Channels Plugin
- SharkHunter
- Developer
Re: Channels Plugin
AlexanderGson - yeah it seems like viasat done some update which makes the channels unusable. It worked a month ago (sort of) so there has been a change lately. As always if I have time I'll have a look. The change is rather big they have removed the old xml files where you found the shows before.
- AlexanderGson
Re: Channels Plugin
Appreciate itSharkHunter wrote:AlexanderGson - yeah it seems like viasat done some update which makes the channels unusable. It worked a month ago (sort of) so there has been a change lately. As always if I have time I'll have a look. The change is rather big they have removed the old xml files where you found the shows before.
I think they changed it as they now have a android app as well which I think they got quite recently.
Re: Channels Plugin
Sorry about that, guys. It should be fixed nowSharkHunter wrote:Weird I'll need to ask SJ to have a look
Re: Channels Plugin
Looking forward to this.SharkHunter wrote:Yes I still support it. But it might come as a surprise that I do have a life and work that needs attending to from time to time. What can I say I use Channels each day (more or less) so it works for me.
I'll look over it again during the weekend.
Re: Channels Plugin
I'm curious to know (since no one reported a verification to the patch): Did you include this feature into the 2.22 plugin? If so, what is the syntax of the line to add to the renderer profile?SharkHunter wrote:Ok just pull the latest master and build (I know you canDeFlanko wrote:I got a Samsung as well as Optimus... he has a few too) and the try something containing a "/" and see that it's swapped to a ":".
What would be real nice to see if you see the error if you disable the CharMap. Just remove the line "CharMap=/ :" from the render conf file...
Edit: I just recognized that the native Samsung renderer profile of UMS 3.3.0 already included the line "CharMap=/ :" - so it's obviously in place. So I will test to remove my current patch in my .ch file and see if it still works. I'll come back with a report....
Pen
Re: Channels Plugin
Is there any chance that someone can do a channel for dreamfilm or swefilm? It would be great.
Re: Channels Plugin
I'm trying to use channels for watching you tube videos on xbox360 without paying gold subscription to M$.
Installed channels plugin with gui.
fixed pepy.zip won't unpack.
Did some changes to youtube.ch, but still can't get anything to play on xbox360.
It always opening, and then get 69-c00d36c4 error code.
Don't know where to look for error: in channels settings or ums settings?
For example here is log for trying to play ANNIE - Official Trailer - In Theaters Christmas 2014!, and Most Shocking Second a Day Video on your Xbox 360
In attachment are channel log, and debug log.
debug.log
- (22.65 KiB) Downloaded 1065 times
channel.log
- (144.27 KiB) Downloaded 971 times
Re: Channels Plugin
I installed the latest version of Universal Media Server and using the Plugin tab added the "Channels" Plugin.
But, when I try to access the "Channel" folder esp. the Icefilms channel, on any of my rendering machines I see the "Folders" of the TV Show and Movies. But, when I go inside it. It just shows "Add to Favorite" message and I am not able to see the Video Links or rather access any of the videos in any of the channels.
Please tell me what do I do to insure that it works?
Additional details is as below:
OS: Windows XP
UMS Verson: 3.6.1
Channel Plugin: 2.22
Rendering Devices: PS3, Android Phone.
OS: Windows XP
UMS Verson: 3.6.1
Re: Channels Plugin
Hi...
One thing i would be happy to see is an upgrade on the channel plugins, .. specially the swedish ones.
Many of them doesent work any more.. it seems... :/
/M
/M
- SharkHunter
- Developer
Re: Channels Plugin
balzac - IceFIlms haven't been updated for a while. Since MegaUpload died I tried some times to get it to work but the speed/quality of the fileshares has been well not viewable. Maybe it's time for a retake.
DualC - which ones doesn't work? Kanal5/9 works,SVTplay works, Tv4 works (at least yesterday), Tv3 haven't tried for ages so that might be dead.
Try clicking the "INstall upgrade channeles" in the GUI since I update the channel files from time to time
