Subfolder Recurse restrictions
Re: Subfolder Recurse restrictions
I can try to help, what is it that you don't understand about it?
DevlshOne
Post by DevlshOne »
My plan was to split the existing FList area into thrids, devote 2/3 to the regular folder list and 1/3 to the non-recursive folder list. I've got quite a bit of work done in message.properties and NavigationShareTab.java, already. I just can't seem to figure out where to expand the layout and then incorporate the new properties. I also thought that I would re-vamp the Navigation Tab while I was in there. I am attaching the work I've already done, including a sketch of what I'd like the new Navigation Tab to look like.
NonRecursive.zip
two files I have already edited
(11.5 KiB) Downloaded 1040 times
NewGUI-Sketch.rar
(235.18 KiB) Downloaded 1083 times
Server: WHS 2011 - AMD Athlon 2.8GHz {Black Edition} - 4GB PC2-6400 - 7TB
SELECT * FROM users WHERE clue IS NOT NULL; Results: 0 rows found
GO DAWGS! SEC East Champions, again!
DevlshOne
Post by DevlshOne »
Oh, and in particular, why do I keep seeing the '.flip' method being used in conjunction with the layout util? My understanding is that its only used for screen rotation orientations.
With regards to flip, it's used for languages that read right-to-left, like Arabic.
With regards to the code, there's some good stuff there like variable renaming, and then some stuff we won't keep too like formatting changes - I do need to write up a document on how this project's code is formatted.
So to do what you want with the columns I think you could just change the line:
recursiveFoldersPanelBuilder.add(pane, FormLayoutUtil.flip(cc.xyw(1, 5, 6), colSpec, orientation));
To something like:
recursiveFoldersPanelBuilder.add(pane, FormLayoutUtil.flip(cc.xyw(1, 5, 4), colSpec, orientation));
Then put your other one on the right.
However I think it would be much better to design it differently; have just one folder list, but put a checkbox next to each entry that is enabled by default, then if the user unticks it then it is non-recursive.
DevlshOne
Post by DevlshOne »
I agree about the single list with tick marks but then we're talking checkboxes inside the textarea and that's truly blowing my mind! LOL! Like I said, if someone can handle the GUI re-design and layout changes, I'll gladly continue to work the logic.
