Connection errors with Roku 3
Re: [solved]Connection errors with Roku 3
I'm sorry but this configuration isn't actually working still. My Roku 2 2720X-b is being detected as a Roku 3 (NSP 5) now, but it will still not render videos. They get stuck at retrieving on Roku Media Player as they did before. I'll look at the debug log again tomorrow.
Maybe the last log wasn't complete because the video playback didn't stop in the trace log.
I recreated the glitch and waited for the trace log to say playback had ended. These are the only relevant lines I noticed.
and
and
Is there a good test video I could try? I know the video is failing to render but despite that the audio renderer should work since I've been able to play mp3s or are separate audio files handled completely differently than audio tracks?
DEBUG 2015-11-22 13:35:23.048 [New I/O worker #7] Matched media renderer "Roku 3 (NSP 5)" based on address /192.168.1.5
TRACE 2015-11-22 13:35:23.048 [New I/O worker #7] Received on socket: Host: 192.168.1.150:7001
TRACE 2015-11-22 13:35:23.048 [New I/O worker #7] Received on socket: Accept: */*
TRACE 2015-11-22 13:35:23.048 [New I/O worker #7] Received on socket: user-agent: Roku/DVP-5.6
TRACE 2015-11-22 13:35:23.048 [New I/O worker #7] Received on socket: SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
TRACE 2015-11-22 13:35:23.048 [New I/O worker #7] Received on socket: CONTENT-TYPE: text/xml ; charset="utf-8"
TRACE 2015-11-22 13:35:23.048 [New I/O worker #7] Received on socket: Content-Length: 743
TRACE 2015-11-22 13:35:23.049 [New I/O worker #7] HTTP User-Agent: Roku/DVP-5.6
TRACE 2015-11-22 13:35:23.049 [New I/O worker #7] Recognized media renderer: Roku 3 (NSP 5)
TRACE 2015-11-22 13:35:23.049 [New I/O worker #7] HTTP: upnp/control/content_directory / 0-0
TRACE 2015-11-22 13:35:23.052 [New I/O worker #7] Could not match any format to "E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\RARBG.com.txt"
TRACE 2015-11-22 13:35:23.053 [New I/O worker #7] Matched format MPG to "E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4"
TRACE 2015-11-22 13:35:23.161 [New I/O worker #7] Parsing results for file "Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4": container: mp4, bitrate: 1274140, size: 217986552, video tracks: 1, audio tracks: 1, video codec: h264, duration: 00:22:48.00, width: 720, height: 404, frame rate: 23.976, mime type: video/mp4, matrix coefficients: BT.709, attached fonts: false
Audio track id: 0, lang: und, audio codec: AAC, sample frequency:48000, number of channels: 2, bits per sample: 16
TRACE 2015-11-22 13:35:23.161 [New I/O worker #7] Adding new child "Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4" with class "net.pms.dlna.RealFile"
TRACE 2015-11-22 13:35:23.165 [New I/O worker #7] Getting player for resource "Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4"
TRACE 2015-11-22 13:35:23.165 [New I/O worker #7] Returning compatible player "FFmpeg"
TRACE 2015-11-22 13:35:23.165 [New I/O worker #7] This video does not have subtitles
TRACE 2015-11-22 13:35:23.165 [New I/O worker #7] Format "mp4" failed to match supported line f:mkv v:h264|mp4 a:aac|flac|lpcm|mp2|mp3 n:2 m:video/x-matroska
TRACE 2015-11-22 13:35:23.165 [New I/O worker #7] Format "mp4" failed to match supported line f:mov v:h264|mp4 a:aac|lpcm|mp2|mp3 n:2 m:video/quicktime
TRACE 2015-11-22 13:35:23.165 [New I/O worker #7] Matched support line f:mp4 v:h264|mp4 a:aac|lpcm|mp2|mp3 n:2 m:video/mp4
DEBUG 2015-11-22 13:35:23.165 [New I/O worker #7] Reading MaxVideoBitrateMbps: "24" (default: "")
TRACE 2015-11-22 13:35:23.165 [New I/O worker #7] Final verdict: "Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4" will be streamed
