Media Player/App on Samsung smart tv
fabio5000
Re: Media Player/App on Samsung smart tv
Post by fabio5000 »
Hi Valib,
I Attach the Debug files
(25.59 KiB) Downloaded 2078 times
valib
Post by valib »
fabio5000 wrote:Hi Valib,
Sorry but you set the TRACE mode too late and immediately packed the log. There are not useful info from the DLNA communication. Can you do it again? If you don't changed the log level from the last test it could be set to TRACE when UMS starts. Or when UMS is running pres the button "Create TRACE logs" which restarts UMS in the TRACE mode. Then let UMS working a little bit longer to be able to see the network traffic.
fabio5000
Post by fabio5000 »
Sorry for that
Now I opened UMS and the option was set to Trace
THanks again
ums_dbg1.zip
(30.18 KiB) Downloaded 2219 times
valib
Post by valib »
It seems to me that UMS is responding correctly so there could be something in the TV setting or I am lost. Maybe some other developers could help.
EDIT: can you try the Samsung-J.conf provided here viewtopic.php?f=5&t=4075 ?
fabio5000
Post by fabio5000 »
Didnt work Valid,
I got the file, but UMS continue not showing in the source or other location in the TV :-(
nade
Post by nade »
Hi!
I'm here also to find a soloution for the same problem. It appeared in this week, and as fabio5000 says, UMS shows that it has found the device (Samsung TV, F-series), but it doesn't appear in the tv-s source list. It also can't been seen in my phone's dlna app (MediaHouse).
I used ccleaner in a couple of days ago, maybe that could mess up or deleted something in/from the registry? Also there was java update in these days. I've tried to install a new version of UMS too, but still doesn't work, as it did for two years.
Please help.
edit:
it now works fine again :) , I don't know for sure why. :roll:
squadjot
Post by squadjot »
Press the Samsung Hub Button,when pressed, does your menu look like this?
If yes, you should choose the purple item called "My Content"
