio Streaming
INFO  2012-06-09 19:25:27.262 [main] Registering transcoding engine: VLC Video Streaming
INFO  2012-06-09 19:25:27.262 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2012-06-09 19:25:27.262 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-06-09 19:25:27.308 [main] Using forced address 192.168.1.117
INFO  2012-06-09 19:25:27.308 [main] Created socket: /192.168.1.117:5001
INFO  2012-06-09 19:25:27.308 [HTTP Server] Starting DLNA Server on host 192.168.1.117 and port 5001...
INFO  2012-06-09 19:25:27.324 [main] Checking shared folder: E:\Musica
INFO  2012-06-09 19:25:27.324 [main] Checking shared folder: E:\Series
INFO  2012-06-09 19:25:27.324 [main] Checking shared folder: E:\Peliculas
INFO  2012-06-09 19:25:27.324 [main] Checking shared folder: D:\Peliculas 3D
INFO  2012-06-09 19:25:27.324 [main] Checking shared folder: D:\Peliculas HD
INFO  2012-06-09 19:25:27.324 [main] Checking shared folder: D:\Series HD
DEBUG 2012-06-09 19:25:27.355 [main] Sending ALIVE...
INFO  2012-06-09 19:25:27.433 [main] Using the following UUID configured in UMS.conf: c26252f3-b2f9-49eb-9aff-e430b5cc032f
INFO  2012-06-09 19:25:32.762 [main] The server should now appear on your renderer
DEBUG 2012-06-09 19:25:42.777 [UPNP-AliveMessageSender] Sending ALIVE...
PMS Debug
INFO  2012-06-09 19:26:19.002 [main] Starting PS3 Media Server 1.52.2-SB71
INFO  2012-06-09 19:26:19.018 [main] by shagrath / 2008-2012
INFO  2012-06-09 19:26:19.018 [main] http://ps3mediaserver.org
INFO  2012-06-09 19:26:19.018 [main] https://github.com/ps3mediaserver/ps3mediaserver
INFO  2012-06-09 19:26:19.018 [main] Custom build by SubJunk, http://www.spirton.com
INFO  2012-06-09 19:26:19.018 [main] Build: b4e8b14fb (2012-04-15)
INFO  2012-06-09 19:26:19.018 [main] Java: 1.7.0_04-Oracle Corporation
INFO  2012-06-09 19:26:19.018 [main] OS: Windows 7 x86 6.1
INFO  2012-06-09 19:26:19.018 [main] Encoding: UTF-8
INFO  2012-06-09 19:26:19.018 [main] Working directory: C:\Program Files (x86)\PS3 Media Server
INFO  2012-06-09 19:26:19.033 [main] Temp folder: C:\Users\NUESTR~1\AppData\Local\Temp\ps3mediaserver
INFO  2012-06-09 19:26:19.033 [main] Logging config file: C:\Program Files (x86)\PS3 Media Server\logback.xml
INFO  2012-06-09 19:26:19.033 [main] debug.log: C:\Program Files (x86)\PS3 Media Server\debug.log
INFO  2012-06-09 19:26:19.033 [main] Profile directory: C:\ProgramData\PMS
INFO  2012-06-09 19:26:19.033 [main] Profile path: C:\ProgramData\PMS\PMS.conf
INFO  2012-06-09 19:26:19.033 [main] Profile status: rw
INFO  2012-06-09 19:26:19.033 [main] Profile name: NuestraPC-PC
INFO  2012-06-09 19:26:19.033 [main] Loading MediaInfo library
INFO  2012-06-09 19:26:19.158 [main] Loaded MediaInfoLib - v0.7.56
INFO  2012-06-09 19:26:19.158 [main] Loading renderer configurations from C:\Program Files (x86)\PS3 Media Server\renderers
INFO  2012-06-09 19:26:19.158 [main] Loading configuration file: AirPlayer.conf
DEBUG 2012-06-09 19:26:19.158 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/AirPlayer.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: Android.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Android.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: Bravia4500.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Bravia4500.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: Bravia5500.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Bravia5500.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: BraviaEX.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/BraviaEX.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: FreeboxHD.