Version 7.0.0-a1 released
Re: Version 7.0.0-a1 released
pipin wrote:Thanks guys for the release and all the best for you and this pretty little piece of software in the next year. :)
Did a quick testing after a clean install.
With a lot of shared folders with many files i got some java errors (out of memory) and ums did freeze.
I dropped some of the folders and now its working fine. Will add the rest gradually.
Thanks for reporting this pipin, can you please try http://www.universalmediaserver.com/upl ... f294e4.exe and let us know if it's any better for that issue?
erick diangilis
Post by erick diangilis »
thanks for this alfa 2 i've tested on the ps4 media player Works really good no disconnection and fixed the slowdown on my 1440p vídeos. :)
Madoka
Post by Madoka »
Tried the 7.0a2 on my PS3. Seems to be working ok so far,playing files. I know I sound like a broken record, but the subtitle icon bug is still in the 7.0 series.
pipin
Post by pipin »
Sure. Will do some testing the next days.
Regards,
Jens
erick diangilis
i have both java 8 update 122 b04 and 9 update 155 early acess is there any compatibility with 9 in this new alfa 7 or alfa 7-2 for 9 or still stuck on 8 or 7.
