Version 7.3.0 released
General:
This release introduces standalone builds (separate post to follow), adds folder scanning to the first-run wizard, fixes a database bug, and updates translations.
Changes since 7.2.1:
  • General:
    • Started to release standalone builds for Windows (no Java installation required)
    • Added option to disable startup folder scanning in the first-run wizard
    • Fixed fully played status sometimes not saving
  • Languages:
    • Updated translations via Crowdin
Compatibility notes:
erick diangilis
Re: Version 7.3.0 released
Post by erick diangilis »
hi subjunk i've tested out this new version on ps4 pro with the media player i'm really glad for this 7.3.0 Works pretty good. searching content on folders is fast, playback quality is superb sound quality is also good. memory usage is kept to a minimum as possible and my laptop behaved the way is suposed to only loud on demanding vídeos.
no disconnections using a long period of time wich is a commom problem on ps4. i also like the fixes and additions you mentioned above thanks for those the stabilty is also very nice. :D
thanks again and i left a comment on the other post with names to that version as you asked keep with the good work.
pipin
Post by pipin »
Thanks for the release, running smooth so far.
Just noticed a lot warnings like this:
02:16:46 ERROR Database error while writing status "true" to FILES_STATUS for "abbbbaa.mkw": Referentielle Integrität verletzt: "FILENAME_MATCH: PUBLIC.FILES_STATUS FOREIGN KEY(FILENAME) REFERENCES PUBLIC.FILES(FILENAME) ('abbbbaa.mkw')"
Referential integrity constraint violation: "FILENAME_MATCH: PUBLIC.FILES_STATUS FOREIGN KEY(FILENAME) REFERENCES PUBLIC.FILES(FILENAME) ('abbbbaa.mkw')"; SQL statement:
INSERT INTO "PUBLIC"."FILES_STATUS"("ID","FILENAME","MODIFIED","ISFULLYPLAYED")VALUES(DEFAULT,?,?,?) [23506-196]
02:16:46 INFO abbbbaa.mkw marked as fully played
Regards,
Jens
JDN165
Post by JDN165 »
I installed version 7.3.0 (stand-alone version).
Everthing works, but also a lot of warnings in the log when playing music files, like this one:
10:32:48 ERROR Database error while writing status "true" to FILES_STATUS for "D:\music\Ray Wilson\102 - Thats All.flac": Referential integrity constraint violation: "FILENAME_MATCH: PUBLIC.FILES_STATUS FOREIGN KEY(FILENAME) REFERENCES PUBLIC.FILES(FILENAME) ('D:\music\Ray Wilson\102 - Thats All.flac')"; SQL statement:
undermyseat
Post by undermyseat »
Hi. I tried to install this release, but I got the "no mountable file system" error that other people have experienced on previous releases. I tried the following releases until I got one that worked: 7.3.0, 7.2.1, 7.2.0, 7.1.0, 7.0.1. I was only able to successfully mount the last one.
I am running on an old Mac Pro (2009) that uses OSX 10.11.6 El Capitan. I have a MacBook Air that runs MacOS 10.12.6 Sierra, and it was able to open and mount the dmg file. Unfortunately, my Mac Pro is so old, that it can't be upgraded past El Capitan. As a workaround, I've opened the dmg on the laptop and copied the application over my local network, but that's not really the best solution. I am able to open other dmg files (including UMS 7.0.1) on my Mac Pro, so there's something about the newer dmg files that aren't compatible. I suspect it has to do with the dmg containing an APFS file system instead of an HFS+ file system. Would it be possible to use HFS+ in the dmg file?
I discovered on the web that you can use the command-line tool hdiutil to mount a dmg file. I've included output from both systems below.
Thanks.
