[Solved] New Windows 10 Installation - Can't See PS3
Hello! I know a billion of these threads exist, but I've gone through a ton of them and still can't solve the issue. I have a brand new computer with a brand new copy of Windows 10 Home. I was previously running UMS on Windows 7 over the same ethernet network, but now for some reason, UMS can't see the PS3 at all. I've added an exclusion in the firewall for the EXE, and still nothing. I'd appreciate any help you can offer. Thank you.
- brian_rubin_ums_dbg.zip
- (39.76 KiB) Downloaded 493 times
Re: New Windows 10 Installation - Can't See PS3
For troubleshooting, try to disable firewall entirely and see if it works.
Looks like you might be right, I set the firewall on this thing to ask me about EVERY connection, and it was still blocking Java, so allowing that did the trick. Thank you!
You're very welcome. Happy streaming
