[Solved] 64 bit Standalone install DIR
OzBrickie
Post by OzBrickie »
Why does the 64 bit standalone install to c:\Program Files(x86) by default?
Cheers and Beers
Oz
valib
Re: 64 bit Standalone install DIR
Post by valib »
Because the 64-bit standalone version is primarily about the 64-bit Java wich is included in it. The UMS itself is compiled always as 32-bit.
@valib That's incorrect. Java code is bitness agnostic. This is just because of a lazy installer implementation.
OzBrickie
Post by OzBrickie »
Well there ya go.
I won't be lazy then and I will install to /Program Files then
Cheers
Our 64-bit build is a hybrid of 64 and 32 so it is put in the (x86) for now. When we remove our 32-bit dependencies eventually that can change. It doesn't actually make a difference though - the 64-bit parts of the app will run in 64-bit mode no matter where they are
OzBrickie
Post by OzBrickie »
Thanks for clarifying that man!
Cheers and Beers
Oz