OSX 10.11.6 El Capitan (FAILED):
Initializing…
DIBackingStoreInstantiatorProbe: interface 0, score 100, CBSDBackingStore
DIBackingStoreInstantiatorProbe: interface 1, score -1000, CBundleBackingStore
DIBackingStoreInstantiatorProbe: interface 2, score -1000, CRAMBackingStore
DIBackingStoreInstantiatorProbe: interface 3, score 100, CCarbonBackingStore
DIBackingStoreInstantiatorProbe: interface 4, score -1000, CDevBackingStore
DIBackingStoreInstantiatorProbe: interface 5, score -1000, CCURLBackingStore
DIBackingStoreInstantiatorProbe: interface 6, score -1000, CVectoredBackingStore
DIFileEncodingInstantiatorProbe: interface 0, score -1000, CMacBinaryEncoding
DIFileEncodingInstantiatorProbe: interface 1, score -1000, CAppleSingleEncoding
DIFileEncodingInstantiatorProbe: interface 2, score -1000, CEncryptedEncoding
DIFileEncodingInstantiatorProbe: interface 0, score 900, CUDIFEncoding
DIFileEncodingNewWithBackingStore: CUDIFEncoding
DIFileEncodingNewWithBackingStore: instantiator returned 0
DIFileEncodingInstantiatorProbe: interface 0, score -1000, CSegmentedNDIFEncoding
DIFileEncodingInstantiatorProbe: interface 1, score -1000, CSegmentedUDIFEncoding
DIFileEncodingInstantiatorProbe: interface 2, score -1000, CSegmentedUDIFRawEncoding
DIDiskImageInstantiatorProbe: interface 0, score 1000, CUDIFDiskImage
DIDiskImageInstantiatorProbe: interface 1, score 0, CSparseBundleDiskImage
DIDiskImageInstantiatorProbe: interface 2, score 0, CSparseDiskImage
CRawDiskImage: data fork length 0x00000000058A15B7 (92935607) not a multiple of 512.
DIDiskImageInstantiatorProbe: interface 3, score -100, CRawDiskImage
DIDiskImageInstantiatorProbe: interface 4, score 0, CDARTDiskImage
DIDiskImageInstantiatorProbe: interface 5, score 0, CDiskCopy42DiskImage
DIDiskImageInstantiatorProbe: interface 6, score -1000, CNDIFDiskImage
DIDiskImageInstantiatorProbe: interface 8, score -100, CShadowedDiskImage
DIDiskImageInstantiatorProbe: interface 9, score -1000, CCFPlugInDiskImage
DIDiskImageInstantiatorProbe: interface 10, score -100, CWrappedDiskImage
DIDiskImageNewWithBackingStore: CUDIFDiskImage
DIDiskImageNewWithBackingStore: instantiator returned 0
Verifying…
Verification completed…
Error 0 (Undefined error: 0).
expected CRC32 $855CF199
Attaching…
DI_kextWaitQuiet: about to call IOServiceWaitQuiet...
DI_kextWaitQuiet: IOServiceWaitQuiet took 0.000004 seconds
2018-08-18 12:01:42.644 diskimages-helper[46243:4376520] DIHelperHDID serveImage: attaching drive
autodiskmount = 1;
"hdiagent-drive-identifier" = "D6D7EA38-6926-4DE6-B75A-25606925D78B";
"unmount-timeout" = 0;
2018-08-18 12:01:42.647 diskimages-helper[46243:4376520] DIHelperHDID serveImage: connecting to myDrive 0x4D0B
2018-08-18 12:01:42.647 diskimages-helper[46243:4376520] DIHelperHDID serveImage: register _readBuffer 0x109dae000
2018-08-18 12:01:42.647 diskimages-helper[46243:4376520] DIHelperHDID serveImage: activating drive port 19211
2018-08-18 12:01:42.647 diskimages-helper[46243:4376520] DIHelperHDID serveImage: set cache enabled=TRUE returned SUCCESS.
2018-08-18 12:01:42.647 diskimages-helper[46243:4376520] DIHelperHDID serveImage: set on IO thread=TRUE returned SUCCESS.
2018-08-18 12:01:42.647 diskimages-helper[46243:4376520] -processKernelRequest: will sleep received
Volume check completed…
Mounting…
2018-08-18 12:01:42.693 diskimages-helper[46243:4376513] -remountReturningDictionary: detaching because no mountable filesystems.
Attaching…
Error 112 (no mountable file systems).
