Version 5.2.3 is released
decadentdave
Re: Version 5.2.3 is released
Post by decadentdave »
My Samsung BD-J5700 is not working with the Samsung CD renderer.
I get the following errors when trying to use this renderer:
13:05:47 INFO Media renderer was not recognized. Possible identifying HTTP headers:User-Agent: [BD] Samsung DLNADOC/1.50
13:05:59 ERROR External input stream instance is null... stopping process
13:05:59 ERROR There is no inputstream to return for 1.21 The Magic Mirror
13:06:09 WARN Sending kill -14 to the Unix process: 9159
13:06:09 WARN Sending kill -14 to the Unix process: 9164
I have tried every Samsung renderer in 5.2.3 and none of them will work with my player. I have to go all the way back to 5.0.1 using the Samsung Allshare.conf for it to work.
Tonne M
Post by Tonne M »
Isn't it possible to just put that working .conf file in the renderers folder of 5.2.3? That is what I did with my (modified) Panasonic_Viera.conf and it works just fine.
michaelt
Post by michaelt »
Video "Casino_Royale" UPC: 043396163362 aborts on startup with "Connection error: java.io.IOException" error. Data seems to be valid as it plays in a previewer and on the Blu-ray disc.
INFO  2015-10-11 11:01:30.679 [StartPlaying Event] Started playing Casino Royale.mkv on your TV-55C8000
TRACE 2015-10-11 11:01:30.679 [New I/O worker #13] Sent to socket: Content-Length: 32049638036
DEBUG 2015-10-11 11:01:30.679 [StartPlaying Event] The full filename of which is: /Users/umsmkv/aML/Video/Index/Blu-ray/Casino Royale.mkv and the address of the renderer is: 10.0.1.89
TRACE 2015-10-11 11:01:30.682 [New I/O worker #14] Opened request handler on socket /10.0.1.89:50794
TRACE 2015-10-11 11:01:30.682 [New I/O worker #14] Request: HTTP/1.0 : GET : get/34/Casino+Royale.mkv
DEBUG 2015-10-11 11:01:30.682 [New I/O worker #14] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-10-11 11:01:30.683 [New I/O worker #14] Received on socket: Range: bytes=0-
TRACE 2015-10-11 11:01:30.683 [New I/O worker #14] Received on socket: getcontentFeatures.dlna.org: 1
TRACE 2015-10-11 11:01:30.683 [New I/O worker #14] Received on socket: transferMode.dlna.org: Streaming
TRACE 2015-10-11 11:01:30.683 [New I/O worker #14] Received on socket: getMediaInfo.sec: 1
TRACE 2015-10-11 11:01:30.683 [New I/O worker #14] Received on socket: Host: 10.0.1.50:5001
TRACE 2015-10-11 11:01:30.683 [New I/O worker #14] Recognized media renderer: TV-55C8000
TRACE 2015-10-11 11:01:30.683 [New I/O worker #14] HTTP: get/34/Casino+Royale.mkv / 0--1
TRACE 2015-10-11 11:01:30.683 [New I/O worker #14] Asked stream chunk : TimeRange [start=null, end=null] of Casino Royale.mkv and player null
TRACE 2015-10-11 11:01:30.683 [New I/O worker #14] Did not send subtitle headers because dlna.getMediaSubtitle returned null
TRACE 2015-10-11 11:01:30.683 [New I/O worker #14] Sending 32049638036 bytes.
TRACE 2015-10-11 11:01:30.684 [New I/O worker #14] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2015-10-11 11:01:30.684 [New I/O worker #14] Sent to socket: Content-Type: video/avi
TRACE 2015-10-11 11:01:30.684 [New I/O worker #14] Sent to socket: Content-Range: bytes 0-32049638035/32049638036
TRACE 2015-10-11 11:01:30.685 [New I/O worker #14] Sent to socket: ContentFeatures.DLNA.ORG: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000
TRACE 2015-10-11 11:01:30.685 [New I/O worker #14] Sent to socket: Accept-Ranges: bytes
TRACE 2015-10-11 11:01:30.685 [New I/O worker #14] Sent to socket: Connection: keep-alive
TRACE 2015-10-11 11:01:30.685 [New I/O worker #14] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.2.3
TRACE 2015-10-11 11:01:30.685 [New I/O worker #14] Sent to socket: Content-Length: 32049638036
DEBUG 2015-10-11 11:01:30.696 [New I/O worker #14] Connection error: java.io.IOException: Connection reset by peer
DEBUG 2015-10-11 11:01:30.696 [New I/O worker #14] Premature end, stopping...
