XBox 360 doesn't See UMS but it can see PMS
Re: XBox 360 doesn't See UMS but it can see PMS
ok, will try that and let you know
Have been having the same exact issue with 5.0 but when downgrading to a previous version everything works relatively fine apart from a few issues where it randomly stops playing the video and doesn't let me resume from where i was at... is it possible the issue with the Xbox 360 detecting it and the BubbleUPnP detecting it are both caused by the same problem in some way?
After upgrading to V 5
UMS sees Xbox
Shows up on Xbox but shows no videos found...no problems before the upgrade
UMS sees Xbox
I have updated to v5.0.0 and now the Xbox does see UMS (yay!) However, it shows me options (folders) such as 'by camera' and 'by ISO'... so obviously the Xbox video app only identifies the pictures section of UMS... even though I haven't enabled any sources to collect pictures!
Hope this helps you to identify and fix the problem.
Matt
Matt
Hi Mattcat888, I've reproduced this problem and am working on fixing it for the next release. Thanks
Thanks soo much!!! I can't wait to start using it again!
This is unrelated but I cannot seem to use my Panasonic DMP-BDT220 Bluray Player with UMS as it doesn't identify which type of device it is. Serviio doesn't either but it has a configuration file for a general Panasonic BD Player which works - any suggestions? If not, thats ok, I'm just happy that the xbox problem is getting solved
If you can attach some logs (instructions in my signature) then I can add support for that player too
That would be great, thanks!! Here it is
- (19.96 KiB) Downloaded 628 times
Thanks for the logs, please try this config by putting it in C:\Program Files (x86)\Universal Media Server\renderers\
Panasonic-DMPBDT220.conf
- (1.37 KiB) Downloaded 765 times
Awesome thank you so much! Works really well