Finishing…
2018-08-18 12:01:43.745 diskimages-helper[46243:4376500] *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection is invalid
DIHLDiskImageAttach() returned 112
hdiutil: attach failed - no mountable file systems
Mac)S 10.12.6 Sierra (SUCCEEDED):
Initializing…
Verifying…
Checksumming Protective Master Boot Record (MBR : 0)…
Protective Master Boot Record (MBR :: verified CRC32 $F24FAFA0
Checksumming GPT Header (Primary GPT Header : 1)…
GPT Header (Primary GPT Header : 1): verified CRC32 $2FE27D3A
Checksumming GPT Partition Data (Primary GPT Table : 2)…
GPT Partition Data (Primary GPT Tabl: verified CRC32 $D56E9B49
Checksumming (Apple_Free : 3)…
(Apple_Free : 3): verified CRC32 $00000000
Checksumming disk image (Apple_APFS : 4)…
disk image (Apple_APFS : 4): verified CRC32 $466E68C0
Checksumming (Apple_Free : 5)…
(Apple_Free : 5): verified CRC32 $00000000
Checksumming GPT Partition Data (Backup GPT Table : 6)…
GPT Partition Data (Backup GPT Table: verified CRC32 $D56E9B49
Checksumming GPT Header (Backup GPT Header : 7)…
GPT Header (Backup GPT Header : 7): verified CRC32 $CC8C0131
verified CRC32 $855CF199
Attaching…
DI_kextWaitQuiet: IOServiceWaitQuiet took 0.000005 seconds
2018-08-18 13:10:02.023 diskimages-helper[5188:24438] DIHelperHDID serveImage: attaching drive
autodiskmount = 1;
"hdiagent-drive-identifier" = "77A9BF02-4B4E-49B0-940F-DD2D51B4FB17";
2018-08-18 13:10:02.024 diskimages-helper[5188:24438] DIHelperHDID serveImage: connecting to myDrive 0x4D0F
2018-08-18 13:10:02.024 diskimages-helper[5188:24438] DIHelperHDID serveImage: register _readBuffer 0x10972d000
2018-08-18 13:10:02.024 diskimages-helper[5188:24438] DIHelperHDID serveImage: activating drive port 19211
2018-08-18 13:10:02.024 diskimages-helper[5188:24438] DIHelperHDID serveImage: set cache enabled=TRUE returned SUCCESS.
2018-08-18 13:10:02.025 diskimages-helper[5188:24438] DIHelperHDID serveImage: set on IO thread=TRUE returned SUCCESS.
2018-08-18 13:10:02.025 diskimages-helper[5188:24438] -processKernelRequest: will sleep received
Checking volumes…
Mounting…
2018-08-18 13:10:03.302 diskimages-helper[5188:24405] _mountDevEntries: disk5s1 aborting mountpoint postflight because disk image has no band size specified.
Finishing…
Finishing…
2018-08-18 13:10:04.337 diskimages-helper[5188:24401] *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection is invalid
/dev/disk2 GUID_partition_scheme
/dev/disk2s1 Apple_APFS
/dev/disk5 EF57347C-0000-11AA-AA11-0030654
/dev/disk5s1 41504653-0000-11AA-AA11-0030654 /Volumes/ums-7.3.0-distribution
undermyseat
Hi, I tried posting this earlier and it doesn't seem to have worked. Sorry if this is a double post.
I tried installing this version and got the "no mountable file system" error that other people have reported on previous versions. So I tried installing these older versions: 7.2.1, 7.2.0, 7.1.0, 7.0.1. Only the last one worked.
I'm using an old Mac Pro 2009 running OSX El Capitan 10.11.6. I have a MacBook Air 2012 running MacOS Sierra 10.12.6, and it was able to open the dmg file. Unfortunately, my Mac Pro is too old to update past El Capitan. I think the problem may be due to using APFS file system instead of the older HFS+. Is it possible to use HFS+ to create the dmg file?
I found a command line tool hdiutil that mounts dmg files, so I captured the output from the two systems. If you're interested in the output, let me now. I can't figure out how to attach files here.
zdaecq
Post by zdaecq »
Hello!
UMS 7.3.0 not woking on macOS HS 10.13.4 after initial setup(language, connection etc).
Java installed if needs.
Here are logs:
INFO 21:33:48.566 [main] Language not specified, defaulting to OS language.