TRACE 2015-10-11 11:01:30.696 [New I/O worker #15] Opened request handler on socket /10.0.1.89:33394
TRACE 2015-10-11 11:01:30.697 [New I/O worker #15] Request: HTTP/1.0 : GET : get/34/Casino+Royale.mkv
DEBUG 2015-10-11 11:01:30.697 [New I/O worker #15] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-10-11 11:01:30.697 [New I/O worker #15] Received on socket: Range: bytes=32049438592-
TRACE 2015-10-11 11:01:30.697 [New I/O worker #15] Received on socket: getcontentFeatures.dlna.org: 1
TRACE 2015-10-11 11:01:30.697 [New I/O worker #15] Received on socket: transferMode.dlna.org: Streaming
TRACE 2015-10-11 11:01:30.697 [New I/O worker #15] Received on socket: Host: 10.0.1.50:5001
TRACE 2015-10-11 11:01:30.697 [New I/O worker #15] Recognized media renderer: TV-55C8000
TRACE 2015-10-11 11:01:30.697 [New I/O worker #15] HTTP: get/34/Casino+Royale.mkv / 32049438592--1
TRACE 2015-10-11 11:01:30.697 [New I/O worker #15] Asked stream chunk : ByteRange [start=32049438592, end=-1] of Casino Royale.mkv and player null
TRACE 2015-10-11 11:01:30.697 [New I/O worker #15] Did not send subtitle headers because dlna.getMediaSubtitle returned null
TRACE 2015-10-11 11:01:30.697 [New I/O worker #15] Sending 199444 bytes.
TRACE 2015-10-11 11:01:30.698 [New I/O worker #15] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2015-10-11 11:01:30.698 [New I/O worker #15] Sent to socket: Content-Type: video/avi
TRACE 2015-10-11 11:01:30.698 [New I/O worker #15] Sent to socket: Content-Range: bytes 32049438592-32049638035/32049638036
TRACE 2015-10-11 11:01:30.698 [New I/O worker #15] Sent to socket: ContentFeatures.DLNA.ORG: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000
TRACE 2015-10-11 11:01:30.698 [New I/O worker #15] Sent to socket: Accept-Ranges: bytes
TRACE 2015-10-11 11:01:30.698 [New I/O worker #15] Sent to socket: Connection: keep-alive
TRACE 2015-10-11 11:01:30.698 [New I/O worker #15] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.2.3
TRACE 2015-10-11 11:01:30.698 [New I/O worker #15] Sent to socket: Content-Length: 199444
TRACE 2015-10-11 11:01:30.761 [New I/O worker #16] Opened request handler on socket /10.0.1.89:55292
TRACE 2015-10-11 11:01:30.761 [New I/O worker #16] Request: HTTP/1.0 : GET : get/34/Casino+Royale.mkv
DEBUG 2015-10-11 11:01:30.761 [New I/O worker #16] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-10-11 11:01:30.761 [New I/O worker #16] Received on socket: Range: bytes=3883-
TRACE 2015-10-11 11:01:30.761 [New I/O worker #16] Received on socket: getcontentFeatures.dlna.org: 1
TRACE 2015-10-11 11:01:30.761 [New I/O worker #16] Received on socket: transferMode.dlna.org: Streaming
TRACE 2015-10-11 11:01:30.761 [New I/O worker #16] Received on socket: Host: 10.0.1.50:5001
TRACE 2015-10-11 11:01:30.761 [New I/O worker #16] Recognized media renderer: TV-55C8000
TRACE 2015-10-11 11:01:30.762 [New I/O worker #16] HTTP: get/34/Casino+Royale.mkv / 3883--1
TRACE 2015-10-11 11:01:30.762 [New I/O worker #16] Asked stream chunk : ByteRange [start=3883, end=-1] of Casino Royale.mkv and player null
TRACE 2015-10-11 11:01:30.762 [New I/O worker #16] Did not send subtitle headers because dlna.getMediaSubtitle returned null
TRACE 2015-10-11 11:01:30.762 [New I/O worker #16] Sending 32049634153 bytes.
TRACE 2015-10-11 11:01:30.763 [New I/O worker #16] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2015-10-11 11:01:30.763 [New I/O worker #16] Sent to socket: Content-Type: video/avi
TRACE 2015-10-11 11:01:30.763 [New I/O worker #16] Sent to socket: Content-Range: bytes 3883-32049638035/32049638036
TRACE 2015-10-11 11:01:30.763 [New I/O worker #16] Sent to socket: ContentFeatures.DLNA.ORG: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000
TRACE 2015-10-11 11:01:30.763 [New I/O worker #16] Sent to socket: Accept-Ranges: bytes
TRACE 2015-10-11 11:01:30.763 [New I/O worker #16] Sent to socket: Connection: keep-alive
TRACE 2015-10-11 11:01:30.763 [New I/O worker #16] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.2.3
TRACE 2015-10-11 11:01:30.763 [New I/O worker #16] Sent to socket: Content-Length: 32049634153
DEBUG 2015-10-11 11:01:30.904 [New I/O worker #16] Connection error: java.io.IOException: Connection reset by peer
DEBUG 2015-10-11 11:01:30.905 [New I/O worker #16] Premature end, stopping...
