UMS hangs during boot (logo)
I just tried starting UMS to watch a movie, but it hangs showing the boot logo. I have uninstalled it and decided to try the 7.0.1 beta, but this gives me the same. When starting UMS, the console shows me
27/08/17 17:07:07,878 sharedfilelistd[480]: [default] [<CFString 0x7fff7c37ae00 [0x7fff7c432440]>{contents = "com.apple.LSSharedFileList.RecentApplications"}] List write failed invalid info items: (null) properties: (null)
27/08/17 17:07:07,878 sharedfilelistd[480]: -[ListStore writeListItems:properties:withListIdentifier:notificationHander:] [com.apple.LSSharedFileList.RecentApplications] List write failed invalid info items: (null) properties: (null)
27/08/17 17:07:16,192 launchservicesd[92]: SecTaskLoadEntitlements failed error=22
27/08/17 17:07:16,200 launchservicesd[92]: SecTaskLoadEntitlements failed error=22
27/08/17 17:07:16,394 appleeventsd[57]: SecTaskLoadEntitlements failed error=22
27/08/17 17:07:20,086 launchservicesd[92]: SecTaskLoadEntitlements failed error=22
27/08/17 17:07:20,193 launchservicesd[92]: SecTaskLoadEntitlements failed error=22
27/08/17 17:07:21,214 SpotlightNetHelper[599]: tcp_connection_tls_session_error_callback_imp 439 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22
27/08/17 17:07:21,214 SpotlightNetHelper[599]: tcp_connection_tls_session_error_callback_imp 438 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22
This is on OSX 10.11.6 (15G1611). Any idea what i can do?
Re: UMS hangs during boot (logo)
Please follow the Problem Reporting Guidelines up the top of this page, that will give us more information
Sorry for the late reply; did not receive a notification in my inbox. The problem has changed. I'm now able to start a stream on my TV. But after about 20 minutes it disconnects. Constantly. I did Google a bit and found this happened about 2 years ago on PS4's like in this thread, viewtopic.php?t=5563 , and i did try to remove "<string>-Djava.net.preferIPv4Stack=true</string>", but this didn't fix the problem.
This time i attach the trace, sorry for forgetting that the previous post. I did watch and waited for a disconnect. This time it took about 27 minutes. Please find a trace attached.
- (55.15 KiB) Downloaded 629 times
Tried to deinstall 7.0 version. Installed 6.7.4. Does show up in Activity Monitor, but does not show splash screen or anything else. After deleting everything from Users/name-of-user/Library/Application Support/UMS i was able to start, but although the distribution file name is 6.7.4., UMS shows 7.0.0-rc1 in the top app row (the one with the minimize icons etc)?! I did close UMS and ran it again: now it hang on the boot logo ("loading"). I deleted the application again, the use data, reinstalled again, did choose the offered local language instead of what i normally do (English), and now i have 6.7.4 running. We just watched a full episode of a series, so currently everything seems to work as it should. Thank you.
