Weekly - Bi-Weekly UMS "Beta" Builds
kuroukage
Re: Daily - Bi-Daily UMS "Beta" Builds
Post by kuroukage »
Is that change included in the new UMS builder? Or do you still have to manually add that .xom update so that it will build with 7?
黒影
Optimus_prime
Post by Optimus_prime »
Nope, it's now included as the default. Just delete the code directory and let it redownload it again and it should update
Also there was an issue with sourceforge, the correct files will be up now.
Should be at revision 2.5.0
kuroukage
Post by kuroukage »
So you have the absolute latest build up on your site now?
黒影
Optimus_prime
Yes the right files are on there now.
By the way we update our own changelog pretty regularly so you can get a pretty good idea of the unreleased changes from that :)
Optimus_prime
Thanks for the advice Subjunk,
I've noticed that today when i was going through git. I will take it from that :D
Keep the good work going
Thanks mate you too :)
Optimus_prime
New Build 24/02/13 out on Sourceforge Link
Updates:
Updated layout on the Transcoding Settings tab
Improved aspect ratio handling on Panasonic TVs
Enabled ASS/SSA subtitle support on Linux by default
Added language flags for Arabic, Croatian, Estonian, Latvian, Serbian and Vietnamese
Fixes some Sony Bravia Aspect Ratio Issues (Not all video combinations)
Adds Custom Video Filter Options
Updated Java to JRE 7
Optimus_prime
So whilst not really being able to post a new beta build of late (plus i think other's are using there own builds) there's one up on sourceforge for all to download
Changelog:
General:
Improved aspect ratio handling on Panasonic and Sony TVs
Now compiled with Java 7
The installer only tells Windows to run UMS at startup on new installs or if the user has specified it in UMS
The first of many code optimizations for Java 7
Added RTMP support to FFmpeg Web Video engine
Fixed fontconfig support on OS X
Renderers:
Added support for Netgear NeoTV
Added support for Telstra T-Box
Added support for Yamaha RX-3900
Improved support for Sony Blu-ray players
Languages:
Made languages more consistent with eachother
Updated Russian translation (thanks, Tianuchka!)
Changed default audio/subtitles language priority for English users, which:
Disables subtitles when audio is English, otherwise look for English subtitles, prioritizing external before internal subtitles
External Components:
Updated InterFrame to 2.5.0, which:
Improves scene-change detection
Minimizes artifacts
Updated Java Runtime Environment automatic downloader for Windows to 7u15, which:
Fixes serious security holes
Updated MediaInfo for Windows to 0.7.62
kuroukage
Post by kuroukage »
Thanks for continuing to post the betas with update info, OP. :)
黒影
Locked