DEBUG 2015-10-11 11:01:34.909 [StopPlaying Event] Matched media renderer "TV-55C8000" based on address /10.0.1.89
INFO  2015-10-11 11:01:34.909 [StopPlaying Event] Stopped playing Casino Royale.mkv on your TV-55C8000
DEBUG 2015-10-11 11:01:34.910 [StopPlaying Event] The full filename of which is: /Users/umsmkv/aML/Video/Index/Blu-ray/Casino Royale.mkv and the address of the renderer is: 10.0.1.89
TRACE 2015-10-11 11:01:56.001 [UPNPHelper] Receiving a M-SEARCH from [10.0.1.89:1025]
DEBUG 2015-10-11 11:01:56.004 [cling-18] Subscription cancelled: RenderingControl on uuid:3a3e65ac-abf0-4e93-5488-d2f1c2b5ef41: DEVICE_WAS_REMOVED
DEBUG 2015-10-11 11:01:56.004 [cling-20] Subscription cancelled: ConnectionManager on uuid:3a3e65ac-abf0-4e93-5488-d2f1c2b5ef41: DEVICE_WAS_REMOVED
DEBUG 2015-10-11 11:01:56.004 [cling-21] Subscription cancelled: AVTransport on uuid:3a3e65ac-abf0-4e93-5488-d2f1c2b5ef41: DEVICE_WAS_REMOVED
DEBUG 2015-10-11 11:01:56.005 [cling-20] TV-55C8000 is now offline.
See viewtopic.php?f=11&t=4148#p18553 for full details.
. . . . and a few others.
Samsung UN55C8000
decadentdave
Tonne M wrote:Isn't it possible to just put that working .conf file in the renderers folder of 5.2.3? That is what I did with my (modified) Panasonic_Viera.conf and it works just fine.
How do I do this? I have no way to access the hidden folders.
michaelt
Post by michaelt »
decadentdave wrote:How do I do this? I have no way to access the hidden folders.
Sure you do: unhide them.
In an iTerm (Terminal) window cut & paste or type:
 chflags hidden ~/Library
Then you will find UMS.conf at:
~/Library/Application Support/UMS/UMS.conf
or Samsung-*.conf file at:
Universal Media Server.app/Contents/Resources/renderers/Samsung-*.conf
wherever you put UMS.
Samsung UN55C8000
decadentdave
Ok I was able to locate the hidden renderers folder and placed the old SamsungAllshare.conf file from 5.0.1 in it and restarted UMS and selected Samsung Allshare as the renderer under the General Configuration menu and restarted again. The good news is that it seems to be working with my BD player now, but it does not detect any renderer on the blank Status tab. Anyways, I think it's important to definitely include the Samsung Allshare.conf file in the renderers folder for future updates as this is the only .conf that actually works with my model Samsung.
bcip
Post by bcip »
i had a lot of movies in which i couldn't search thru the movie (to start from min '30...or something like this) because it's shows 999.999 at the movie length. on my PC i had no problems with these movies, only when i tried to watch them on my TV. was this resolved in this update?
michaelt
Post by michaelt »
This is not an isolated problem.
There are a total of nine Titles aborting the same way:
  • 3:10 To Yuma
    Casino Royale
    Crank
    Departed
    Ghost Rider
    Hellboy
    No Country For Old Men
    Tears Of The Sun
    Terminator
Have Logs & UPC's if needed.
Samsung UN55C8000
  • 3:10 To Yuma
    Casino Royale
    Crank
    Departed
    Ghost Rider
    Hellboy
    Tears Of The Sun
    Terminator
Did they work on a previous version?
decadentdave wrote:Ok I was able to locate the hidden renderers folder and placed the old SamsungAllshare.conf file from 5.0.1 in it and restarted UMS and selected Samsung Allshare as the renderer under the General Configuration menu and restarted again. The good news is that it seems to be working with my BD player now, but it does not detect any renderer on the blank Status tab. Anyways, I think it's important to definitely include the Samsung Allshare.conf file in the renderers folder for future updates as this is the only .conf that actually works with my model Samsung.
SamsungAllShare.conf was removed in UMS 4.2.1, so is the version that works for you from 4.2.0? If you can start a thread in the help forum you can attach the config that works for you and we can look at adding a modified version for your device. Logs would also be useful to help us know how best to identify your device.