INFO 21:33:52.993 [main] Starting Universal Media Server 7.3.0
INFO 21:33:52.993 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO 21:33:52.993 [main] http://www.universalmediaserver.com
INFO 21:33:52.994 [main] Build: eb6b9d092 (2018-08-13)
INFO 21:33:52.994 [main] Java: Java HotSpot(TM) 64-Bit Server VM 1.8.0_131 (64-bit) by Oracle Corporation
INFO 21:33:52.995 [main] OS: Mac OS X 64-bit 10.13.4
INFO 21:33:52.999 [main] Maximum JVM Memory: 1.1 GiB
INFO 21:33:53.005 [main] Language: English (United States)
INFO 21:33:53.006 [main] Encoding: UTF-8
INFO 21:33:53.155 [main] Working directory: /Applications/Universal Media Server.app/Contents/Resources
INFO 21:33:53.161 [main] Temporary directory: /var/folders/qf/87c3vr0960z2r9_71hr66w180000gn/T/UMS-zdaecqzezdaecq
INFO 21:33:53.162 [main] Logging configuration file: /Applications/Universal Media Server.app/Contents/Resources/logback.xml
INFO 21:33:53.162 [main] Logfile: /Users/zdaecqzezdaecq/Library/Application Support/UMS/debug.log
INFO 21:33:53.163 [main] Profile directory: /Users/zdaecqzezdaecq/Library/Application Support/UMS
INFO 21:33:53.163 [main] Profile directory permissions: drwx
INFO 21:33:53.163 [main] Profile configuration file: /Users/zdaecqzezdaecq/Library/Application Support/UMS/UMS.conf
INFO 21:33:53.164 [main] Profile configuration file permissions: -rw-
INFO 21:33:53.166 [main] Profile name: MacBook-Pro-zdaecqze.local
INFO 21:33:53.167 [main] Web configuration file: /Users/zdaecqzezdaecq/Library/Application Support/UMS/WEB.conf
WARN 21:33:53.167 [main] Web configuration file not found: File "/Users/zdaecqzezdaecq/Library/Application Support/UMS/WEB.conf" not found
INFO 21:33:53.186 [main] Using database located at: /Users/zdaecqzezdaecq/Library/Application Support/UMS/database
andrewbarton
Post by andrewbarton »
I am having the same "no mountable file system" problem and I believe it is because the latest dmg files are saved in the newer APFS file format
Would it be possible to post HFS file system version of the UMS dmg files ?
The latest version of UMS dmg file that I could attached to my file system was UMS-7.0.1.dmg.
I have also tried to download, "attach" and install version UMS-7.3.1.dmg without success.
After the download I get:
Universal Media Server macOS - 89.10 MB | version: 7.3.1
MD5: 71690ed46137d0b033fed345bb8ef90e
SHA1: 01021469b1ec36f4ddb6b8b3ce1e61fe02d4409a
SHA256: b342daeca6fc688d340ba07d5c41ffda6068e21507b47bf9bff8bddb296df4b6
and if i tried to mount the file from the command line I get:
UNKNOWN:~ bartonandrew$ hdiutil attach /Users/bartonandrew/Downloads/UMS-7.3.1.dmg
expected CRC32 $45605010
The operating system on my iMac is below:
System Software Overview:
System Version: OS X 10.11.6 (15G22010)
Kernel Version: Darwin 15.6.0
Boot Volume: New Main Disc
Boot Mode: Normal
Secure Virtual Memory: Enabled
System Integrity Protection: Enabled
Time since boot: 19 days 21:39
andrewbarton
Following on from my earlier message, I followed the instructions in this link
( https://github.com/universalmediaserver ... structions )
I managed to use git to clone a copy of the latest UMS repository (currently UMS-7.4) and (after editing the pom.xml file used by Maven to "activate" the osx-java8 profile), I was able to build a version of UMS that will run in apple's older HFS+ file format.
Would it be possible in future to create two dmg files: one for HFS+ and one for the newer APFS ?
Hi andrewbarton, I think I will just build them all in HFS+ now, because I don't see any warnings about it when I use HFS+ files on APFS
