[FIXED] [3.0.0.a3]Can't play any mkv
Locked
robod
Post by robod »
Hi! First of all, thanks for all your work.
I have a error with 3.0.0 a3. I can't play any .mkv files, just mp4 using "no encoding" option with a Sony Bravia EX. Here is the log:
(39.07 KiB) Downloaded 723 times
Thanks!
robod
Re: [3.0.0.a3]Can't play any mkv
Post by robod »
Same problem with beta 1 :(
Hi robod, hopefully we can find the cause of this. Can you please try 3.0.0-a1 and a2 as well? It will make it much easier for me if I know the exact first version the bug appeared in. Thanks
robod
Post by robod »
Oh, finally , with the 3.0.0 version I can play these .mkv . The problem is solved :)
Good work!
Locked
