[Solved] Shutdown plugin
Re: Shutdown plugin
This feature has been added to the upcoming UMS version, in the Server Settings folder
Nierewa
Re: [Solved] Shutdown plugin
Post by Nierewa »
Hi. I've installed UMS 14.9.0 but don't see this feature.
How can I enable this one?
Edit:
Found it.
But this doesn't work. PC won't shutdown.
You can enable the server settings folder
Clipboard Image (2).jpg (20.92 KiB) Viewed 4418 times
which will appear on your device
Screenshot 2025-02-12 185848.png (5.62 KiB) Viewed 4418 times
And give you the option to restart UMS or shutdown the computer.
Screenshot 2025-02-12 185926.png (46.98 KiB) Viewed 4418 times
You could also do this in the tools menu if you are using the Web UI
Screenshot 2025-02-12 190326.png (15.62 KiB) Viewed 4418 times
There is also permissions for this in the user accounts to prevent other users shutting down the computer. If it is not working then it might be disabled here.
Screenshot 2025-02-12 190517.png (29.52 KiB) Viewed 4418 times
Nierewa
Post by Nierewa »
Thank you for your explanation :D
With DLNA-Client shutdown works.
Using the WEB UI doesn't shutdown. I will have a look of the permissions.
Nierewa
Post by Nierewa »
With docker shutdown doesn't work anymore.
See my post in this thread:
viewtopic.php?p=49545#p49545
