update to Panasonic.conf
zzricezz
Re: update to Panasonic.conf
Post by zzricezz »
For another issue, i watch a lot of RMVB videos and when it transcode the video and audio is always 3-4 seconds out of sync. Any advise how I can fix this?
watching the same RMVB files on my Pioneer Kuro TV doesn't have this issue so I don't think it is my computer is not transcode fast enough.
ums_dbg rmvb.zip
(17.24 KiB) Downloaded 835 times
ExSport
Post by ExSport »
zzricezz wrote:I have turn on TRACE and used x-divx and x-msvideo but still the same problem.
In log there is no info that you tried to play AVI file. Also how you changed x-divx and x-msvideo when in zip is only one log?
You need to edit Panasonic.conf file and restart UMS (not from UMS GUI!), make log - backup it, again change conf file and restart UMS. Make log and upload both.
It seems you don't know exactly what we need to test and exactly how so please attach also changed Panasonic conf file with every debug.log so we can check if you changed what should be changed and in right way.
Many thanks!
zzricezz
Post by zzricezz »
as i mention with qpel:yes|no i see a ! on the file and when i press play it doesn't capture in the log.
here is the log of me trying to play hurt locker.avi using x-msvideo
http://i187.photobucket.com/albums/x7/z ... 190941.jpg
also uploaded the log for x-divx but same thing as the above screen shot.
ums debug x-divx.zip
(25.91 KiB) Downloaded 960 times
ums debug msvideo.zip
(29.11 KiB) Downloaded 783 times
ExSport
Post by ExSport »
We both lost the time 8-)
I hate big companies.Don't understand why they removed(didn't implemented) XVID/DivX (AVI) support totally :roll:
From official site:
AVCHD 3D / Progressive, SD-VIDEO / MotionJPEG (Lumix) / MKV / MP4 / MOV / M4v / FLV / 3GPP / VRO / VOB / TS / PS, MP3 / AAC / FLAC, JPEG / MPO
Check site 80:
http://service.us.panasonic.com/OPERMAN ... P_UT50.PDF
There is no DivX support so comment whole "Supported = f:avi|divx ....." with "#" sign.
UMS will then transcode these files to MPEG2 so it will be supported by your TV.
On the other hand, your TV supports MKV natively, so you can try changing this line in Panasonic conf:
StreamExtensions=mkv
It should stream MKV natively without using tsMuxeR for remuxing. Don't forget every change require UMS restart (restart not from GUI, you need stop and start UMS again)
Please can you also test something for us? At last remove Panasonic.conf file totally (rename .conf extension to .bak etc.) so UMS will log how TV is announced because it will be unknown:
Matched media renderer "Panasonic TV" based on header "User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50"
It will help us to tune "User-Agent" detection for different Panasonic models (but I think different models have same agent used so we can't make different renderer confs for different PanTVs :| )
Thx
zzricezz
Post by zzricezz »
thanks, finally working and loved the mkv setting.
attached is the file you requested.
btw anyway to help with rmvb audio/video out of sync issue?
ums_dbg panasonic unknown.zip
(5.6 KiB) Downloaded 842 times
zzricezz
Post by zzricezz »
what i notice for rmvb play back is the audio from my pioneer receiver would cut in and out causing the out of sync.
zzricezz
Post by zzricezz »
Attached is the working conf file with ExSport suggestion. If it can be included in the next release that would be great.
Panasonic.conf
(5.91 KiB) Downloaded 958 times
ExSport
Post by ExSport »
I don't have any RMVB files so can't help.
Your conf file should not be used globally because there are lot of Panasonic TV from 2010-2012 which supports AVI (DivX/XviD) but doesn't support MKV.
Your case is opposite so your "special" config file will not work well for majority of Panasonic TV users.
Unfortunately it seems your TV announces itself same way as other Panasonic TV so we can't differentiate different PanTV models:
INFO  2013-01-26 12:28:38.109 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50, X-PANASONIC-DMP-Profile: "", X-PANASONIC-Registration: VklFUkEgVVQ1MAAAAAAAAAAAAAAAAAAAAAA=
ExSport
Post by ExSport »
About the RMVB ask SubJunk. It seems there is no good support for this format and maybe "ffmpeg_MPGMUX.exe" is outdated.
