FFMpeg error return code on PS4 UMS 7.7.0
Re: FFMpeg error return code on PS4 UMS 7.7.0
i suggest you to disable AviSynth engine for FFmpeg and MEncoder to avoid that bug.
Hoping that it helped.
Edit:
Your settings should have been as following:
Subtitle priority : fr,off;*,eng;*,und
Edit:
