[Solved] Sony X90J and X95J can't connect
Re: Sony X90J and X95J can't connect
Only 1 is 1080p, the rest are UHD 4K!
Ok cool, can you send logs with one or both of the 4k ones switched on so I can see how they identify themselves?
Yup. Let me install the newest build you just added and I'll grab logs right meow!
IP's changed probably. Testing on the 55R625 model........
Sony 50" - X80J - IP Address: 192.168.50.183
TCL Roku 28" - 28S305 - IP Address: 192.168.50.144
TCL Roku 55" - 55S515 - IP Address: 192.168.50.168
TCL Roku 55" - 55R625 - IP Address: 192.168.50.112 <--- Samsung Q850A is on this device via eARC
And here's the log file for that.Resident Evil played fine. 4K 10bit (2nd video) Wonder Woman wouldn't load. It just exited back to play screen. 720p Wonder Woman played. Lagged loading all. FORCE these tv's to use Roku Ultra (by default all new TCL use that from what I have seen) and it works much faster...
Guessing you need to enable 4K 10bit so I'm not crippled playing low res.
- ums_dbg_2021-12-29-19-54.zip
- (136.33 KiB) Downloaded 686 times
Ah this is interesting. So the 28S305 and 55S515 both identify themselves by their hardware generation, which tells us what they support. But the 55R625 identifies itself by the software version, which isn't very helpful.
With that one particularly (and potentially all of them), we might need to go back and forth a bit to get the filetype support squared away. They don't really publish information about it. They have a general page with filetypes but it's not that detailed and it doesn't differentiate between models.
Here's an attempt, each TV has a separate config https://www.universalmediaserver.com/up ... 952a35.exe
The 1080p and 4k tv's now showed up in UMS. I'll try the 3rd TCL 4k shortly.
- Capture.JPG (99.19 KiB) Viewed 6982 times
The 5 series TCL shows as 4k and streams just fine now....Meow meow!
Looks like everything works. Multiple bugs fixed. Wheeeee all work now!
- Capture 1.JPG (88.6 KiB) Viewed 6945 times
That's so great, thanks for all the testing. I'm really happy to have done these fixes since they will affect stability for all users. It has been merged so will be in the next release soon
