BRAVIA KDL-40EX710 and image issue when streaming movies.
I have an issue when I want to watch a movie or any video of any formats.
Although the sound is OK, the picture is not and it renderers like in the attachment.
If I turn on tsMuxer, the video doesn't stream at all.
it does this horrible results with any .conf files or even using the default settings.
Do you know how to fix this?
Or maybe, can you help me edit this .conf file that I created using a previous workable version EX.conf and a EX725.conf that i renamed EX710.conf that I will keep as my default .conf file.
If I need to reinstall UMS, I would put it in the renderer folder to use it as default.
Thanks.
710.conf file to edit and change to make it work with all music format and video format and if possible HD and 4K compatible:
# Profile for Sony Bravia EX710 TVs.
RendererName = Sony Bravia EX710
# friendlyName=BRAVIA KDL-40EX710
# modelName=KDL-40EX710
UpnpDetailsSearch = KDL-\d{2}EX710
LoadingPriority = 1
SeekByTime = true
TranscodeAudio = LCPM
DLNALocalizationRequired = true
DefaultVBVBufSize = false
CreateDLNATreeFaster = true
AccurateDLNAOrgPN = true
MuxNonMod4Resolution = true
HalveBitrate = true
MediaInfo = true
#MaxVideoWidth = 1283
#MaxVideoHeight = 720
SupportedVideoBitDepths = 8,10
H264Level41Limited = true
#H265Level41Limited = true
ChunkedTransfer = true
TranscodedVideoFileSize = 1000000
TranscodeExtensions = mkv,m4a,mp4,avi
SubtitleHttpHeader = CaptionInfo.sec
PrependTrackNumbers = true
CharMap = / :
ForceJPGThumbnails = true
ThumbnailAsResource = true
OverrideFFmpegVideoFilter = pad=max(iw*1.01\\,ih*1.01*(16/9)):ow/(16/9):(ow-iw)/16:(oh-ih)/16, setdar=4/3
CustomMencoderOptions = -vf softskip,expand=::::1:16/9:2,scale=1283:720 -lavcopts aspect=16/9
# Our Bravia EX-specific notes:
# DTS is not supported.
# H.264 within AVI containers is not supported, nor is GMC or QPEL.
# WMV is supported, but not with 5.1 audio.
# Apple Lossless Audio Codec (ALAC) is not supported.
# Supported video formats:
Supported = f:mpegps|mpegts v:mpeg1|mpeg2|mp4|h264 a:ac3|lpcm|aac-lc|mpa m:video/mpeg
Supported = f:avi|divx v:mp4|divx|mjpeg a:mp3|lpcm|mpa|ac3 m:video/x-divx qpel:no gmc:0
Supported = f:mp4 v:mp4|h264 a:ac3|aac-lc m:video/mp4
Supported = f:wmv v:wmv|vc1 a:wma m:video/x-ms-wmv n:2
# Supported audio formats:
Supported = f:wav n:6 m:audio/wav s:48000 a:dts|lpcm
Supported = f:wav n:2 m:audio/wav s:48000
Supported = f:mp3 n:2
Supported = f:m4a n:2 m:audio/mp4 a:(?!alac).+
Supported = f:wma n:2
Supported = f:atrac n:2
Thanks.
LoadingPriority = 1
SeekByTime = true
HalveBitrate = true
MediaInfo = true
CharMap = / :
Sony-BraviaEX710.conf
- (2.34 KiB) Downloaded 451 times
- 20180118_210841.jpg (3.9 MiB) Viewed 3900 times
Re: BRAVIA KDL-40EX710 and image issue when streaming movies.
You can show the debug.log in the .config/ums repertory.
Try to delete "TranscodeVideo = MPEGTS-H264-AC3"
