UMS Unable To Start
boss
Re: UMS Unable To Start
Post by boss »
I might have given you the wrong start command. I haven't used Debian Linux (perhaps others with Debian experience could help), but it looks as though your system uses systemctl.
I think the start command might be:
systemctl start /opt/ums/UMS.sh
and
systemctl stop /opt/ums/UMS.sh
But maybe you were already doing that.
I don't think your issues is a UMS issues as such and you will have better luck posting in a forum specific to Raspbian Jessie/Debian.
Hopefully you will get there in the end and I am sure you will be happy with UMS.
F1Fish
Post by F1Fish »
I believe this configuration of UMS came from this forum.
I am sorry the proper person is not sited.
I use a 2 server system,
1) File server
2) UMS server
I’ve used both Ubuntu 15, 16 and Debian 8. Ubuntu works best with my Sony BLU-RAY player.
I use UFW for a firewall, ports are listed below.
File server set up on the UMS system.
mkdir /home/Video
mkdir /home/Cinema
nano /etc/fstab
//10.0.69.34/Video /home/Video cifs username=user,password=passwd,iocharset=utf8,sec=ntlm  0  0
//10.0.69.34/Cinema /home/Cinema cifs username=user,password=passwd,iocharset=utf8,sec=ntlm  0  0
Check fstab
mount -a
df -h
ls -la /home
Ubuntu setup
Note Java 7 does not work with Ubuntu 16.04 Xenial
apt-get install software-properties-common
add-apt-repository ppa:webupd8team/java
apt-get update
apt-get install oracle-java7-installer
apt-get install oracle-java8-set-default
Debian Jessie 8 setup
sh -c 'echo "deb http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main" >> /etc/apt/sources.list'
sh -c 'echo "deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main" >> /etc/apt/sources.list'
apt-key adv --keyserver keyserver.ubuntu.com --recv-keys EEA14886
apt-get update
apt-get install oracle-java8-installer
Both systems.
apt-get install mediainfo dcraw vlc-nox mplayer2
Change the wget to reflect UMS version.
cd ~
wget https://sourceforge.net/projects/unimediaserver/files/Official%20Releases/Linux/UMS-6.4.0-Java8.tgz
tar xvzf UMS-6.4.0-Java8.tgz
ls -la
mv ums-6.4.0 /etc/ums
ls -la
rm UMS-6.0.0-b2.tgz
nano /etc/init.d/ums
ums_init.d
chmod +x /etc/init.d/ums
update-rc.d ums defaults
service ums start
nano /etc/ums/UMS.cred
nano /etc/ums/UMS.conf
These are my personal setting for the Sony and multiple drives.
prettify_filenames =true
folders =""
Change  Virtual Folders File
virtual_folders_file =VirtualFolders.conf
nano /etc/ums/VirtualFolders.conf
VirtualFolders.conf
Firewall ports
tcp 9001
tcp 5001
udp 1900
Remove WEB from menu
mv /etc/ums/WEB.conf /etc/ums/WEB.conf.bak
service ums restart
Good Luck!
VirtualFolders_conf.txt
(516 Bytes) Downloaded 803 times
ums_initd.txt
(4.48 KiB) Downloaded 818 times
beaksdale
Post by beaksdale »
Thanks for the replies.
