Xbox One Getting DLNA Support
Re: Xbox One Getting DLNA Support
Thanks, your link worked for me, but strangely enough my XboxOne is now being identified as an Xperia Z. Streaming working fine though.SubJunk wrote:Yay, thanks for the great testingWhogie wrote:Yes it does!
I'll attach logs in case they're of some use to you. I ran the XB1 and 360 at the same time and it was able to distinguish between them.
Thanks for the report, jimwhat. Can you please post logs for this so I can see what's happening? viewtopic.php?f=5&t=556
Please test this one guys, hopefully it fixes the detection again
http://www.spirton.com/uploads/UMS/UMS-3ce8fdb.exe
Seems working
- proper xb1 detection.zip
- (23.09 KiB) Downloaded 739 times
Yay, now hopefully they can stop changing it around on us
Sorry about that. By the time I read your message I had already closed the program and then it stopped working after that.
Your latest update has fixed it though. It's being recognized as an Xbox One. Thank You.
- ums_dbg_Jimwhat.zip
- (15.4 KiB) Downloaded 741 times
Excellent, thanks for confirming
We will release the next version with this fix very soon
I am running the latest version of UMS - 4.2.2 on my Mac which is currently running Yosemite OS. The UMS detects my Xbox 360 but doesn't detect my Xbox One. PLEASE HELP!
I attached my log as instructed
- Mac to Xbox One not working
- (5.23 KiB) Downloaded 724 times
Hi madmagix, thanks for the logs. I can't see any attempt by the Xbox One to connect in the logs, so that usually means it's not on the same network as the computer
I made sure to connect to the same WiFi as my laptop as on my Xbox One, but oddly enough - even when I had my Xbox 360 turned off completely, and went to the Media Player app on my Xbox One, it picked up my Xbox 360.SubJunk wrote:Hi madmagix, thanks for the logs. I can't see any attempt by the Xbox One to connect in the logs, so that usually means it's not on the same network as the computer
I don't know what else to try.