TRACE 2015-11-22 13:35:23.165 [New I/O worker #7] File "Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4" will be sent with MIME type "video/mp4"
DEBUG 2015-11-22 13:35:23.165 [New I/O worker #7] Reading hide_transcode_folder: true (default: false)
TRACE 2015-11-22 13:35:23.166 [New I/O worker #7] Could not match any format to "E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\rick.and.morty.s02e01.hdtv.x264-batv.nfo"
TRACE 2015-11-22 13:35:23.167 [New I/O worker #7] Could not match any format to "E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\rick.and.morty.s02e01.hdtv.x264-batv.nfo"
TRACE 2015-11-22 13:35:23.168 [New I/O worker #7] End of analysis for E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]
TRACE 2015-11-22 13:35:23.168 [New I/O worker #7] Not setting subsAreValidForStreaming and it is false for Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4
DEBUG 2015-11-22 13:35:23.168 [New I/O worker #7] Reading prettify_filenames: true (default: false)
TRACE 2015-11-22 13:35:23.169 [New I/O worker #7] Network debugger: "Resume: Rick and Morty - 201" http-get:*:video/mp4:DLNA.ORG_OP=01 size=217986552 duration=00:22:48.00 http://192.168.1.150:7001/get/49/Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4
TRACE 2015-11-22 13:35:23.169 [New I/O worker #7] Not setting subsAreValidForStreaming and it is false for Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4
TRACE 2015-11-22 13:35:23.170 [New I/O worker #7] Network debugger: "Rick and Morty - 201" http-get:*:video/mp4:DLNA.ORG_OP=01 size=217986552 duration=00:22:48.00 http://192.168.1.150:7001/get/50/Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4
TRACE 2015-11-22 13:35:23.170 [New I/O worker #7] <?xml version="1.0" encoding="utf-8"?>
DEBUG 2015-11-22 13:35:23.742 [New I/O worker #1] Matched media renderer "Roku 3 (NSP 5)" based on address /192.168.1.5
TRACE 2015-11-22 13:35:23.742 [New I/O worker #1] Received on socket: Host: 192.168.1.150:7001
TRACE 2015-11-22 13:35:23.742 [New I/O worker #1] Received on socket: User-Agent: Roku/DVP-7.0 (067.00E09021A)
TRACE 2015-11-22 13:35:23.742 [New I/O worker #1] HTTP User-Agent: Roku/DVP-7.0 (067.00E09021A)
TRACE 2015-11-22 13:35:23.742 [New I/O worker #1] Recognized media renderer: Roku 3 (NSP 5)
TRACE 2015-11-22 13:35:23.742 [New I/O worker #1] HTTP: get/49/thumbnail0000Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4 / 0-0
DEBUG 2015-11-22 13:35:23.744 [New I/O worker #1] Starting C:\Program Files (x86)\Universal Media Server\win32\mplayer.exe -ss 328 -quiet E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4 -msglevel all=4 -vf scale=320:-2,expand=:180 -frames 1 -vo jpeg:outdir=mplayer_thumbs:subdirs="33507784" -nosound
DEBUG 2015-11-22 13:35:23.762 [mplayer.exe-6-1] MPlayer SB64-UMS (C) 2000-2015 MPlayer Team
DEBUG 2015-11-22 13:35:23.762 [mplayer.exe-6-1] Custom build by SubJunk, http://www.spirton.com
DEBUG 2015-11-22 13:35:23.777 [mplayer.exe-7-1] MPlayer SB64-UMS (C) 2000-2015 MPlayer Team
DEBUG 2015-11-22 13:35:23.778 [mplayer.exe-7-1] Custom build by SubJunk, http://www.spirton.com
DEBUG 2015-11-22 13:35:23.870 [mplayer.exe-7-1] Scanning dir C:/Windows/fonts
DEBUG 2015-11-22 13:35:23.870 [mplayer.exe-6-1] Scanning dir C:/Windows/fonts
DEBUG 2015-11-22 13:35:23.870 [mplayer.exe-7-1] getch2: 6 can't get number of input events [disabling console input]
DEBUG 2015-11-22 13:35:23.870 [mplayer.exe-6-1] getch2: 6 can't get number of input events [disabling console input]
DEBUG 2015-11-22 13:35:23.870 [mplayer.exe-7-1] Playing E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4.
