[Solved] How do I turn off Resume
emoxam
Re: [Solved] How do I turn off Resume
Post by emoxam »
I've got some error there, how can i fix it ?
 Exception in thread "jupnp-stream-server-1" org.jupnp.transport.spi.InitializationException: Could not initialize NettyStreamServer: org.jboss.netty.channel.ChannelException: Failed to bind to: /192.168.1.2:5002
13:28:10 INFO  	at net.pms.network.mediaserver.jupnp.transport.impl.NettyStreamServer.run(NettyStreamServer.java:138)
13:28:10 INFO  	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
13:28:10 INFO  	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
13:28:10 INFO  	at java.base/java.lang.Thread.run(Unknown Source)
13:28:10 INFO  Caused by: org.jboss.netty.channel.ChannelException: Failed to bind to: /192.168.1.2:5002
13:28:10 INFO  	at org.jboss.netty.bootstrap.ServerBootstrap.bind(ServerBootstrap.java:272)
13:28:10 INFO  	at net.pms.network.mediaserver.jupnp.transport.impl.NettyStreamServer.run(NettyStreamServer.java:127)
13:28:10 INFO  	... 3 more
13:28:10 INFO  Caused by: java.net.BindException: Address already in use: bind
13:28:10 INFO  	at java.base/sun.nio.ch.Net.bind0(Native Method)
13:28:10 INFO  	at java.base/sun.nio.ch.Net.bind(Unknown Source)
13:28:10 INFO  	at java.base/sun.nio.ch.ServerSocketChannelImpl.netBind(Unknown Source)
13:28:10 INFO  	at java.base/sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
13:28:10 INFO  	at java.base/sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
13:28:10 INFO  	at org.jboss.netty.channel.socket.nio.NioServerBoss$RegisterTask.run(NioServerBoss.java:193)
13:28:10 INFO  	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.processTaskQueue(AbstractNioSelector.java:391)
13:28:10 INFO  	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:315)
13:28:10 INFO  	at org.jboss.netty.channel.socket.nio.NioServerBoss.run(NioServerBoss.java:42)
13:28:10 INFO  	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
13:28:10 INFO  	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
emoxam
Post by emoxam »
And this ones
13:32:46 INFO  Using the following UUID configured in UMS.conf: 384ab1cf-e3e4-4fc5-bf03-949519886ab5
13:32:47 INFO  Exception in thread "jupnp-stream-server-1" org.jupnp.transport.spi.InitializationException: Could not initialize NettyStreamServer: org.jboss.netty.channel.ChannelException: Failed to bind to: /192.168.1.2:5002
13:32:47 INFO  	at net.pms.network.mediaserver.jupnp.transport.impl.NettyStreamServer.run(NettyStreamServer.java:138)
13:32:47 INFO  	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
13:32:47 INFO  	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
13:32:47 INFO  	at java.base/java.lang.Thread.run(Unknown Source)
13:32:47 INFO  Caused by: org.jboss.netty.channel.ChannelException: Failed to bind to: /192.168.1.2:5002
13:32:47 INFO  	at org.jboss.netty.bootstrap.ServerBootstrap.bind(ServerBootstrap.java:272)
13:32:47 INFO  	at net.pms.network.mediaserver.jupnp.transport.impl.NettyStreamServer.run(NettyStreamServer.java:127)
13:32:47 INFO  	... 3 more
13:32:47 INFO  Caused by: java.net.BindException: Address already in use: bind
13:32:47 INFO  	at java.base/sun.nio.ch.Net.bind0(Native Method)
13:32:47 INFO  	at java.base/sun.nio.ch.Net.bind(Unknown Source)
13:32:47 INFO  	at java.base/sun.nio.ch.ServerSocketChannelImpl.netBind(Unknown Source)
13:32:47 INFO  	at java.base/sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
13:32:47 INFO  	at java.base/sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
13:32:47 INFO  	at org.jboss.netty.channel.socket.nio.NioServerBoss$RegisterTask.run(NioServerBoss.java:193)
13:32:47 INFO  	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.processTaskQueue(AbstractNioSelector.java:391)
13:32:47 INFO  	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:315)
13:32:47 INFO  	at org.jboss.netty.channel.socket.nio.NioServerBoss.run(NioServerBoss.java:42)
13:32:47 INFO  	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
13:32:47 INFO  	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
13:32:48 INFO  Universal Media Server is now available for renderers to find
13:32:48 INFO  Library scan completed in 0 seconds
No idea I will need to see the full logs for context. See the section in red above.
As far as I can see in that error the address is already in use. You may have UMS still running if you have just restarted it and the previous process has not fully shut down.
