Another Java Exception 2.2.0
Re: Another Java Exception 2.2.0
Does not work on my roommate's Sharp Aquos. I select the movie, shows the screen where I have to wait a second or two for it to start, then it goes back to the selection menu. I included the debug files. I have to revert back to 2.1.2 (the last version that worked).
- (28.28 KiB) Downloaded 693 times
That last debug log is from version 2.2.5, please attach one for 2.3.0 and 2.1.2 so I can compare them
Lol, my bad. Here are the proper ones. Thanks a lot!
- ums_dbg.2.3.0.zip
- Debug from 2.3.0 of it not working
- (14.44 KiB) Downloaded 648 times
- ums_dbg.2.1.2.zip
- Debug from 2.1.2 of it working and manually stopping
- (14.41 KiB) Downloaded 694 times
Any thoughts?
2.4.0 is out. Time to upgrade.orgon3 wrote:Any thoughts?
Well, my issue wasn't listed under the changelog. I will go through the trouble of upgrading and see if it works. I just hate installing a new version, then reverting back to the older ones over and over again.kuroukage wrote:2.4.0 is out. Time to upgrade.orgon3 wrote:Any thoughts?
Well, the Java Exception has been fixed. I am on Java 7u13 and there are no Java errors in 2.4.0. However, my roommate's TV still does not work with 2.4.0 (or anything above 2.1.2). The 2.1.2 and 2.3.0 debug files are above, and included here are the 2.4.0 ones.SubJunk wrote:That last debug log is from version 2.2.5, please attach one for 2.3.0 and 2.1.2 so I can compare them
To refresh your memory, when selecting a file, it goes to start it, but then backs out back to the menu, and never actually plays.
- ums_dbg.2.4.0.zip
- Sharp Aquos not playing the files
- (16.15 KiB) Downloaded 789 times
Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DLNADOC/1.50 SHARP-AQUOS-DMP/1.1W
Try to force e.g. PS3 as a default renderer (in General configuration tab) and restart UMS.
Your tv should be recognized as PS3. Try to play file. Works?
Post new debug.zip in TRACE mode/level to help further.
I've made a renderer for Sharp Aquos TVs based on the manual. Please test this version: http://www.spirton.com/uploads/UMS/UMS-sharpaquos.exe
Thanks so much! So far it works just great! I tested it using a few different MKVs. Thanks again SubJunk!SubJunk wrote:I've made a renderer for Sharp Aquos TVs based on the manual. Please test this version: http://www.spirton.com/uploads/UMS/UMS-sharpaquos.exe
