[Solved] Issues with transcoding with FFmpeg and MEncoder
witek
Re: Issues with transcoding with FFmpeg and MEncoder
Post by witek »
Another test came to my mind. I decided to remux the .mkv file to separate the different parts of the file and try to see what I can come up with.
I've create a total of 6 files:
  1. Full file with both audio tracks and the subtitle track but with the font removed.(filename: CB_full_no_font.mkv)
  2. File with both audio tracks but with the subtitle track removed along with the font. (filename: CB_no-sub_2audio.mkv)
  3. File with English AC3 audio track. (filename: CB_no-sub_ac3-audio.mkv)
  4. File with the Japanese FLAC audio track. (filename: CB_no-sub_flac-audio.mkv)
  5. File with English AC3 audio track and subtitles but with the font removed. (filename:CB_ac3-audio_sub_no_font.mkv)
  6. File with the Japanese FLAC and subtitles but with the font removed. (filename: CB_flac-audio_sub_no_font.mkv)
Then I've tried playing all of them using FFmpeg transcoding. Out of all of the combinations only the two files with no subtitles and a single audio track played. I'm attaching the log file, in the log you will find one occasion where MEncoder ran, not sure why I did a couple of tries and it always started at that one point, sorry for that. I'm not sure if this will be helpful in any way but if it is then I can do more tests like this. It was all played using UMS 14.5. Looks like in this instance the subtitle track is what causes issues, but other than that I don't really know what to make of this. I've also noticed that some of the files ended with the -22 error.
ums_dbg_2024-09-09-19-00.zip
(879.33 KiB) Downloaded 3280 times
I did see an error I have not seen before but it may have been caused by the remux you did. It may also be a hint that the problem is to do with the subtitle logic as the other tests without subtitles work.
Error while executing: To remux when video codec is MPEG-2 and there are no subtitles:    vcodec == mpeg2 && srtfile == null : In file: inline evaluation of: ``To remux when video codec is MPEG-2 and there are no subtitles:    vcodec == mpe . . . '' Encountered "when" at line 1, column 10.
[jupnp-stream-server-98]   Starting transcode/remux of CB_no-sub_2audio.mkv with media info: Container: MKV, Size: 12886076858, Overall Bitrate: 14887696, File Title from Metadata: Cowboy Bebop: Knockin' on Heaven's Door (2001), Duration: 1:55:24.417, Video Tracks: 1 [Video Id: 0, Language Code: jpn, Codec: h264, Format Profile: high 10, Format Level: 4.1, Stream Order: 0, Duration: 1:54:57.641, Resolution: 1772 x 952, Display Aspect Ratio: 1.85:1, Scan Type: Progressive, Frame Rate: 23.976, Reference Frame Count: 4, Bit Depth: 10], Audio Tracks: 2 [Audio Id: 0, Language Code: jpn, Codec: FLAC, Stream Order: 1, Bitrate: 1943013, Bits per Sample: 24, Channels: 6, Sample Frequency: 48000 Hz], [Audio Id: 1, Language Code: eng, Codec: AC3, Stream Order: 2, Bitrate: 448000, Channels: 6, Sample Frequency: 48000 Hz], DLNAThumbnail: [Format = JPEG, Resolution = 320×172, Size = 4056, DLNA Profile = JPEG_RES_320_172], Mime Type: video/x-matroska
[jupnp-stream-server-98]   Searching for external subtitles for CB_no-sub_2audio.mkv
[jupnp-stream-server-98]   Not muxing the video stream with tsMuxeR via MEncoder because the user setting is disabled
[jupnp-stream-server-98]   Using video bitrate limit from Cookie_Monster configuration (9 Mb/s) because it is lower than the general configuration bitrate limit (90 Mb/s)
[jupnp-stream-server-98]   Adjusting the video bitrate limit to 8000 kb/s to make room for audio
[Windows Sleep Worker]     Calling SetThreadExecutionState ES_SYSTEM_REQUIRED to prevent Windows from going to sleep
[jupnp-stream-server-213]  Suspend Read: readCount=0 / writeCount=0
[StartPlaying Event]       Started playing CB_no-sub_2audio.mkv (FFmpeg Video) on your Cookie_Monster
[StartPlaying Event]       The full filename of which is: H:\Anime Mangi\CB test\CB_no-sub_2audio.mkv and the address of the renderer is: 192.168.0.78
[jupnp-stream-server-98]   Error while executing: To remux when video codec is MPEG-2 and there are no subtitles:    vcodec == mpeg2 && srtfile == null : In file: inline evaluation of: ``To remux when video codec is MPEG-2 and there are no subtitles:    vcodec == mpe . . . '' Encountered "when" at line 1, column 10.
[jupnp-stream-server-98]   Creating pipe \\.\pipe\mencoder1725901058274
[ffmpeg.exe-10-2]          [vist#0:0/h264 @ 000001b3f0dff700] [dec:h264 @ 000001b3f0ead5c0] Using auto hwaccel type dxva2 with new default device.
[Thread-76]                Result of \\.\pipe\ffmpegvideo_101_1725901057736: true
[ffmpeg.exe-10-2]          [fc#0 @ 000001b3f0defec0] Cannot find a matching stream for unlabeled input pad pad:default
[ffmpeg.exe-10-2]          Error binding filtergraph inputs/outputs: Invalid argument
[jupnp-stream-server-98]   Successfully initialized buffer to 52,428,800 bytes.
[Thread-82]                Waiting for Windows names pipe connection "\\.\pipe\mencoder1725901058274"
[mencoder.exe-11]          Starting "C:\Program Files (x86)\Universal Media Server\bin\mencoder.exe" -ss 0 "H:\Anime Mangi\CB test\CB_no-sub_2audio.mkv" -msglevel statusline=2 -oac lavc -of lavf -lavfopts format=mpegts -ovc x264 -channels 2 -lavdopts debug=0:threads=4 -lavcopts aspect=16/9:acodec=ac3:abitrate=448:threads=8 -x264encopts crf=23:preset=superfast:level=31:threads=auto:vbv_maxrate=8000:vbv_bufsize=9000 -aid 1 -nosub -noautosub -ofps 24000/1001 -vf expand=::::0:16/9:4,softskip -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1725901058274
[ffmpeg.exe-10]            EOF
[ffmpeg.exe-10]            Process C:\Program Files (x86)\Universal Media Server\bin\ffmpeg.exe has a return code of -22! Maybe an error occurred... check the log file
If it is due to subtitles then if you disable the subtitles in the transcoding settings then these should play no problem.
Clipboard Image.jpg (5.12 KiB) Viewed 13764 times
I just tried it on the problem videos I had recently and it works. I think the reason some episodes were giving me problems was due to forced subtitles for the foreign language parts as the episodes that did not have these worked fine.
This has not been a problem in the past though, at most it can take a little longer for FFmpeg to start up as it needs to process these subs and as I have an old computer it takes just long enough for my PS4 to time out while waiting, especially if the video has a lot of subtitles, but as it builds up a cache the first time restarting it immediately will allow it to play normally.
For some reason it was not doing this for me with this series, but another series I was watching with forced subtitles worked fine. Maybe something about how the video was encoded is taking longer to get started or some other problem with UMS as this is affecting both FFmpeg and Mencoder. It may be this newer version of FFmpeg is expecting another argument as it says "unlabeled input pad pad:default" where it would start transcoding on the previous one.
witek
Post by witek »
Actually I did try disabling subtitles and for some reason it makes no difference. Just did another go with Disable Subtitles on with the original file, same outcome as before.
As for the remux I did, I've used MKVToolNix, I've used it with good results in the past but I can't rule out that it puts something in the file that blows FFmpeg up.
Yeah I assumed there must be some kind of caching going on when trying to play the file repeatedly made it finally start.
