Help us improve support for your devices
Re: Help us improve support for your devices
Thanks a lot for this, you've contributed a lotwazer wrote:Aaaaaand another player logged/added via ums 5.0.0-b1 to you Sub
Sony BDP-480
Hi smala, thanks for the info! I've made a build for you to test with the Zperia Z3, please let me know how it goes: http://www.spirton.com/uploads/UMS/UMS-e6fe176.exesmala wrote:Hi all,![]()
I'm enjoying UMS since 4.2.0 release.
Now i'm testing UMS 5.0.0b1 along with 4.3.1 (stable)
I own a Sony Xperia Z3 and is recognized by UMS 5.0.0b1 as a "ChromeCast" device.
I tried to play a chapter of an Anime (Mkv format) but UMS does transcoding to MP4 format, which breaks time-seek. My phone supports several video formats, MKV included.
As far i know, in 4.3.1 works better since it's recognized as "Android".
Test case:
1. UMS 5.0.0b1 default configuration + Sony "Film" App (which has native DLNA support) ==> video plays (in 4.3.1 crashes) with MP4 transcoding and TimeSeek KO; no way to force default MKV to get streamed
2.UMS 5.0.0b1 default configuration + BubbleUPNP w/ "sony player" ==> video plays with MP4 transcoding and TimeSeek KO; no way to force default MKV to get streamed
I've also tried MxPlayer with Bubble UPNP, but video get always transcoded to MP4, hence the problems.
In attachment: Logs + MKV detail
Hi,SubJunk wrote:Hi smala, thanks for the info! I've made a build for you to test with the Zperia Z3, please let me know how it goes: http://www.spirton.com/uploads/UMS/UMS-e6fe176.exe
i tried the build in attachment.
With this build, the renderer "Xperia Z3" is recognized correctly.
Opening the stock Film App, and navigating to the folder/file i want to view (the same as previous test) gives me "unable to open file".
Log attached
After i made some other test (sorry, no log) with sony stock film app (Xperia Z3.conf file loaded), sometimes i receive a warning that "no files can be found in this folder"
I did also a test with BubbleUPNP / MxPlayer and still video get transcoded from MKV-to-MP4 format (seek broken), since the profile Chromecast is loaded.
Disabling the Chromecast profile, the media renderer BubbleUPNP/Android is forced to be used.
Media plays correctly and the video is streamed directly in MKV format.
i noticed that if i seek 1-2 times in a row, the player(MxPlayer in H/W Mode) stops to receive data and/or crashes.
All log in attachment
- UMS-e6fe176_NOchromecast_bubbleUPNP_MxPlayer.zip
- Chromecast profile forced off, BubbleUPNP with MxPlayer recognized as BubbleUPNP/Android; video plays natively in MKV. Noticed player hangs when seeking 1-3 times
- (31.29 KiB) Downloaded 765 times
- UMS-e6fe176_chromecast_bubbleUPNP_MxPlayer_KO.zip
- Stock UMS config, BubbleUPNP recognized as Chromecast device, video plays but in MP4 format with broken seek.
- (52.73 KiB) Downloaded 690 times
- UMS-e6fe176_Z3_Sony_Film_APP_KO.zip
- Stock UMS config, used the Sony Film APP to browse /render files
- (36.17 KiB) Downloaded 703 times
nickhere wrote:here my zip for a panasonic TC-50AS650UE
keep up the work
wish i can help more
Thanks a lot for these! I've added them now for the next releasenickhere wrote:here another one
the panasonic bdt-360 dvd player
When i use transcoding it always crashes for me about a minute or two right before the end of a 23ish minute serie episode. I've been tinkering around with settings but nothing seems to fix it. Plex transcoding does seem to work without issues but i don't like that program and how it is setup at all. I used UMS and the previous PS3 media server for a number of years now (when not transcoding the program works perfectly) so when i spotted this thread i thought i'd contribute and see if that helps and maybe it was a renderer issue.
- (48.35 KiB) Downloaded 709 times
Sorry for the delay, I didn't have notifications turned on to see you had repliedSubJunk wrote:Hi rhauff, please try this version and let me know how it goes: http://www.spirton.com/uploads/UMS/UMS-74253d2.tgzrhauff wrote:Sony Bluray player BDP-BX510 has problems playing many video types. I'll start with this one:
Trying to play an iphone video, the video comes up shows maybe 1 second of video, no audio, then freezes. I am unable to power down the player, and must pull the power plug to restart it.
UMS version 5.0.0-b1 on Ubuntu (same problem occurs on version 4.3 and 4.2, have not tested earlier)
The renderer is properly detected as a Sony Bluray
I have attached the debug log zip file, and the specification file (change extension to .pdf to open it)
Thanks for the help!
No change in playback using build UMS-74253d2, playing this iPhone .mov video. It still plays about 1 second of video without audio, then locks up the Sony Bluray player. If I play it with the newly released 5.0.0 (still on Ubuntu 14.10 with Java8) I get either a blank screen (no response whatsoever), a message "The file is corrupt or unsupported", or video with no audio
Thanks for testing and the logs. Do either of these work better?smala wrote:i tried the build in attachment...
- Sony-XperiaZ3-2.zip
- (947 Bytes) Downloaded 686 times
- Sony-XperiaZ3-1.zip
- (882 Bytes) Downloaded 816 times
I hope we can fix it for you, can you please let me know how this goes? http://www.spirton.com/uploads/UMS/UMS-f726db9.exerisljaninasim wrote:When i use transcoding it always crashes for me about a minute or two right before the end of a 23ish minute serie episode. I've been tinkering around with settings but nothing seems to fix it. Plex transcoding does seem to work without issues but i don't like that program and how it is setup at all. I used UMS and the previous PS3 media server for a number of years now (when not transcoding the program works perfectly) so when i spotted this thread i thought i'd contribute and see if that helps and maybe it was a renderer issue.
Thanks for the logsrhauff wrote:Sorry for the delay, I didn't have notifications turned on to see you had repliedSubJunk wrote:Hi rhauff, please try this version and let me know how it goes: http://www.spirton.com/uploads/UMS/UMS-74253d2.tgzrhauff wrote:Sony Bluray player BDP-BX510 has problems playing many video types. I'll start with this one:
Thanks for the help!![]()
Hi y'all,
Got myself an nice, new Philips PUS7809 TV . Please find attached the logs generated when starting UMS 5.0.
One noticable thing though is that detection under UMS 5.0 is much slower/erratic then under UMS 4.4 (also logs included)
I hope the 55 log helps in generating/building the CONF. The conf i use now is derived from Leroy's Philips PFL conf (whic was really good for my last Philips TV!)
Have fun and thanx for a really good server!
Uppie
Uppie
- ums50_dbg_Philips_PUS7809.zip
- (43.69 KiB) Downloaded 781 times
- ums44_dbg_Philips_PUS7809.zip
- (18.34 KiB) Downloaded 671 times
