Nothing plays with Sony KD65-XD7505
AlGrenadine
Re: Nothing plays with Sony KD65-XD7505
Post by AlGrenadine »
No the first one doesn't display the correct length of the movie.
Second one (not the one from git) works better
AlGrenadine
My pleasure, thanks for your help :)
I'll try more things tomorrow with the 2nd conf
valib
Post by valib »
AlGrenadine your problem is somewhere else. Do you have any Chromecast renderer on your network or is your TV based on Android? UMS is confused by it and recognizes your TV as KD-65XD7505 but uses the Google-Android-Chromecast.conf. Please try to disable Android and Chromecast at the General Configuration tab Select renderers button and try to test it.
AlGrenadine
This tv is an Android tv yes. Nothing else on the network
valib
Post by valib »
That is why your media are not properly parsed and transcoded when it is not necessary because your TV is supporting them. Try what I suggested and please send the log.
AlGrenadine
valib wrote:That is why your media are not properly parsed and transcoded when it is not necessary because your TV is supporting them. Try what I suggested and please send the log.
Tried disabling Android and chromecast conf. Same results when trying to resume a play.
Attached logs
(45.33 KiB) Downloaded 905 times
AlGrenadine
Sami32 wrote:Could you send an other log while using the second renderer that i sended you ?
download/file.php?id=3561
I think it's the one I used in latest log posted
Sami32
Post by Sami32 »
I don't think so, as it use the default icon in your log and not the BraviaX icon used by the second renderer...
