Re: Jumpy Plugin (8 April 2014)
Thanks for the reply but still the same
debug http://pastebin.com/6auAnc8Y
jumpy.log http://pastebin.com/TWV1TNWU
Well not quite, it's a sightly different error nowabre wrote:Thanks for the reply but still the same
- Open a command console and create a symlink (outside your user path) to your XBMC user folder, for example C:\XBMC
mklink /d C:\XBMC C:\Users\Mój\AppData\Roaming\XBMC
- Shut down UMS, open UMS.conf and edit xbmc.path to point to the symlink, e.g.
xbmc.path = C:\\XBMC
Yes I know there was a slight difference
now I've done what you wrote but still nothing more on my tv.
jumpy.log http://pastebin.com/JpkmPyTg
Which addons do you have installed in xbmc? A directory listing of C:\XBMC\addons\ would be good if possible.abre wrote:still nothing more on my tv
Help !!! I have been looking into any similar problem but i can't play any content from jumpy at all can you help please , i been trying icefilms plugin and got no where please see my Zip , any help would be very much appreciated as i did love the ability to stream and really miss it now.
- (162.6 KiB) Downloaded 719 times
There are:infidel wrote: Which addons do you have installed in xbmc? A directory listing of C:\XBMC\addons\ would be good if possible.
metadata.album.universal, metadata.artists.universal, metadata.common.amazon.de, metadata.common.hdtrailers.net, metadata.common.htbackdrops.com, metadata.common.theaudiodb.com, metadata.common.themoviedb.org, metadata.musicvideos.theaudiodb.com, metadata.themoviedb.org, metadata.tvdb.com, packages, plugin.video.weeb.tv, script.module.addon.common, script.module.simplejson, script.module.urlresolver, script.torrent-tv.ru, weather.wunderground.
Hi Thanks for the reply, hope you can help .. I have attached the screen shot of installed addons.
- Untitled-1.jpg (259.36 KiB) Viewed 13344 times
This is your only addon and it's working for me. I'm not sure why it's not showing up in your jumpy folder, since the logs are "normal" and jumpy is seeing everything else in C:\XBMC\addons. 2 things to check and report back please:abre wrote:plugin.video.weeb.tv
- install the youtube addon (Videos >> Addons >> Get More... >> YouTube).
- verify that weeb.tv is working for you in XBMC itself.
Hi, firstly please don't double post so we can keep things in good shape around herer2obd wrote: can't play any content from jumpy at all can you help please , i been trying icefilms plugin
- Is Icefilms working for you in xbmc itself? The error you're getting seems to indicate a bad install. Try uninstalling and reinstalling it in xbmc. I should mention that even when it's working:
- many icefilms links require solving a captcha, which you can't do in jumpy since there's no gui.
- you will need to add this setting to jumpy.conf to be able to use the links that work:
resolve_at_playback = false
- What about your other addons, are they working? If not, please verify whether they're working in xbmc also.
Wow. I've just installed the youtube addon and now it's workinginfidel wrote: This is your only addon and it's working for me. I'm not sure why it's not showing up in your jumpy folder, since the logs are "normal" and jumpy is seeing everything else in C:\XBMC\addons. 2 things to check and report back please:
Anyway, thank you for your help infidel
