nomi2013
Re: Jumpy Plugin (14 September 2013)
Post by nomi2013 »
Thanks Infiden for the prompt reply I will attached debug.log with PMS with Jump 0.2.9
I also have issues with UMS 3.b1 or 2.6.5 build as mentioned .. 3.0 b1 logs also attached at following URL. Looks to me some settings missing either in UMS or jumpy to support the streams which is currently working in XBMC (Frodo)..
viewtopic.php?f=9&t=1245
So I am currently working on two things a) Make UMS 3.0 b1/2.6.5 works with jump 0.2.9 OR b) Make PMS latest build works with jump 0.2.9 to get the channels back :)
Thanks again
Nomi
mtutick
Post by mtutick »
I guess I need some help. I've been reading through this post and various others, but I haven't found a solution so far.
My problem is that I can't get ANY streams from the SportsDevil addon to work. Everything shows up as "no titles available" on the PS3 once I click through the folders down to where the video should start (actually they are kind of appearing as folders instead of videos). The streams work on my Windows PC if I try them inside of XBMC.
Setup: XBMC with SportsDevil Add-on. Renderer is PS3. I'm using PMS 1.90.1
What I've tried
- Streams from the Web folder work (tried Ted Talks)
- Streams from other XBMC Addons work. I tried YouTube and Ted Talks
I would appreciate any help. I've attached log files.
Thanks!
PMS.zip
(97.85 KiB) Downloaded 997 times
infidel
Post by infidel »
mtutick (debug.log) wrote:TRACE 2013-11-22 22:55:52.565 [Thread-97] Could not match any format to "rtmp://ny.premiumcdnlive.com/edge playpath=xoaaohmeuajfeyf swfUrl=http://player.ilive.to/secure_player_ilive_z.swf live=1 timeout=15 token=I8772LDKksadhGHGagf# swfVfy=1 pageUrl=http://www.ilive.to"
It's a bug in PMS. This is a librtmp-style pseudo-url as used by ffmpeg and is being (generically) rejected because it contains "illegal" spaces (even though that's how ffmpeg wants/expects it to be). UMS will be able to handle it properly.
In general Sports Devil functionality is very hit-or-miss in my experience, same as with any of the "mega-addons" that attempt to support everything under the sun :).
mtutick
Post by mtutick »
infidel, thanks for the quick reply. You were correct. I switched over to UMS and it works. Thanks for the help.
rasa
Post by rasa »
Is this plugin compatible with latest UMS version 3.1.2.1?
Casper
Post by Casper »
Are there any tricks to get subtitles working with UMS 3.1.2.1 and Jumpy 0.2.9?
Subtitles are working in UMS with video files, it's configured to always show them regardless of language and UMS finds them in C:\ProgramData\UMS\data\subs. But with Jumpy, the log indicates it knows where the subtitle files are (the addon data folder) but UMS can't find them and doesn't include them in the ffmpeg options.This is with the youtube addon and the subtitle files are ssa.
lotis
Post by lotis »
I have a LG LA6130
each version UMS + XBMC + JUMPY the following error:
11-28 22:28:57 Buffer read ArrayIndexOutOfBoundsException error:
11-28 22:28:57 readCount: "99999993856"
11-28 22:28:57 maxMemorySize: "209715200
has anyone have any ideas?
R9deLima
Post by R9deLima »
lotis
The most recent versions of UMS are producing the same error for me, 3.0 and up. 3.0.0a-1 seems to work fine, but anything higher is creating errors. The old versions give me no problems. I started up a thread a few days ago and hoping to get some answers.
viewtopic.php?f=9&t=1391&p=8559&hilit=producing#p8559
infidel
Post by infidel »
Casper wrote:Are there any tricks to get subtitles working with UMS 3.1.2.1 and Jumpy 0.2.9?
Yes, use 0.3.0 instead :).
@rasa, @lotis, @R9deLima: hopefully you've worked things out by now :).
infidel
Re: Jumpy Plugin (18 December 2013)
Post by infidel »
Update: jumpy-0.3.0
