Need YAMAHA RX- A720 renderer
Re: Need YAMAHA RX- A720 renderer
You don't have that much that you want keep from your anterior ums.conf, so doing it again from the GUI will take you around 1 minute or so.
Ok any ideas on how to get the radio streaming to work through Yamaha receiver?
I saw 3 possible problems that could be related to this issue, but as i'm not familiar with that matter it would very useful if you could post a log done with a UMS working version as well.
I can post a log from 5.13.
Logs from the 5.13Sami32 wrote:Good, that should help.
- ums_dbg5.13-A720-radio.zip
- (30.85 KiB) Downloaded 728 times
Did you tried to play the "Power88.1" web radio ?
Could try to copy the FFmpeg version in UMS 5.1.3, in your UMS program file folder (/Universal Media Server/win32), in UMS 6.6.0 version (after having backup it) and test it again with UMS 6.6.0 version ?
Not sure what you mean?Sami32 wrote:Did you tried to play the "Power88.1" web radio ?
Could try to copy the FFmpeg version in UMS 5.1.3 in UMS 6.6.0 version (after having backup it) and test it again with UMS 6.6.0 version ?
Copy the FFmpeg.exe from your UMS 5.1.3, found inside your UMS program file folder (/Universal Media Server/win32), to your UMS 6.6.0 program folder.
No luck!Sami32 wrote:Copy the FFmpeg.exe from your UMS 5.1.3, found inside your UMS program file folder (/Universal Media Server/win32), to your UMS 6.6.0 program folder.
- ums_dbg6.0A720.zip
- (47.02 KiB) Downloaded 842 times
