[Solved] ERROR Database error while writing to FAILED_LOOKUPS
Re: ERROR Database error while writing to FAILED_LOOKUPS
I just tryed that version you uploaded - It works perfectly!SubJunk wrote: ↑Sun Jul 25, 2021 4:49 pm Ok great, thanks for testing. Please let me know how this one goes: https://www.universalmediaserver.com/up ... x86_64.tgz
No problems/errors/anomolies at all in the Log
Video folder access was fast/speedy being access on the TV
Videos played fine
Thank you for that
I was not sure if you wanted a log of this but decided to upload one anyway perhaps for comparison to review/check stuff
I changed the Log level: Trace
If you still want any more logs, just let me know
Thank you SubJunk
- ums_dbg_2021-07-26-03-54 - UMS-revert-2496-multiple-db-connections-x86_64.zip
- (83.79 KiB) Downloaded 303 times
That's a relief, thanks for your testing CatMan, and thanks for the extra notes. I'm glad it's working so well for you
That fix will be in the next version. Please let us know if you have any more problems