DEBUG 2015-11-22 13:35:23.870 [mplayer.exe-6-1] Playing E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4.
DEBUG 2015-11-22 13:35:23.874 [mplayer.exe-6-1] libavformat version 56.19.100 (internal)
DEBUG 2015-11-22 13:35:23.874 [mplayer.exe-7-1] libavformat version 56.19.100 (internal)
DEBUG 2015-11-22 13:35:23.886 [mplayer.exe-7-1] libavformat file format detected.
DEBUG 2015-11-22 13:35:23.886 [mplayer.exe-6-1] libavformat file format detected.
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-7-1] [lavf] stream 0: audio (aac), -aid 0, -alang und
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-6-1] [lavf] stream 0: audio (aac), -aid 0, -alang und
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-7-1] [lavf] stream 1: video (h264), -vid 0
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-7-1] VIDEO: [H264] 720x404 0bpp 23.976 fps 1141.1 kbps (139.3 kbyte/s)
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-7-1] Clip info:
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-6-1] [lavf] stream 1: video (h264), -vid 0
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-7-1] major_brand: isom
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-6-1] VIDEO: [H264] 720x404 0bpp 23.976 fps 1141.1 kbps (139.3 kbyte/s)
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-7-1] minor_version: 1
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-6-1] Clip info:
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-7-1] compatible_brands: isom
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-6-1] major_brand: isom
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-7-1] creation_time: 2015-07-27 04:07:32
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-6-1] minor_version: 1
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-7-1] Load subtitles in E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-6-1] compatible_brands: isom
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-6-1] creation_time: 2015-07-27 04:07:32
DEBUG 2015-11-22 13:35:23.913 [mplayer.exe-6-1] Load subtitles in E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\
DEBUG 2015-11-22 13:35:23.914 [mplayer.exe-6-1] jpeg: Progressive JPEG disabled.
DEBUG 2015-11-22 13:35:23.914 [mplayer.exe-7-1] jpeg: Progressive JPEG disabled.
DEBUG 2015-11-22 13:35:23.914 [mplayer.exe-6-1] jpeg: Baseline JPEG enabled.
DEBUG 2015-11-22 13:35:23.914 [mplayer.exe-7-1] jpeg: Baseline JPEG enabled.
DEBUG 2015-11-22 13:35:23.915 [mplayer.exe-6-1] Opening video filter: [expand h=180]
DEBUG 2015-11-22 13:35:23.915 [mplayer.exe-7-1] Opening video filter: [expand h=180]
DEBUG 2015-11-22 13:35:23.915 [mplayer.exe-7-1] Expand: -1 x 180, -1 ; -1, osd: 0, aspect: 0.000000, round: 1
DEBUG 2015-11-22 13:35:23.915 [mplayer.exe-6-1] Expand: -1 x 180, -1 ; -1, osd: 0, aspect: 0.000000, round: 1
DEBUG 2015-11-22 13:35:23.915 [mplayer.exe-7-1] Opening video filter: [scale w=320 h=-2]
DEBUG 2015-11-22 13:35:23.915 [mplayer.exe-6-1] Opening video filter: [scale w=320 h=-2]
DEBUG 2015-11-22 13:35:23.915 [mplayer.exe-6-1] ==========================================================================
DEBUG 2015-11-22 13:35:23.915 [mplayer.exe-7-1] ==========================================================================
DEBUG 2015-11-22 13:35:23.918 [mplayer.exe-7-1] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2015-11-22 13:35:23.918 [mplayer.exe-6-1] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2015-11-22 13:35:23.918 [mplayer.exe-7-1] libavcodec version 56.20.100 (internal)
DEBUG 2015-11-22 13:35:23.918 [mplayer.exe-6-1] libavcodec version 56.20.100 (internal)
DEBUG 2015-11-22 13:35:23.919 [mplayer.exe-7-1] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2015-11-22 13:35:23.919 [mplayer.exe-6-1] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2015-11-22 13:35:23.919 [mplayer.exe-7-1] ==========================================================================
DEBUG 2015-11-22 13:35:23.919 [mplayer.exe-7-1] Audio: no sound
DEBUG 2015-11-22 13:35:23.919 [mplayer.exe-7-1] Starting playback...
DEBUG 2015-11-22 13:35:23.919 [mplayer.exe-6-1] ==========================================================================
DEBUG 2015-11-22 13:35:23.919 [mplayer.exe-6-1] Audio: no sound
DEBUG 2015-11-22 13:35:23.919 [mplayer.exe-6-1] Starting playback...
DEBUG 2015-11-22 13:35:23.948 [mplayer.exe-7-1] Movie-Aspect is undefined - no prescaling applied.
DEBUG 2015-11-22 13:35:23.950 [mplayer.exe-7-1] [swscaler @ 01f3f5e0]bicubic scaler, from yuv420p to rgb24 using MMXEXT
DEBUG 2015-11-22 13:35:23.950 [mplayer.exe-7-1] VO: [jpeg] 320x180 => 320x180 RGB 24-bit
DEBUG 2015-11-22 13:35:23.951 [mplayer.exe-7-1] jpeg: output directory: mplayer_thumbs
DEBUG 2015-11-22 13:35:23.959 [mplayer.exe-7-1]
DEBUG 2015-11-22 13:35:23.959 [mplayer.exe-6-1] Movie-Aspect is undefined - no prescaling applied.
DEBUG 2015-11-22 13:35:23.960 [mplayer.exe-6-1] [swscaler @ 01f3f5e0]bicubic scaler, from yuv420p to rgb24 using MMXEXT
DEBUG 2015-11-22 13:35:23.960 [mplayer.exe-6-1] VO: [jpeg] 320x180 => 320x180 RGB 24-bit
DEBUG 2015-11-22 13:35:23.961 [mplayer.exe-6-1] jpeg: output directory: mplayer_thumbs
DEBUG 2015-11-22 13:35:23.968 [mplayer.exe-6-1]
DEBUG 2015-11-22 13:35:23.968 [mplayer.exe-7-1]
DEBUG 2015-11-22 13:35:23.968 [mplayer.exe-7-1] Exiting... (End of file)
DEBUG 2015-11-22 13:35:23.969 [mplayer.exe-6-1]
DEBUG 2015-11-22 13:35:23.969 [mplayer.exe-6-1] Exiting... (End of file)
DEBUG 2015-11-22 13:35:26.629 [New I/O worker #7] Matched media renderer "Roku 3 (NSP 5)" based on address /192.168.1.5
TRACE 2015-11-22 13:35:26.629 [New I/O worker #7] Received on socket: User-Agent: Roku/DVP-7.0 (067.00E09021A)
TRACE 2015-11-22 13:35:26.630 [New I/O worker #7] Received on socket: Host: 192.168.1.150:7001
TRACE 2015-11-22 13:35:26.630 [New I/O worker #7] Received on socket: Accept: */*
TRACE 2015-11-22 13:35:26.630 [New I/O worker #7] HTTP User-Agent: Roku/DVP-7.0 (067.00E09021A)
TRACE 2015-11-22 13:35:26.630 [New I/O worker #7] Recognized media renderer: Roku 3 (NSP 5)
TRACE 2015-11-22 13:35:26.630 [New I/O worker #7] HTTP: get/50/thumbnail0000Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4 / 0-0
DEBUG 2015-11-22 13:35:26.631 [New I/O worker #7] Starting C:\Program Files (x86)\Universal Media Server\win32\mplayer.exe -ss 4 -quiet E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4 -msglevel all=4 -vf scale=320:-2,expand=:180 -frames 1 -vo jpeg:outdir=mplayer_thumbs:subdirs="25733780" -nosound
DEBUG 2015-11-22 13:35:26.658 [mplayer.exe-8-1] MPlayer SB64-UMS (C) 2000-2015 MPlayer Team
DEBUG 2015-11-22 13:35:26.658 [mplayer.exe-8-1] Custom build by SubJunk, http://www.spirton.com
DEBUG 2015-11-22 13:35:26.715 [MPlayer Thumbnail Failsafe] Stopping process: mplayer.exe-6
DEBUG 2015-11-22 13:35:26.735 [mplayer.exe-8-1] Scanning dir C:/Windows/fonts
DEBUG 2015-11-22 13:35:26.735 [mplayer.exe-8-1] getch2: 6 can't get number of input events [disabling console input]
DEBUG 2015-11-22 13:35:26.735 [mplayer.exe-8-1] Playing E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\Rick.and.Morty.S02E01.HDTV.x264-BATV.mp4.
