[Solved] srt subtitles stopped working a while back
pipin
Re: srt subtitles stopped working a while back
Post by pipin »
SubJunk wrote: Fri Sep 27, 2019 8:04 pm *hits refresh every day*
by the way I am very motivated to fix this bug, I try to pick one bug at a time to focus on with UMS and this is my one for now - if I focus on too many at once then they don't get finished
Dang it, I forgot. Will do it now.
Edit:
Soon, after soccer. ;)
Regards,
Jens
pipin
Post by pipin »
Here are the logs.
First the working tv and then the other with subtitles not working.
ums_dbg_5_10.zip
(297.52 KiB) Downloaded 1241 times
Regards,
Jens
pipin
Post by pipin »
Ok, im on it.
And this time faster. ;)
Regards,
Jens
pipin
Post by pipin »
SubJunk wrote: Sat Oct 12, 2019 8:46 pm Thanks pipin. I am clutching at straws after not seeing anything in the logs so now I'm going to ask you to test more versions to tell me which work:
Ok just quick checking the not working Samsung TV UE 48H6600
https://www.universalmediaserver.com/up ... a1f766.exe
working
https://www.universalmediaserver.com/up ... 8b360e.exe
working
https://www.universalmediaserver.com/up ... 2f60d1.exe
working
https://www.universalmediaserver.com/up ... 1d3eb1.exe
working
https://www.universalmediaserver.com/up ... 850c63.exe
working
Hm, all are working. Just one obervation: only the last one worked out of the box by selecting video files on connection. On all other versions I had to select all files. If I selected video there were no video files found.
Regards,
Jens
pipin
Post by pipin »
Regards,
Jens
Ok great so we have identified which commit seems to have broken that subs support. It happened in https://github.com/drakulis/UniversalMe ... it/6337b21
Here's an attempt at a fix
https://www.universalmediaserver.com/up ... b73e67.exe
pipin
Post by pipin »
SubJunk wrote: Fri Oct 18, 2019 9:55 am Ok great so we have identified which commit seems to have broken that subs support. It happened in https://github.com/drakulis/UniversalMe ... it/6337b21
Sorry, but doesnt work.
And this version needed much more time to install again.
Regards,
Jens
Ok another approach for testing please :)
https://www.universalmediaserver.com/up ... 305393.exe
