Playback issue on Fetch TV
redavenger
Re: Playback issue on Fetch TV
Post by redavenger »
still cant play or find any folders with this new version 10.13.0
would anyone be able to look into this and fix it?
I'm interested in helping to fix this. Can you please attach logs from 10.8.0 so we can compare that with 10.7.0?
redavenger
ive already have the necessary logs attached earlier in the thread from version 10.7 and a later version after 10.7. Can you use those as it does not matter what version i tried after 10.7 none of them manage to detect the fetch box.
redavenger
so does anyone know if the issue is resolved the latest 10.15.0 build?
I had a look through the changes between 10.7 and 10.8 at https://github.com/UniversalMediaServer ... 0...10.8.0 and can't see anything that would explain this. It might have been caused by a third party dependency or something I missed.
If I make you some test builds will you try them? Since I don't have any ideas I would just upload some builds between 10.7 and 10.8 until we narrow it down
redavenger
yeah that sounds ok I could try some builds.
redavenger
thanks for that
I can confirm both work for me.
I also tried version 10.15.0 and that did not work.
redavenger
tried both and both dont work.
I did notice the 2nd one detected the fetch box as sony xperia ... i then disabled all renders and it just left it for fetch tv, but it still didnt work.