Now I see this remuxer is not used for RM files???? I found MEncoder was used only and generated some errors:
DEBUG 2013-01-24 18:04:35.515 [Thread-20] MEncoder SB49 (C) 2000-2012 MPlayer Team
DEBUG 2013-01-24 18:04:35.515 [Thread-20] Custom build by SubJunk, http://www.spirton.com
DEBUG 2013-01-24 18:04:35.546 [Thread-20] success: format: 0 data: 0x0 - 0xe256d12
DEBUG 2013-01-24 18:04:35.546 [Thread-20] libavformat version 54.61.101 (internal)
DEBUG 2013-01-24 18:04:35.546 [Thread-20] REAL file format detected.
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Stream description: Audio Stream
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Stream mimetype: audio/x-pn-realaudio
DEBUG 2013-01-24 18:04:35.546 [Thread-20] [real] Audio stream found, -aid 0
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Stream description: Video Stream
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Stream mimetype: video/x-pn-realvideo
DEBUG 2013-01-24 18:04:35.546 [Thread-20] [real] Video stream found, -vid 1
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Stream mimetype: logical-fileinfo
DEBUG 2013-01-24 18:04:35.546 [Thread-20] VIDEO: [RV40] 512x384 24bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s)
DEBUG 2013-01-24 18:04:35.546 [Thread-20] [V] filefmt:11 fourcc:0x30345652 size:512x384 fps:25.000 ftime:=0.0400
DEBUG 2013-01-24 18:04:35.546 [Thread-20] ==========================================================================
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2013-01-24 18:04:35.546 [Thread-20] libavcodec version 54.89.100 (internal)
DEBUG 2013-01-24 18:04:35.546 [Thread-20] AUDIO: 44100 Hz, 2 ch, floatle, 32.0 kbit/1.14% (ratio: 4005->352800)
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Selected audio codec: [ffcook] afm: ffmpeg (FFmpeg COOK audio)
DEBUG 2013-01-24 18:04:35.546 [Thread-16] Result of \\.\pipe\mencoder1359068675187 : true
DEBUG 2013-01-24 18:04:35.562 [Thread-20] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Opening video filter: [expand osd=1]
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Opening video filter: [expand osd=1 aspect=16/9 round=4]
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 1.777778, round: 4
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Opening video filter: [softskip]
DEBUG 2013-01-24 18:04:35.562 [Thread-20] ==========================================================================
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Opening video decoder: [realvid] RealVideo decoder
DEBUG 2013-01-24 18:04:35.562 [Thread-19] Error loading dll
DEBUG 2013-01-24 18:04:35.562 [Thread-19] ERROR: Could not open required DirectShow codec drvc.dll.
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Read the RealVideo section of the DOCS!
DEBUG 2013-01-24 18:04:35.562 [Thread-20] VDecoder init failed :(
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Selected video codec: [rv40win] vfm: realvid (Win32 RealPlayer 9 RV40)
SubJunk?
zzricezz
Post by zzricezz »
ExSport wrote:I don't have any RMVB files so can't help.
Not sure which Panasonic tv support divx but I checked the LCD/LED 2012 and the 2011 Panasonic plasma and they have the same format as the 2012 plasma model.
ST30 (2011 plasma)
• SD-Video Files (SD-Video Standard Ver.1.3)
Modified data with a PC may not be displayed correctly.
• AVCHD Standard compatible files
• MotionJPEG files (taken with LUMIX)*
• MP4 files (Video codec H.264 | Audio codec MP3/AC-3/LPCM)
• MKV files (Video codec H.264 | Audio codec MP3/AC-3/LPCM)
• MPEG-2 PS files**
• MPEG-2 TS files**
TC-L47WT50 (2012 LED)
Media Player null / yes (SD Card/USB)
Support Format AVCHD 3D/Progressive, SD-VIDEO/MotionJPEG (Lumix)/MKV/MP4/MOV/M4v/FLV/3GPP/VRO/VOB/TS/PS, MP3/AAC/FLAC, JPEG/MPO
