Help us improve support for your devices
Re: Help us improve support for your devices
Hi I have a few questions about my device, that is not officially supported however it works out of the box with a few problems just using a standard Samsung config.
My TV is a TCL 43P1FS which supports a lot of different codecs including h265
I've attached the debug logs including the manually edited config file that I have been working with.
In the debug logs I have played a few different files that are presenting the following errors.
The problems I am getting though are as follows
- No seeking when file is transcoded - The TV doesn't allow it.
- Thumbnails don't show
- Subtitles work and different subtitle tracks can be selected however when I select no subtitle track in the TV options menu it still displays the last selected track insteasd of cancelling subtitles all together
- Subtitles also show ( &apos ) instead of just an ( ' ) for example "don't" will show as "don&apost"
- Playing most xvid encoded avi files without transcoding them causes the video framerate to look like it has been halved whilst the audio is still in sync, therefore I have to force transcode them which sucks because then I can't seek through the file.
- 10 bit x265 files play however there is artifacts all over the screen which I persume is because the inbuilt CODEC doesn't support 10 bit x265 files (Normal x265 files play fine). Is there a way to stream normal ones and transcode if they're 10 bit?
- 6.1 channel sound isn't supported by the TV... a message pops up saying unsupported audio.
Note: I have commented out a line in the TCL.config to force .avi files to stream as is (for testing purposes) - I usually uncomment that line so they will be transcoded so they aren't skipping.
Thankyou!
Thankyou!
- (48.72 KiB) Downloaded 1177 times
Afaik that should be default behavior, see comment by SubJunk about SupportedVideoBitDepths hereisaacTV wrote:- 10 bit x265 files play however there is artifacts all over the screen which I persume is because the inbuilt CODEC doesn't support 10 bit x265 files (Normal x265 files play fine). Is there a way to stream normal ones and transcode if they're 10 bit?
http://universalmediaserver.com/forum/v ... ths#p27354
You'll have to edit your Supported lines in your renderer configisaacTV wrote:- 6.1 channel sound isn't supported by the TV... a message pops up saying unsupported audio.
For an example this makes UMS transcode to stereo if there are more than sound 2 channels in any given wmv file.
Supported = f:wmv m:video/x-ms-wmv n:2
Hello I have troubles with videos on my Sony TV in the living room not always able to be played
Also i just brought a new samsung 2016 model for bedroom, I thought you might wanted to check support for all devices I added to the zip.
DLink-DSM510.conf = DCS-930LB1
http://www.dlink.com/uk/en/support/prod ... ork-camera
Samsung-CD.conf = UE55K5515
http://www.samsung.com/dk/consumer/tv-a ... K5515AKXXE
Sony-BraviaHX.conf = KDL-55HX753
http://www.sony.dk/support/da/product/KDL-55HX753
- (20.64 KiB) Downloaded 1044 times
I have a Hisense VIDAA TV. the model number is LED32EC320A. I send you the log file, if it takes too long, please teach me how can a create render file by myself. thanks in advance. PD: Sorry for my bad english
debug.log
- (47.13 KiB) Downloaded 1151 times
Can i use UMS without a router? I wanna hook up a cat6 line from my ps4 straight to my laptop, can i do that, and if so how? if this has been answered please forgive me... i have searched high and low for answer..
On Sony KD65-XD7505 (Android TV) :
I had it work once on a video then i tried fast forwarding... Now nothing plays even if i reboot UMS and the TV...
Here are the logs
Here are the logs
- (68.37 KiB) Downloaded 1012 times
Hi Algrenadine,
https://raw.githubusercontent.com/Unive ... viaXD.conf
But as told in this configuration file you'll need to add into your UMS.conf file placed in your UMS profile folder (not into the UMS.conf found in your Universal "Media Server" program folder).
Hoping that help.
If not don't hesitate to post a new log while using this new setting.
chromecast_extension=false
Hoping that help.
Is there a conf. file for the Yamaha rx a2050?
It is recognized as a sony xperia phone for some reason?
- (44.11 KiB) Downloaded 1088 times
Hi markoma,
try this configuration file: (place it in your "renderer" folder of your "Universal Media Server" program directory) Please, don't forget to give feedback
is there a config. file for the PS4 PRO ? UMS seems to recognize my ps4 pro like a normal PS4 si it thinks the max resolution is 1080x1920 instead of 2160x3840.
Thanks!
Thanks!