I think I've managed to get the systemd setup though I'm still running into the initialization error. The first time I try and run it I get this:
sudo systemctl status ums
? ums.service - Universal Media Server
   Loaded: loaded (/etc/systemd/system/ums.service; enabled)
   Active: inactive (dead) since Fri 2016-07-29 12:03:16 BST; 34s ago
  Process: 369 ExecStart=/opt/ums/UMS.sh (code=exited, status=0/SUCCESS)
 Main PID: 369 (code=exited, status=0/SUCCESS)
Jul 29 12:03:15 flirc-pi UMS.sh[369]: 12:03:15,679 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.apache] to WARN
Jul 29 12:03:15 flirc-pi UMS.sh[369]: 12:03:15,681 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [httpclient.wire] to WARN
Jul 29 12:03:15 flirc-pi UMS.sh[369]: 12:03:15,683 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [fm.last.musicbrainz.coverart] to WARN
Jul 29 12:03:15 flirc-pi UMS.sh[369]: 12:03:15,684 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to DEBUG
Jul 29 12:03:15 flirc-pi UMS.sh[369]: 12:03:15,686 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [console] to Logger[ROOT]
Jul 29 12:03:15 flirc-pi UMS.sh[369]: 12:03:15,688 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [default.log] to Logger[ROOT]
Jul 29 12:03:15 flirc-pi UMS.sh[369]: 12:03:15,688 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
Jul 29 12:03:15 flirc-pi UMS.sh[369]: 12:03:15,690 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@6fa38a - Registering current configuration as safe fallback point
Jul 29 12:03:15 flirc-pi UMS.sh[369]: INFO  12:03:12.109 [main] Language not specified, defaulting to OS language.
Jul 29 12:03:16 flirc-pi UMS.sh[369]: ERROR 12:03:16.241 [main] A serious error occurred during Universal Media Server initialization: null
Which doesn't occur the second time I run it though in both cases it generates the same errors in the debug log file.
DEBUG 2016-07-29 12:05:25.820 [main] Base path set to file:///etc/ums/UMS.conf
DEBUG 2016-07-29 12:05:26.524 [main] FileName set to UMS.conf
DEBUG 2016-07-29 12:05:26.525 [main] Base path set to /etc/ums
INFO  2016-07-29 12:05:26.655 [main] Language not specified, defaulting to OS language.
DEBUG 2016-07-29 12:05:27.545 [main] Default logfile folder set to: /var/log/UMS/root
DEBUG 2016-07-29 12:05:29.778 [main] LogBack started with configuration file: /opt/ums-6.4.0/logback.headless.xml
DEBUG 2016-07-29 12:05:29.967 [main] Fri Jul 29 12:05:29 BST 2016
DEBUG 2016-07-29 12:05:29.972 [main] Reading cred.path: "/etc/ums/UMS.cred" (default: "")
DEBUG 2016-07-29 12:05:29.975 [main] PID file not found, cannot check for running process
DEBUG 2016-07-29 12:05:29.989 [main] Writing PID: 681
ERROR 2016-07-29 12:05:30.234 [main] A serious error occurred during Universal Media Server initialization: null
I'm not sure what to do without knowing what the error is that UMS is throwing
F1Fish
Post by F1Fish »
Are all your paths set right?
This one seems different because UMS ver. number.
your ums.conf file needs help
Shared folders
no quotes, the path should end with foward slash, and I skip the space after =
folders = "/media/Ultra/Audio\"
folders =/media/Ultra/Audio/
If this does not work can you post the set-up you used with with the os ver?
beaksdale
Post by beaksdale »
Thanks changed the conf file but no change and I checked the path but I've set it to /etc/ums which is linked to ums-6.4.0 so not sure, I've attached my set-up files.
setup.zip
(14.38 KiB) Downloaded 818 times
F1Fish
Post by F1Fish »
Could you post a link or set-up you used as reference to build your server.
Thank nyou
beaksdale
Post by beaksdale »
As I said in my first post it's a Raspberry Pi 2 running Raspbian Jessie in headless mode
F1Fish
Post by F1Fish »
I'm sorry,
The question is not the os build which comes headless or desktop, but most any linux system can run headless.
Did you roll your own UMS sever or follow someones example on setting this up?
beaksdale
Post by beaksdale »
Sure I know but just being clear. I followed a guide online first then the guide posted on here which was basically download, move and set link. I then replaced the init setup with a systemd setup but I can't get either working which I guess since I can't get the script to run manually anyway isn't that surprising (though you provide extra configuration information in running the script with both startup methods so not too sure on that).
F1Fish
Post by F1Fish »
If the system is just a media server, start over. Rebuild Debian use one of the UMS guides on this site.
If not, Remove UMS from the system, then use one of the guides.
