MEDE8ER ???
Re: MEDE8ER ???
thanx wolfgang....you make it so too easy to be true ! Never though to use that renderer....BlackBerryPlayBook-KalemSoftMP ?? you did that one a year ago right ?
always based myself on ps3 or realtek
would have loved if you did that for me as i suppose it would be quick for ya, guess your are busy...
i will give it another shot
and yes the MEde8er is the device that accepts the most formats out there, it natively plays every single codec aside from FLV, HEVC and some 10 bit encodes.... that is why i NEED to optimized UMS
i will
then send it over to their forums and make many people happy i guess !
i will
- SharkHunter
- Developer
Re: MEDE8ER ???
SO does it work now? If so pls either make a pull request with you new render conf file on git hub. Or simply upload it here and we'll include it in future releases.
Re: MEDE8ER ???
shark ! speaking with a legend am i not ?
thanx for the interest....well i still did not have time to test and do what WOLF suggested....give me 48h
But i really don't wanna upload it before you have a look
should be very easy for you to approuve or not as the MED natively reads every single format
will keep you posted ! thanx again for the interest !
- SharkHunter
- Developer
Re: MEDE8ER ???
I don't know if I'm a legend but I been around for a while
. If you got a MED8ER and get it to work pls share your conf file with us. We don't have all the renders we support (that would be very expensive) but we do have a lot.
Re: MEDE8ER ???
Ohh, I didn't recall there was a RealTek profile already, i was answering remotely by memorynenito2k wrote:thanx wolfgang....you make it so too easy to be true ! Never though to use that renderer....BlackBerryPlayBook-KalemSoftMP ?? you did that one a year ago right ?![]()
always based myself on ps3 or realtek![]()
Just make sure UserAgentSearch=RealtekMediaCenter in the RealTek profile and that should work then (most likely the profile indicates to stream anything without transcoding as the renderer is very capable)
Re: MEDE8ER ???
great wolf ! make it much easier
please at the end of the conf file of the realtel there is StreamExtensions, i am adding the ones supported...what is the correct code/writing for DTS hd and dolby true hd ????
Re: MEDE8ER ???
ok WOLF did as you said....and tested....
seems ok but i have one question to you and SHARK !
if my player is compatible natively with external subs, must i still encode it with ffmpeg/mencoder ???
anyway for now quite happy with UMS+Mede8er i tested
720p mkv
1080p mkv
SD 480p
and 720p/1080p HEVC encoded @24hz , @50hz & @60hz in AC3 : AND IT WORKED great !
Seems Subjunk did incredible improvements on the implementation of HEVC
will upload the conf file SHARK, BUT it seems to me it is incomplete and not accurate. Please have a look when later
EDIT: attached the conf file....i really dunno if i did even changed anything really; as i don't even know how to put the icon
hope it helps even a little WOLF
720p mkv
1080p mkv
SD 480p
Mede8er test.conf
- (3.38 KiB) Downloaded 914 times
Re: MEDE8ER ???
nenito2k have you read the PS3.conf which serve as a guide for customizing renderers .conf? At the end of that file is written so add the line and test it. Hopefully it may work if Realtek media center support them. Eventually you can try
# SupportedSubtitlesType: Comma-separated list of text-based subtitle formats
# supported by the renderer for streaming together with streaming (not transcoded) video.
# Supported formats: File extension:
# SUBRIP .srt
# ASS .ass or.ssa
# TEXT .txt
# MICRODVD .sub
# E.g. "SupportedSubtitlesType = SUBRIP,ASS,MICRODVD"
# SupportedSubtitlesType =
# UseClosedCaption: Some renderers use the "sec:CaptionInfoEx" parameter to
# stream external subtitles.
# Supported subtitles are defined in SupportedSubtitlesType.
# Default value is false.
UseClosedCaption =
UseClosedCaption = true
Re: MEDE8ER ???
thanx for the interest....but i have no clue where to add the info !!! bear in mind that i used the REALTEK conf file, as suggested by WOLF (and it was much easier for me -unlike PS3 - to understand !!!!!
On top? at the end ?
in between lines ? do i leave a blank space ? how much blank etc....really i am lost...
Can you just give me a hand ?!! use the conf file just above and upload another one modified by you.
please....and i will test it
Here are the subtitle files the Mede8er supports:
.pgs,
.srt,
.ssa,
.ass,
.smi, .idx +
.sub, (bluray)
.sup (DVD)
.txt
.pgs,
.srt,
.ssa,
.ass,
.smi, .idx +
.sub, (bluray)
.sup (DVD)
.txt
