[Solved] No ISO or VOB Support on PS3 after installing 5.2.x
Re: No ISO or VOB Support on PS3 after installing 5.2.x
I reproduced the bug with your ISO, yay! I'm really happy about that. I've run out of time today but will find the cause tonight and finally we can put this behind us
It's working for me now with this build, please confirm: http://www.universalmediaserver.com/upl ... d81194.exe
chrisl
Post by chrisl »
Cheers SubJunk.
Sorry, I can't try the build, I'm on OSX ...
Thank you :D
Ah I remembered that after I left work tonight and left my mac there :p I'll either build it for you or just do a release tomorrow since I'm pretty sure this fixes the bug, at least for that ISO
chrisl
Post by chrisl »
No problem, take your time.
chrisl
Post by chrisl »
Congratulations SubJunk, DVDs are working now with 6.3.1 !
Many thanks :D
I'm curious, what was the problem about, in a few words (if possible).
PAL vs NTSC ? as I saw you mentionned : "Fixed support for PAL DVDs" ?
Yay thanks for confirming :) Basically we added some code that said "define HD as above 540 pixels high" so we were telling the PS3 the video was HD instead of SD. Now we are saying "define HD as above 576 pixels high" since that's what PAL DVDs have
chrisl
Re: [Solved] No ISO or VOB Support on PS3 after installing 5.2.x
Post by chrisl »
Thank you.
Makadamiä
Post by Makadamiä »
Thanks a bunch, glad that this could be solved.
Tested my initial ISOs on PS3 & PS4, works flawless.
