Problem with subtitle characters
SharkHunter
Re: Problem with subtitle characters
Post by SharkHunter »
Have you tried to transcode the movie on the ES7000? I suspect that one of the samsungs are "smart enough" to use the srt file it self while the other gets it "burned" in by UMS. If that works I would suspect that the ES7000 don't like the code page the srt file is sent in (either UMS sneds it as UTF-8 when the ES7000 expects CP1254 or vice versa).
I just did "Save file" when the browser asked my and I got the srt file yes...
tanaytopac
Post by tanaytopac »
I'll try to transcode it. Should I change the line of SamsungAllShare.conf file
TranscodeExtensions=flv,wav
to:
TranscodeExtensions=flv,wav,mkv
and removing mkv from?
StreamExtensions=
Also it is weird that both ES7000 and ES5500 handles these Turkish characters correctly when playing the file from USB. It only happens when using DLNA.
tanaytopac
Changing the .conf file as described above didn't work. After changing it the video could not event start.
Any suggestions please :cry:
squadjot
Post by squadjot »
Does this work?
Homeland.S01E07.720p.HDTV.x264-AVS.zip
(20.53 KiB) Downloaded 544 times
squadjot
Post by squadjot »
Or this one?
(24.28 KiB) Downloaded 657 times
tanaytopac
I finally solved the problem with your last file and selecting the encoding as Turkish in my TV's settings solved the problem. God I haven't noticed there was a setting in TV before. Thanks for all your helps.