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/FreeboxHD.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: FreecomMusicPal.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/FreecomMusicPal.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: iPad-iPhone.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/iPad-iPhone.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: Kuro.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Kuro.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: N900.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/N900.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: Panasonic.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Panasonic.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: Philips.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Philips.conf
INFO  2012-06-09 19:26:19.174 [main] Loading configuration file: PhilipsPFL.conf
DEBUG 2012-06-09 19:26:19.174 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/PhilipsPFL.conf
INFO  2012-06-09 19:26:19.189 [main] Loading configuration file: PopcornHour.conf
DEBUG 2012-06-09 19:26:19.189 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/PopcornHour.conf
INFO  2012-06-09 19:26:19.189 [main] Loading configuration file: PS3.conf
DEBUG 2012-06-09 19:26:19.189 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/PS3.conf
INFO  2012-06-09 19:26:19.189 [main] Loading configuration file: Realtek.conf
DEBUG 2012-06-09 19:26:19.189 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Realtek.conf
INFO  2012-06-09 19:26:19.189 [main] Loading configuration file: Samsung.conf
DEBUG 2012-06-09 19:26:19.189 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Samsung.conf
INFO  2012-06-09 19:26:19.189 [main] Loading configuration file: SamsungAllShare.conf
DEBUG 2012-06-09 19:26:19.189 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/SamsungAllShare.conf
INFO  2012-06-09 19:26:19.189 [main] Loading configuration file: SamsungWiseLink.conf
DEBUG 2012-06-09 19:26:19.189 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/SamsungWiseLink.conf
INFO  2012-06-09 19:26:19.189 [main] Loading configuration file: Showtime3.conf
DEBUG 2012-06-09 19:26:19.189 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Showtime3.conf
INFO  2012-06-09 19:26:19.189 [main] Loading configuration file: SonyBluray.conf
DEBUG 2012-06-09 19:26:19.189 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/SonyBluray.conf
INFO  2012-06-09 19:26:19.189 [main] Loading configuration file: Streamium.conf
DEBUG 2012-06-09 19:26:19.189 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/Streamium.conf
INFO  2012-06-09 19:26:19.189 [main] Loading configuration file: WDTVLive.conf
DEBUG 2012-06-09 19:26:19.189 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/WDTVLive.conf
INFO  2012-06-09 19:26:19.205 [main] Loading configuration file: WMP.conf
DEBUG 2012-06-09 19:26:19.205 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/WMP.conf
INFO  2012-06-09 19:26:19.205 [main] Loading configuration file: XBMC.conf
DEBUG 2012-06-09 19:26:19.205 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/XBMC.conf
INFO  2012-06-09 19:26:19.205 [main] Loading configuration file: XBOX360.conf
DEBUG 2012-06-09 19:26:19.205 [main] Base path set to file:///C:/Program%20Files%20(x86)/PS3%20Media%20Server/renderers/XBOX360.conf
INFO  2012-06-09 19:26:19.205 [main] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-06-09 19:26:19.205 [main] launching: win32/mplayer.exe
DEBUG 2012-06-09 19:26:19.346 [main] launching: win32/mplayer.exe
INFO  2012-06-09 19:26:19.457 [main] Done!
