update to Panasonic.conf
zzricezz
Re: update to Panasonic.conf
Post by zzricezz »
attached is the log of me playing the same RMVB file using my Pioneer Kuro tv and it has no issues at all. So I don't think it is a UMS problem but a conf problem?
ums_dbg kuro.zip
(29.99 KiB) Downloaded 820 times
ExSport
Post by ExSport »
I have one Plasma 3D and one LCD non-3D Viera TVs and both supports DivX. SubJunk has PanTV and also his one supports DivX. Trust me.
You are the first one who complains about AVI (DivX/XviD) files that they are not natively supported.
ExSport
Post by ExSport »
zzricezz wrote:attached is the log of me playing the same RMVB file using my Pioneer Kuro tv and it has no issues at all. So I don't think it is a UMS problem but a conf problem?
Only visible difference for me is that Kuro doesn't use bandwidth limiting and AspectRatio fix:
MaxVideoBitrateMbps=90
CustomMencoderOptions=-vf softskip,expand=::::1:16\/9:4
Try playing with these two lines in Panasonic.conf if it helps.
First try to change 90 to 0 and then add # before "CustomMencoderOptions=..." so it will be commented.
Don't forget, every change needs restart.
zzricezz
Post by zzricezz »
didnt work. I even tried copying all the setting from the kuro conf but still problem. looks like more of a Panasonic hardware issue now? which is odd cause there no problem transcoding divx.
ExSport wrote:About the RMVB ask SubJunk. It seems there is no good support for this format and maybe "ffmpeg_MPGMUX.exe" is outdated.
Now I see this remuxer is not used for RM files???? I found MEncoder was used only and generated some errors:
DEBUG 2013-01-24 18:04:35.515 [Thread-20] MEncoder SB49 (C) 2000-2012 MPlayer Team
DEBUG 2013-01-24 18:04:35.515 [Thread-20] Custom build by SubJunk, http://www.spirton.com
DEBUG 2013-01-24 18:04:35.546 [Thread-20] success: format: 0 data: 0x0 - 0xe256d12
DEBUG 2013-01-24 18:04:35.546 [Thread-20] libavformat version 54.61.101 (internal)
DEBUG 2013-01-24 18:04:35.546 [Thread-20] REAL file format detected.
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Stream description: Audio Stream
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Stream mimetype: audio/x-pn-realaudio
DEBUG 2013-01-24 18:04:35.546 [Thread-20] [real] Audio stream found, -aid 0
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Stream description: Video Stream
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Stream mimetype: video/x-pn-realvideo
DEBUG 2013-01-24 18:04:35.546 [Thread-20] [real] Video stream found, -vid 1
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Stream mimetype: logical-fileinfo
DEBUG 2013-01-24 18:04:35.546 [Thread-20] VIDEO: [RV40] 512x384 24bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s)
DEBUG 2013-01-24 18:04:35.546 [Thread-20] [V] filefmt:11 fourcc:0x30345652 size:512x384 fps:25.000 ftime:=0.0400
DEBUG 2013-01-24 18:04:35.546 [Thread-20] ==========================================================================
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2013-01-24 18:04:35.546 [Thread-20] libavcodec version 54.89.100 (internal)
DEBUG 2013-01-24 18:04:35.546 [Thread-20] AUDIO: 44100 Hz, 2 ch, floatle, 32.0 kbit/1.14% (ratio: 4005->352800)
DEBUG 2013-01-24 18:04:35.546 [Thread-20] Selected audio codec: [ffcook] afm: ffmpeg (FFmpeg COOK audio)
DEBUG 2013-01-24 18:04:35.546 [Thread-16] Result of \\.\pipe\mencoder1359068675187 : true
DEBUG 2013-01-24 18:04:35.562 [Thread-20] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Opening video filter: [expand osd=1]
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Opening video filter: [expand osd=1 aspect=16/9 round=4]
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 1.777778, round: 4
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Opening video filter: [softskip]
DEBUG 2013-01-24 18:04:35.562 [Thread-20] ==========================================================================
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Opening video decoder: [realvid] RealVideo decoder
DEBUG 2013-01-24 18:04:35.562 [Thread-19] Error loading dll
DEBUG 2013-01-24 18:04:35.562 [Thread-19] ERROR: Could not open required DirectShow codec drvc.dll.