I'm wondering now. Can I fiddle around with exchanging FFmpeg in UMS for a different release? Might be worth to experiment but I'm not sure if UMS won't break.
ums_dbg_2024-09-09-22-23.zip
(610.2 KiB) Downloaded 3279 times
It might be the KeepAspectRatioTranscoding in the conf that is keeping it from working now as it is part of the same input as the subtitles.
See if setting it to false again changes anything with the subtitles disabled.
I think the caching thing would only work on those videos that just seemed to stop in the logs and did not have an error -22
I was thinking the same thing about trying an earlier version of FFmpeg. You should be able to download it from somewhere but you need to make sure it is the complete version as some builds are lite versions without the options that UMS uses, this may be more of a thing on Linux though.
Just copy the binary to "C:\Program Files (x86)\Universal Media Server\bin" to overwrite the old one, or another option is to change the path to FFmpeg in UMS.conf
# Path to ffmpeg (absolute or relative from project.binaries.dir)
# Example: /usr/bin/ffmpeg
# Default:
#     Win: win32/ffmpeg.exe
#     Mac: osx/ffmpeg
#     Linux: ffmpeg + system PATH
ffmpeg_path =
I just noticed the default setting shown is incorrect for windows as it should be bin/ffmpeg.exe not win32 if I am understanding it correctly.
witek
Post by witek »
OMG, you are right I totally forgot to comment that line out after switching versions. Thanks for the tip on how to update FFmpeg.
Well I finally have some good news! :D Now after updating FFmpeg to the newest version, 09-09-2024, and disabling KeepAspectRatioTranscoding I'm able to successfully play from the original file, but only the tracks with no subtitles. It's still a step forward :). Although if the KeepAspectRatioTranscoding is not commented out it will still fail. As always I'm attaching logs for both attempts. It seems that the issue with playing this file was connected to both FFmpeg and that one config option. Other that that I don't see any other conclusions.
Subtitles are still problematic. It's not in the attached logs but I tried changing the "Use embedded style" and "Use font settings" options to see it it makes a difference but it didn't change the behavior.
ums_dbg_2024-09-11-22-25_new-ffmpeg_ratio-commented.zip
(750.94 KiB) Downloaded 3286 times
ums_dbg_2024-09-11-22-20_new-ffmpeg_ratio-not-commented.zip
(873.48 KiB) Downloaded 3251 times
OK this definitely proves a problem with the pad argument for aspect ratio and subtitles, but may be a change in FFmpeg itself in a newer version.
You could try an older version say from 6 months ago and see if this is better. If it is you could keep trying the next versions till you see which one breaks it.
I opened an issue on Github last week about this so hopefully this can be looked into a bit more and fixed.
Did you try to play videos that don't play again to see if it works the second time when having subtitles enabled but that option in the conf commented out?
This would prove the caching problem if it works the second time.
I think the issue has something to do with forced internal subtitle and UMS is ignoring all the other subs but this and it could be causing conflicts.
In this post they mentioned that only the first subtitle was showing in the transcode folder and I noticed the same thing looking into this and was able to replicate it.
