[Solved] Playback 4K in LG TV
Re: [Solved] Playback 4K in LG TV
Are you using the config I posted?
I may have misinterpreted how some of the formats are written and I think the mpegps line is wrong
Supported = f:ts|trp|tp|mts   v:h264|h265|mpeg2                 a:mp3|ac3|eac3|aac-lc|he-aac|adpcm      m:video/vnd.dlna.mpeg-tts
Supported = f:mpegts          v:h264|h265|mpeg2                 a:mp3|ac3|eac3|aac-lc|he-aac|adpcm      m:video/vnd.dlna.mpeg-tts
should have been
Supported = f:mpegps          v:h264|h265|mpeg2                 a:mp3|ac3|eac3|aac-lc|he-aac|adpcm      m:video/vnd.dlna.mpeg-tts
I think :?:
I don't really know what the ps and ts means though :?
could you post the whole trace log though, the snippet you posted doesn't quite give the full picture.
@azraraktar Your setup looks correct for the file you posted, except that I'm not sure if DTS-HD MA will match "dtshd". To know for sure, one have to look in the log. Search for "Parsing results" and find the one that is for the file in question. If you use the cache (which you probably do), the parsing results might not be logged because the parsing information from the cache is used - if that's the case, turn off the cache and "browse" to the folder with the file, and it should be logged. Then turn the cache on again.
The excerpt from your log doesn't seem to be about this file. If you had included a bit more of the log (further up), it would say which file it was about. One thing that can be slightly confusing in the log, is that because UMS is multithreaded, several things happen at once - so completely unrelated things may come mixed together. The part in the [square brackets] shows the name of the thread, in this case "HTTPv2 Request Worker 3". When you look further up or down for what happened to the "case you are investigating", disregard everything that's not from the same thread. The reason it doesn't look like the same file is that the file in question has embedded subtitles, and the MediaInfo output you posted does not. The reason the file that is being evaluated is being transcoded, is that the renderer isn't configured to support subtitles track 2 (whatever format/type it is, that part of the log isn't there). I have no idea if your TV actually supports internal subtitles or this particular format, but this is also specified in the renderer configuration (both internal/embedded and external/subtitles file are specified separately).
@both The part we DO see in the log, is the least interesting (except for the first line). What happens is that after UMS determines that the file isn't supported (for some reason), it will pick a format to transcode to (Usually MPEG-TS or MPEG-PS). The same "resolving process" will then be performed for the transcoded format, which is what we see in the log. Unless the configuration is completely off, this will always find a match, so that part is something I just skip with my eyes when reading ;)
@mik_s MPEG-TS and MPEG-PS are called (MPEG) Transport Stream and (MPEG) Program Stream respectively. They are different file formats, both often simply using the .mpeg extension. MPEG-TS is capable of much more than MPEG-PS, but a lot is identical too. I guess you could say that a Transport Stream is a kind of "container" that can contain many program streams. In addition, they can carry lots of extra metadata, like repeating "headers" (which makes them stream-friendly as you don't need to read the start of the stream to know what the content is), EPG tracks, encryption/decryption packets etc. MPEG-TS is very commonly used for TV broadcast (satellite, terrestrial and cable), where multiple radio, TV or data channels are all muxed into one transport stream. The tuner will then demux the stream, read EPG and "channel information" and the pick the tracks it's interested in for the selected channel. This channel is then usually a "program stream" within the transport stream. Some times, a program stream will end when one program ends and another one starts, while other times they "merge" different programs (and commercials) into one long program stream. If they use separate program streams for ads (which is really natural, as it's a different source), it would become much too easy to automatically remove them I guess ;)
binzoman
Post by binzoman »
I wanted to know if native WebOS media player on LG tvs, support streaming of movies with EXTERNAL subtitles present in folder where the movie is - via DLNA only embedded ones seems to be working can i do it with UMS?
shyh
Post by shyh »
had similar issue with the new default lg-oled.conf, playing 10bit HDR files
adding
SupportedVideoBitDepths = 8,10
and
modifying the MKV line to
Supported = f:mkv       v:av1|h264|h265|mp4|mpeg2|vp8|vp9   a:aac-lc|he-aac|ac3|dts|eac3|lpcm|mp3|mpa               si:ASS|SUBRIP   m:video/x-matroska vbd:8|10
fixed the issue
someoneElse
Post by someoneElse »
I have a similar issue.
Even though the TV doesn't "support" DTS-HD or whatever, everything can be played when plugged directly into the TV. When it comes to UMS i don't want any encoding ever. Either the files Run or they don't. I wouldn't care about error messages and so on. Hence i removed the renderers directory alltogether. I can watch any movie now. BUT every 4k Movie is not even displayed. I don't even see it on the TV..
I haven't investigated any further if H265 is the Problem but the only thing i want UMS to do is to establish the connection and provide the files.. no transcoding, no thinking about any codecs whatsoever....
do you guys have any idea what the problem could be?
OS on Server is Win Server 2019 Std. TV is LG OLED77C39LC.AEU
If you only have the one device you plan to use UMS on then you can set "Skip transcoding for the following extensions (comma separated):" in transcoding settings to all the filetypes you plan on playing. Something like "MKV,MP4,AVI" etc. This will affect all devices on the network though. To limit this to the one device you can do something similar in it's conf but does take a bit more work to set up.
You should probably keep your renderer confs though as they are used for sending the correct format type (MIME type) to the device. If there are no confs to match it will use the built in "default renderer" which has very limited support so is probably why you are not seeing any 4k videos.
The problem won't be h265 as this should be supported on all modern TVs, but it will be the DTS audio. To know exactly though I will need to see logs (see the section in red above)
If the conf is set up correctly you should not need to know about codecs and formats, UMS will handle everything and convert anything not normally playable.
If your TV supports HLS then using that for transcoding is nearly identical as streaming.