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Read the RealVideo section of the DOCS!
DEBUG 2013-01-24 18:04:35.562 [Thread-20] VDecoder init failed :(
DEBUG 2013-01-24 18:04:35.562 [Thread-20] Selected video codec: [rv40win] vfm: realvid (Win32 RealPlayer 9 RV40)
SubJunk?
Does it work if you put the attached file (unzipped) into win32/codecs?
drvc.zip
(135.58 KiB) Downloaded 815 times
zzricezz
Post by zzricezz »
Don't have the error message anymore but the video and audio still out of sync :( could it be the error in bold?
DEBUG 2013-01-31 20:28:06.265 [StartPlaying Event] The full filename of which is: D:\shares\Videos\Drama\Chinese\TVB - Dicey Business\1.rmvb and the address of the renderer is: 192.168.0.184
DEBUG 2013-01-31 20:28:06.687 [Thread-20] MEncoder SB49 (C) 2000-2012 MPlayer Team
DEBUG 2013-01-31 20:28:06.687 [Thread-20] Custom build by SubJunk, http://www.spirton.com
DEBUG 2013-01-31 20:28:06.906 [Thread-20] success: format: 0  data: 0x0 - 0xe256d12
DEBUG 2013-01-31 20:28:06.953 [Thread-20] libavformat version 54.61.101 (internal)
DEBUG 2013-01-31 20:28:07.453 [Thread-20] REAL file format detected.
DEBUG 2013-01-31 20:28:07.468 [Thread-20] Stream description: Audio Stream
DEBUG 2013-01-31 20:28:07.468 [Thread-20] Stream mimetype: audio/x-pn-realaudio
DEBUG 2013-01-31 20:28:07.468 [Thread-20] [real] Audio stream found, -aid 0
DEBUG 2013-01-31 20:28:07.468 [Thread-20] Stream description: Video Stream
DEBUG 2013-01-31 20:28:07.468 [Thread-20] Stream mimetype: video/x-pn-realvideo
DEBUG 2013-01-31 20:28:07.468 [Thread-20] [real] Video stream found, -vid 1
DEBUG 2013-01-31 20:28:07.468 [Thread-20] Stream mimetype: logical-fileinfo
DEBUG 2013-01-31 20:28:07.515 [Thread-20] VIDEO:  [RV40]  512x384  24bpp  25.000 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2013-01-31 20:28:07.515 [Thread-20] [V] filefmt:11  fourcc:0x30345652  size:512x384  fps:25.000  ftime:=0.0400
DEBUG 2013-01-31 20:28:07.515 [Thread-20] ==========================================================================
DEBUG 2013-01-31 20:28:07.640 [Thread-20] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2013-01-31 20:28:07.640 [Thread-20] libavcodec version 54.89.100 (internal)
DEBUG 2013-01-31 20:28:08.015 [Thread-20] AUDIO: 44100 Hz, 2 ch, floatle, 32.0 kbit/1.14% (ratio: 4005->352800)
DEBUG 2013-01-31 20:28:08.015 [Thread-20] Selected audio codec: [ffcook] afm: ffmpeg (FFmpeg COOK audio)
DEBUG 2013-01-31 20:28:08.015 [Thread-20] ==========================================================================
DEBUG 2013-01-31 20:28:08.015 [Thread-16] Result of \\.\pipe\mencoder1359682085781 : true
DEBUG 2013-01-31 20:28:08.046 [Thread-20] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2013-01-31 20:28:08.078 [Thread-20] Opening video filter: [expand osd=1]
DEBUG 2013-01-31 20:28:08.109 [Thread-20] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
DEBUG 2013-01-31 20:28:08.109 [Thread-20] Opening video filter: [expand osd=1 aspect=16/9 round=4]
DEBUG 2013-01-31 20:28:08.109 [Thread-20] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 1.777778, round: 4
DEBUG 2013-01-31 20:28:08.109 [Thread-20] Opening video filter: [softskip]