DEBUG 2015-11-22 13:35:26.736 [mplayer.exe-8-1] libavformat version 56.19.100 (internal)
DEBUG 2015-11-22 13:35:26.737 [mplayer.exe-8-1] libavformat file format detected.
DEBUG 2015-11-22 13:35:26.744 [MPlayer Thumbnail Failsafe] Stopping process: mplayer.exe-7
DEBUG 2015-11-22 13:35:26.753 [mplayer.exe-8-1] [lavf] stream 0: audio (aac), -aid 0, -alang und
DEBUG 2015-11-22 13:35:26.753 [mplayer.exe-8-1] [lavf] stream 1: video (h264), -vid 0
DEBUG 2015-11-22 13:35:26.753 [mplayer.exe-8-1] VIDEO: [H264] 720x404 0bpp 23.976 fps 1141.1 kbps (139.3 kbyte/s)
DEBUG 2015-11-22 13:35:26.753 [mplayer.exe-8-1] Clip info:
DEBUG 2015-11-22 13:35:26.753 [mplayer.exe-8-1] major_brand: isom
DEBUG 2015-11-22 13:35:26.753 [mplayer.exe-8-1] minor_version: 1
DEBUG 2015-11-22 13:35:26.753 [mplayer.exe-8-1] compatible_brands: isom
DEBUG 2015-11-22 13:35:26.753 [mplayer.exe-8-1] creation_time: 2015-07-27 04:07:32
DEBUG 2015-11-22 13:35:26.753 [mplayer.exe-8-1] Load subtitles in E:\Cartoons\Rick and Morty\Rick.and.Morty.S02E01.HDTV.x264-BATV[rarbg]\
DEBUG 2015-11-22 13:35:26.754 [mplayer.exe-8-1] jpeg: Progressive JPEG disabled.
DEBUG 2015-11-22 13:35:26.754 [mplayer.exe-8-1] jpeg: Baseline JPEG enabled.
DEBUG 2015-11-22 13:35:26.754 [mplayer.exe-8-1] Opening video filter: [expand h=180]
DEBUG 2015-11-22 13:35:26.754 [mplayer.exe-8-1] Expand: -1 x 180, -1 ; -1, osd: 0, aspect: 0.000000, round: 1
DEBUG 2015-11-22 13:35:26.754 [mplayer.exe-8-1] Opening video filter: [scale w=320 h=-2]
DEBUG 2015-11-22 13:35:26.754 [mplayer.exe-8-1] ==========================================================================
DEBUG 2015-11-22 13:35:26.754 [mplayer.exe-8-1] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2015-11-22 13:35:26.754 [mplayer.exe-8-1] libavcodec version 56.20.100 (internal)
DEBUG 2015-11-22 13:35:26.754 [mplayer.exe-8-1] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2015-11-22 13:35:26.755 [mplayer.exe-8-1] ==========================================================================
DEBUG 2015-11-22 13:35:26.755 [mplayer.exe-8-1] Audio: no sound
DEBUG 2015-11-22 13:35:26.755 [mplayer.exe-8-1] Starting playback...
DEBUG 2015-11-22 13:35:26.763 [mplayer.exe-8-1] Movie-Aspect is undefined - no prescaling applied.
DEBUG 2015-11-22 13:35:26.764 [mplayer.exe-8-1] [swscaler @ 01fbf5e0]bicubic scaler, from yuv420p to rgb24 using MMXEXT
DEBUG 2015-11-22 13:35:26.764 [mplayer.exe-8-1] VO: [jpeg] 320x180 => 320x180 RGB 24-bit
DEBUG 2015-11-22 13:35:26.764 [mplayer.exe-8-1] jpeg: output directory: mplayer_thumbs
DEBUG 2015-11-22 13:35:26.772 [mplayer.exe-8-1]
DEBUG 2015-11-22 13:35:26.773 [mplayer.exe-8-1]
DEBUG 2015-11-22 13:35:26.773 [mplayer.exe-8-1] Exiting... (End of file)
- (45.45 KiB) Downloaded 487 times
