PS4 Pro (PlayStation 4 Pro) renderer's configuration file
As always feedback is welcome
Add/replace this renderer into your UMS "renderer" subfolder:
Re: PS4 Pro (PlayStation 4 Pro) renderer's configuration file
thanks for your work.
I have tried your conf file but it doesn't work. I've got an error on my ps4 pro. I can't read 4k videos.
Without your full trace log reproducing the "error", as explained here, i don't think we can do anything more than wait that "someone" post his log...
Thank you for having taken the time to give feedback
thanks for your reply
there you go
there you go
- (2.94 MiB) Downloaded 904 times
Thanks for your log
i waited one since february...
I see many transcoding issues, so i'll need to make a fixed UMS version for you to test later, i think around saturday, since today i'll not have time to work on it.
That's perfect.
Thanks a lot. and take your time.
No worries I'll give you my feedback.
I take your words, and hope for you feeback, also if it work
You can follow this PR here.
If you could test the external SRT (SubRip) subtitles, i will really appreciate that
If your PS4 Pro is connected to your TV by HDMI, make sure that you use the correct HMDI cable (2.0) for being able to see 4K HDR video.
Here is the new build, but you'll need to do a clean install to make it fully efficient:
https://we.tl/K7tDUpjulS
hi sami is this new built 6.7.3 snapshot includes the changes made on 7 rc1 which was released last week or is based on the 6.7.2 which was released before the 7 rc1?
This build is based on the lastest master, the 7.0.0 RC1 is based on the master at the time it was build.
To simplify, that mean that it have the lastest fixes and enhancements, but not the Database/library enhancement found in 7.0.0-RC1.
Thanks a lot for your work
... but it doesn't work.
You'll find the log attached
- (70.65 KiB) Downloaded 1010 times
