[Solved] UMS Won't Startup
Re: UMS Won't Startup
There's no need for system restore, it's easy to break the PATH on any Windows installation. Just make sure that some of the paths are invalid, that is: contains characters invalid for storage paths. You can easily "construct" this issue on your own Windows SubJunk.
It would be helpful if you can try to set an invalid path since I won't be at my Windows machine for a few days and it would be nice to get this wrapped up before then.
Here's an attempted fix which hopefully skips over invalid sections of the path:
https://www.universalmediaserver.com/up ... b5529a.jar
railiyat wrote: Tue Aug 13, 2019 6:31 am Are you running any firewalls/AV products?
Great, another spambot...
Yup looks like. There's no spam yet but I'll keep an eye on him and as soon as any links appear he's gone.
There's no reason to wait, look at his other posts - they are just copies of other posts in the same thread.
yes, you're right. I didn't look back at the previous posts in the threads. I'll hit him with the Ban Hammer :D
:thumbsup:
randomusername wrote: Mon Aug 12, 2019 10:48 pm I rebroke the path tried the old ums.jar and after seeing it not run replaced it with the new ums-9.0.0-b2-1d7b5529a. It works now with the broken path.
Thanks so much for all your testing, I'll look to merge that fix and hopefully that can resolve the issue for more users
And thanks for all the help with spammers mik_s!