DEBUG 2013-01-31 20:28:08.156 [Thread-20] ==========================================================================
DEBUG 2013-01-31 20:28:08.265 [Thread-20] Opening video decoder: [realvid] RealVideo decoder
DEBUG 2013-01-31 20:28:08.500 [Thread-20] Selected video codec: [rv3040win] vfm: realvid (Win32 RealPlayer 10 RV30/40)
DEBUG 2013-01-31 20:28:08.500 [Thread-20] ==========================================================================
[b]DEBUG 2013-01-31 20:28:08.578 [Thread-19] [ac3 @ 011b2b00]Channel layout not specified
DEBUG 2013-01-31 20:28:08.578 [Thread-19] [ac3 @ 011b2b00]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2013-01-31 20:28:08.656 [Thread-19] Limiting audio preload to 0.4s.
DEBUG 2013-01-31 20:28:08.656 [Thread-19] Increasing audio density to 4.[/b]
DEBUG 2013-01-31 20:28:08.765 [Thread-20] Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
DEBUG 2013-01-31 20:28:08.765 [Thread-20] videocodec: libavcodec (684x384 fourcc=3267706d [mpg2])
DEBUG 2013-01-31 20:28:08.765 [Thread-20] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2013-01-31 20:28:09.218 [Thread-19]
DEBUG 2013-01-31 20:28:09.218 [Thread-19] Skipping frame!
DEBUG 2013-01-31 20:28:09.234 [Thread-19]
DEBUG 2013-01-31 20:28:09.234 [Thread-19] Skipping frame!
DEBUG 2013-01-31 20:28:09.343 [Thread-20] Writing header...
DEBUG 2013-01-31 20:28:09.343 [Thread-20] INITV: 0.200, 0.160, fps: 25.000
DEBUG 2013-01-31 20:29:29.437 [New I/O server worker #1-1] Setting margin to 2Mb
Nope that's a normal message. It's probably just that the file format is so rare, I doubt the MEncoder developers even test it.
zzricezz
Post by zzricezz »
SubJunk wrote:Nope that's a normal message. It's probably just that the file format is so rare, I doubt the MEncoder developers even test it.
sigh rmvb is a very popular format for asian media.
I might be wrong but in my experience rmvb files are usually provided on forums whereas mkv (better format) are in torrents and fansub blogs. Usually when I see rmvb files they are a very low filesize alternative for people who want say an 80mb file instead of the 200mb MKV
Doxeng
Post by Doxeng »
:ugeek:
I have a very large collection of files in all formats and I had been playing with the panasonic.conf file, now I have very much every format streaming to a TC-P65ST50 Smart viera Panasonic.
Most files are natively supported by the TV set so no encoding is needed for JPEG, SD-Video, AVCHD, MP4, AVI, MKV, FLV, 3GPP, PS, TS, MPEG1, MPEG2, MP3, HE-AAC, and AC3 file
So, a bunch of things just commented out # in the .conf file, I have FFmpeg as first engine in the list for transcoding
Two issues remain with the file, when a video file audio portion is encoded to mpeg the playback has a delay of around 1.5 to 2 seconds. (it seems a lot of renderers have the same issue, however, using another media server I do have this issue
The DLNA client in the DLNA tv screen, also displays the resume files as part of the file list, so if you play partially 2 or 3 files, it creates 2 or 3 resume files in the list.
my .conf file is attached, a bit messy , very much all video formats play
Panasonic.conf
(7.04 KiB) Downloaded 900 times
