Will it Transcode or stream tester
Would it be possible to add an option to test if a file will be streamed or transcoded to a renderer according by its config, maybe just by dragging and dropping the file onto the renderer icon in UMS and have it show if it is streamed, and if not why it will be transcoded.
I guess this should be fairly simple to implement as all the logic is already there but you have to dig though long log files and decipher them a bit to see the result, and this way you don't actually need to have that player if you have test with renderer option too.
