Help us improve support for your devices
wazer
Re: Help us improve support for your devices
Post by wazer »
Hello again
This time I'm writing for my parents house, home for Christmas, started clean ums 5.0.0-b1 installion so that you can improve/add support for UE55ES8005/UE55ES8000
Here's the debug files
UE55ES8005/UE55ES8000 5.0.0-b1
(18.95 KiB) Downloaded 943 times
kkomara
Post by kkomara »
I do not use DLNA because I need to access my home media over VPN over the internet.
Please add HTTP support for IOS/iPhone,
Here is what works on Wild Media Server (WMS):
My video files are stored as .wmv (Video Format is wmv2, Audio format is mp3)
Video is transcoded to:
Mpegts
-vcodec h264 libx264 (yuv420p, 720x540,....)
-acodec aac libfaac (48000Hz,....)
When I use WMS and I click on a movie to play it streams to my iphone and the stock IOS video player plays the movie perfectly. When I use the WMS HTTP interface I do not have issues with it trying to use FLASH. I have other MANY other issues with WMS that are causing me not to be able to use it. Would MUCH rather use an OPEN source program like UMS !!
Audio:
My audio files are stored as .wmva(Format is wmav2)
mp3
acodec mpe libmp3ame (44100Hz,....)
When I use WMS and I click on a song to play it streams to my iphone and the stock IOS video player plays the song perfectly. When I use the WMS HTTP interface I do not have issues with it trying to use FLASH. I have other MANY other issues with WMS that are causing me not to be able to use it. Would MUCH rather use an OPEN source program like UMS !!
Maybe this is a dumb question - but is this possible now with UMS by changing some kind of internal parameters ???
Thanks All !!!!
kkomara
Unctom
Post by Unctom »
Beta 1 seems stable but some transcoders don't seem to work. Here is my log file.
(23.19 KiB) Downloaded 986 times
billfish
Post by billfish »
Samsung BD-C6800. UMS shows up onscreen as a device, but attempts to open it produce the message "No movie file in current device."
UMS media scan looked like it went OK.
Mac OSX 10.10.1
UMS 4.3.1
Java 8
Log file attached.
ums_dbg1.zip
(5.6 KiB) Downloaded 968 times
Enrice
Post by Enrice »
Hi again,
by sending via Windows Media Player I managed to identify the supported media of the HAMA IR320, which are:
mp3,wav,mp4,aac,wma
Anyway, by using UMS I was just able to play WMA as can be verified by the attached log - still only by controlling via UMS, not through the device itself.
HAMA IR320
(42.71 KiB) Downloaded 1059 times
On my PANA I still get best results when excluding transcoding for MKV and AVI. What I find annoying is that you can no longer have "no encoding" as default, this can only be selected in the #TRANSCODED'# folder, when exclusion for that specific file extension is activated. For verification of this behaviour I provided another log.
ums_dbg2.zip
PANASONIC ETW60
(199.91 KiB) Downloaded 998 times
Thanks for investigation (again).
wazer wrote:Hello again
Thanks a lot, wazer! We have added support for that TV in the next version :)
kkomara wrote:I do not use DLNA because I need to access my home media over VPN over the internet.
Mpegts
Audio:
mp3
Thanks All !!!!
kkomara
What happens when you try to use the UMS web interface on your iPhone with UMS 5.0.0-b1?
billfish wrote:Samsung BD-C6800. UMS shows up onscreen as a device, but attempts to open it produce the message "No movie file in current device."
Mac OSX 10.10.1
UMS 4.3.1
Java 8
Log file attached.
Hi billfish, I've attempted to improve support for your device in the next version. Unfortunately I can't build test versions for OS X so you'll have to wait for the release, sorry.
Enrice wrote:Hi again,
mp3,wav,mp4,aac,wma
The attachment ums_dbg.zip is no longer available
The attachment ums_dbg2.zip is no longer available
Thanks for the info, Enrice! I've added those supported files for the IR320, feel free to try out the attached renderer config and let me know how it goes.
As for the Panasonic thing, in the next version there will be more videos that don't get transcoded, since we had a bug that caused too much transcoding. Some may still unnecessarily transcode, since we like to err on the side of caution (it's better to receive a transcoded video than one that doesn't work) but it will be much improved :)
Hama-IR320.conf
(767 Bytes) Downloaded 1192 times
Tuhincba
Post by Tuhincba »
THIS site is most important for electric divice users thank you for the post
Enrice
Post by Enrice »
SubJunk wrote:Some may still unnecessarily transcode, since we like to err on the side of caution (it's better to receive a transcoded video than one that doesn't work) but it will be much improved :)
Not, if your server is too slow for transcoding... ;-)
Enrice
Post by Enrice »
Hi.
Regarding the ir320: sorry to say, still no files listed at all. :cry: I never have seen any file listed with any version and any renderer config when using UMS.
Something deeply more general must be the problem, since I am able to see (and play) them from win8 media player as well as Plex media server.
rhauff
Post by rhauff »
Sony Bluray player BDP-BX510 has problems playing many video types. I'll start with this one:
Trying to play an iphone video, the video comes up shows maybe 1 second of video, no audio, then freezes. I am unable to power down the player, and must pull the power plug to restart it.
UMS version 5.0.0-b1 on Ubuntu (same problem occurs on version 4.3 and 4.2, have not tested earlier)
The renderer is properly detected as a Sony Bluray
I have attached the debug log zip file, and the specification file (change extension to .pdf to open it)
Thanks for the help!
(64.96 KiB) Downloaded 1008 times
BDPBX510_mksp.zip
Specifications for Sony BDP-BX510
Rename to .pdf to open
(212.77 KiB) Downloaded 849 times
Locked