INFO  2012-06-09 19:26:19.457 [main] Found AviSynth plugins dir: C:\Program Files (x86)\AviSynth\plugins
INFO  2012-06-09 19:26:19.457 [main] Found VideoLAN version 2.0.1 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-06-09 19:26:19.457 [main] Searching for plugins in C:\Program Files (x86)\PS3 Media Server\plugins
INFO  2012-06-09 19:26:19.457 [main] Found plugin: net.pms.external.LastFMScrobbler
INFO  2012-06-09 19:26:19.457 [main] Found plugin: com.chocolatey.pmsencoder.Plugin
INFO  2012-06-09 19:26:19.472 [main] PMSEncoder: initializing PMSEncoder 1.6.0
INFO  2012-06-09 19:26:19.503 [main] PMSEncoder: log directory: C:\Program Files (x86)\PS3 Media Server
INFO  2012-06-09 19:26:19.503 [main] PMSEncoder: loading built-in log4j config file: jar:file:/C:/Program%20Files%20(x86)/PS3%20Media%20Server/plugins/pmsencoder.jar!/log4j_default.xml
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: PMSEncoder
INFO  2012-06-09 19:26:20.580 [main] PMSEncoder: checking engine list: [mencoder, avsmencoder, tsmuxer, avsffmpeg, mplayeraudio, ffmpegaudio, tsmuxeraudio, pmsencoder, mencoderwebvideo, vlcvideo, mplayervideodump, mplayerwebaudio, vlcaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-06-09 19:26:20.580 [main] PMSEncoder: prioritised engine: [pmsencoder, mencoder, avsmencoder, tsmuxer, avsffmpeg, mplayeraudio, ffmpegaudio, tsmuxeraudio, mencoderwebvideo, vlcvideo, mplayervideodump, mplayerwebaudio, vlcaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: FFmpeg Audio
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: MEncoder
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: Avisynth/MEncoder
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: MPlayer Audio
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: MEncoder Web
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: MPlayer Web
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: tsMuxeR
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2012-06-09 19:26:20.580 [main] Found VLC version 2.0.1 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: VLC Audio Streaming
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: VLC Video Streaming
INFO  2012-06-09 19:26:20.580 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2012-06-09 19:26:20.595 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-06-09 19:26:20.627 [main] Using forced address 192.168.1.117
INFO  2012-06-09 19:26:20.627 [main] Created socket: /192.168.1.117:5001
INFO  2012-06-09 19:26:20.642 [HTTP Server] Starting DLNA Server on host 192.168.1.117 and port 5001...
INFO  2012-06-09 19:26:20.642 [main] Checking shared folder: E:\Peliculas
INFO  2012-06-09 19:26:20.642 [main] Checking shared folder: D:\Peliculas 3D
INFO  2012-06-09 19:26:20.642 [main] Checking shared folder: D:\Peliculas HD
INFO  2012-06-09 19:26:20.642 [main] Checking shared folder: D:\Series HD
INFO  2012-06-09 19:26:20.642 [main] Checking shared folder: E:\Series
INFO  2012-06-09 19:26:20.642 [main] Checking shared folder: C:\Users\NuestraPC\Music
INFO  2012-06-09 19:26:20.642 [main] Checking shared folder: E:\Musica
INFO  2012-06-09 19:26:20.642 [main] Checking shared folder: E:\Privado
DEBUG 2012-06-09 19:26:20.673 [main] Sending ALIVE...
INFO  2012-06-09 19:26:20.736 [main] Using the following UUID configured in PMS.conf: b1e89f9e-c103-3e87-8f4b-65df46097700
INFO  2012-06-09 19:26:22.537 [HTTP Server] Access granted to /192.168.1.145 by rule: 192.168.1.145
INFO  2012-06-09 19:26:22.618 [pool-4-thread-1] Checking IP: 192.168.1.145 for Sony Bravia EX
INFO  2012-06-09 19:26:25.278 [main] The server should now appear on your renderer
INFO  2012-06-09 19:26:27.243 [pool-4-thread-1] Renderer Sony Bravia EX found on this address: 192.168.1.145
DEBUG 2012-06-09 19:26:27.243 [pool-4-thread-1] Starting ping -n 3 -l 64000 192.168.1.145
DEBUG 2012-06-09 19:26:29.256 [SpeedStats Failsafe] Stopping process: ping-0
INFO  2012-06-09 19:26:29.256 [pool-4-thread-1] Address /192.168.1.145 has an estimated network speed of: 32 Mb/s
DEBUG 2012-06-09 19:26:35.293 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-06-09 19:26:37.178 [HTTP Server] Access denied to /192.168.1.101
PMS screen
PMS screen
screen pms.jpg (163.36 KiB) Viewed 16556 times
UMS screen
UMS screen
screen ums.jpg (168.82 KiB) Viewed 16556 times
Re: Sony KDL-EX725 doesn't see UMS
Thanks for the information and your patience :) I'm sorry this is taking so long but it's a strange bug :)
Can you please also include these files:
eva01
Post by eva01 »
No problem, I am very happy to try and work even slightly in this great project ;)
I attached the files you requested it
Files.zip
(1.43 KiB) Downloaded 1003 times