These 2 videos are from the same series and have the same amout of subtitles except the forced ones in the first
With forced subs
TRACE 2024-09-17 18:27:23.327 [LibraryResource resolver thread 467-1] Adding Time Bandits S01E03 - Medieval (forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 0, Embedded, Default, Forced, title: Forced, lang: eng, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.328 [LibraryResource resolver thread 467-1] Adding Time Bandits S01E03 - Medieval (forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 0, Embedded, Default, Forced, title: Forced, lang: eng, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.328 [LibraryResource resolver thread 467-1] Adding Time Bandits S01E03 - Medieval (forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 0, Embedded, Default, Forced, title: Forced, lang: eng, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
No forced subs
TRACE 2024-09-17 18:27:23.333 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: -2147483648, Embedded, lang: null, type: UNKNOWN, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.334 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 2, Embedded, lang: ara, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.335 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 3, Embedded, lang: bul, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.335 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 4, Embedded, title: Simplified, lang: chi, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.336 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 5, Embedded, title: Traditional, lang: chi, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.337 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 6, Embedded, lang: cze, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.338 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 7, Embedded, lang: dan, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.339 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 26, Embedded, lang: dut, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.340 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 0, Embedded, lang: eng, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.340 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 1, Embedded, title: SDH, lang: eng, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.341 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 12, Embedded, lang: est, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.342 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 13, Embedded, lang: fin, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.343 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 14, Embedded, title: Canadian, lang: fre, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.344 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 15, Embedded, lang: fre, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.345 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 8, Embedded, lang: ger, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.345 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 9, Embedded, lang: gre, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.346 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 16, Embedded, lang: heb, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.347 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 17, Embedded, lang: hin, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.348 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 18, Embedded, lang: hun, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.348 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 19, Embedded, lang: ind, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.349 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 20, Embedded, lang: ita, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.350 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 21, Embedded, lang: jpn, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.351 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 22, Embedded, lang: kor, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.351 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 24, Embedded, lang: lav, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.352 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 23, Embedded, lang: lit, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.353 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 25, Embedded, lang: may, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.353 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 27, Embedded, lang: nor, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.354 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 28, Embedded, lang: pol, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.355 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 29, Embedded, lang: por, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.356 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 30, Embedded, title: Brazilian, lang: por, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.356 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 31, Embedded, lang: rus, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.357 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 32, Embedded, lang: slo, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.358 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 33, Embedded, lang: slv, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.359 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 10, Embedded, title: Latin American, lang: spa, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.359 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 11, Embedded, lang: spa, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.360 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 34, Embedded, lang: swe, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.361 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 35, Embedded, lang: tam, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.361 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 36, Embedded, lang: tel, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.362 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 37, Embedded, lang: tha, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.363 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 38, Embedded, lang: tur, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.364 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 39, Embedded, lang: ukr, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.364 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 41, Embedded, title: Traditional, lang: und, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.365 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 40, Embedded, lang: vie, type: SUBRIP, engine: FFmpeg Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.366 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: -2147483648, Embedded, lang: null, type: UNKNOWN, engine: AviSynth/FFmpeg (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.367 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: -2147483648, Embedded, lang: null, type: UNKNOWN, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.368 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 2, Embedded, lang: ara, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.368 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 3, Embedded, lang: bul, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.369 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 4, Embedded, title: Simplified, lang: chi, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.370 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 5, Embedded, title: Traditional, lang: chi, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.371 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 6, Embedded, lang: cze, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.372 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 7, Embedded, lang: dan, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.373 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 26, Embedded, lang: dut, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.377 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 0, Embedded, lang: eng, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.378 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 1, Embedded, title: SDH, lang: eng, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.379 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 12, Embedded, lang: est, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.379 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 13, Embedded, lang: fin, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.380 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 14, Embedded, title: Canadian, lang: fre, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.380 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 15, Embedded, lang: fre, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.381 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 8, Embedded, lang: ger, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.382 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 9, Embedded, lang: gre, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.383 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 16, Embedded, lang: heb, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.383 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 17, Embedded, lang: hin, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.384 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 18, Embedded, lang: hun, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.385 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 19, Embedded, lang: ind, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.385 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 20, Embedded, lang: ita, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.386 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 21, Embedded, lang: jpn, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.386 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 22, Embedded, lang: kor, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.387 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 24, Embedded, lang: lav, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.388 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 23, Embedded, lang: lit, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.388 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 25, Embedded, lang: may, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.389 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 27, Embedded, lang: nor, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.390 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 28, Embedded, lang: pol, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.391 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 29, Embedded, lang: por, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.391 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 30, Embedded, title: Brazilian, lang: por, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.392 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 31, Embedded, lang: rus, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.392 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 32, Embedded, lang: slo, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.393 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 33, Embedded, lang: slv, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.393 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 10, Embedded, title: Latin American, lang: spa, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.394 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 11, Embedded, lang: spa, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.394 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 34, Embedded, lang: swe, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.395 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 35, Embedded, lang: tam, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.396 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 36, Embedded, lang: tel, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.396 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 37, Embedded, lang: tha, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.397 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 38, Embedded, lang: tur, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.398 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 39, Embedded, lang: ukr, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.399 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 41, Embedded, title: Traditional, lang: und, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.400 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 40, Embedded, lang: vie, type: SUBRIP, engine: MEncoder Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.401 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: -2147483648, Embedded, lang: null, type: UNKNOWN, engine: AviSynth/MEncoder (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.402 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: -2147483648, Embedded, lang: null, type: UNKNOWN, engine: tsMuxeR Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.402 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: -2147483648, Embedded, lang: null, type: UNKNOWN, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.403 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 2, Embedded, lang: ara, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.404 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 3, Embedded, lang: bul, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.405 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 4, Embedded, title: Simplified, lang: chi, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.405 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 5, Embedded, title: Traditional, lang: chi, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.406 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 6, Embedded, lang: cze, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.407 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 7, Embedded, lang: dan, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.407 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 26, Embedded, lang: dut, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.408 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 0, Embedded, lang: eng, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.409 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 1, Embedded, title: SDH, lang: eng, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.409 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 12, Embedded, lang: est, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.410 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 13, Embedded, lang: fin, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.410 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 14, Embedded, title: Canadian, lang: fre, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.411 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 15, Embedded, lang: fre, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.412 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 8, Embedded, lang: ger, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.413 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 9, Embedded, lang: gre, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.413 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 16, Embedded, lang: heb, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.414 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 17, Embedded, lang: hin, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.414 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 18, Embedded, lang: hun, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.415 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 19, Embedded, lang: ind, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.416 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 20, Embedded, lang: ita, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.417 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 21, Embedded, lang: jpn, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.418 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 22, Embedded, lang: kor, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.418 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 24, Embedded, lang: lav, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.419 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 23, Embedded, lang: lit, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.420 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 25, Embedded, lang: may, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.422 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 27, Embedded, lang: nor, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.423 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 28, Embedded, lang: pol, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.424 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 29, Embedded, lang: por, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.425 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 30, Embedded, title: Brazilian, lang: por, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.425 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 31, Embedded, lang: rus, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.426 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 32, Embedded, lang: slo, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.427 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 33, Embedded, lang: slv, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.428 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 10, Embedded, title: Latin American, lang: spa, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.429 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 11, Embedded, lang: spa, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.430 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 34, Embedded, lang: swe, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.431 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 35, Embedded, lang: tam, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.432 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 36, Embedded, lang: tel, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.433 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 37, Embedded, lang: tha, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.434 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 38, Embedded, lang: tur, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.435 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 39, Embedded, lang: ukr, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.435 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 41, Embedded, title: Traditional, lang: und, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
TRACE 2024-09-17 18:27:23.436 [LibraryResource resolver thread 467-2] Adding Time Bandits S01E10 - Fortress Of Darkness (no forced subs).mkv: audio: Audio Id: 0, Language Code: eng, Codec: Enhanced AC-3, Stream Order: 1, Bitrate: 768000, Channels: 6, Sample Frequency: 48000 Hz, subtitle: Id: 40, Embedded, lang: vie, type: SUBRIP, engine: VLC Video (MPEGTS-H264-AC3)
Strangely when I moved the 2 videos to a new folder and renamed them to do some testing I did not have a problem playing the one that was giving me problems before.
This makes me think that something had changed in the database that had stopped them from working and moving them to a new folder made them new to UMS so there were rescanned. This may also the be why this is affecting both FFmpeg and Mencoder.
There is still that issue with the pad option when using KeepAspectRatioTranscoding in the latest version of FFmpeg.
ums_dbg_2024-09-17-18-32.zip
(218.58 KiB) Downloaded 3283 times
Re: Issues with transcoding with FFmpeg and MEncoder
The pad problem has been fixed now, and maybe that combined with moving the file so it is rescanned is enough? I will upload a test version
I sent a private message with the build to test
I'm marking this as fixed, I think we got it
