Greetings! Successful Deployment To Odroid-H2 / Debian Stretch / Denon X4200W
Hi Everybody,
I'm not sure if this would be the discussion to post this normally, but since it involves success rather than an immediate troubleshooting request, I thought I'd say hello.
I've successfully deployed UMS as a service to an Odroid-H2 running Debian Stretch / OpenMediaVault 4.1 (Arrakis). It's always nice to get an existence proof of a deployment . I -did- have to perform a modest amount of extra configuration work, but it wasn't too time consuming to setup satisfactorily. I'm not going to publish a comprehensive description of the details in this post. Suffice it to say that in /etc/systemd/service/ums.service, I pointed to an environment file, /etc/default/ums, and then in the environment file, I employed a seldom mentioned environment variable, XDG_CONFIG_HOME. I would caution any linux novice to avoid following this path, and rely upon standard instructions.
I ran into problems with my Denon AVR-4311CI. I am encountering the often mentioned, Not Authorized problem. I tried the DHCP trick. It didn't solve the problem. I have some promising leads regarding DLNA certificates and/or a failed subscription to X_HtmlPage. I haven't sorted it out yet, and I intend to post more detailed research in the proper venue, Media Renderers.
The good news, however, is that with a very similar configuration file, UMS recognizes my Denon AVR-X4200W. Shout out to fuggi for blazing the trail, so to speak:
I test-drove a number of UPNP/DLNA server implementations for linux/debian. I was not happy with Plex. It appears that it has chosen to transcode by default on my rootfs (i.e. not tmpfs in /tmp ... in ram). I found UMS to have the best device-specific rendering control of any available implementation.
Access to the source code has helped with a number of initial problems. It was how I was able to discover XDG_CONFIG_HOME, above. Of course, TRACE-level, logging is very useful as well .
Great work, UMS team (and users)!
With a few more modifications to the renderer config file, the X4200W now plays DSD 2.8M and FLAC 192K natively: no transcoding!.fuggi wrote: ↑Sun Feb 17, 2019 8:23 am All,
it took me a day to set up UMS with my LG SJ800V (webOS v5.8) and Denon AVR-X2500H. You will find the configuration files attached which work very well for me, though they might not be final. I hope they will serve you well, too.
This configuration is set up in such a way to work around the "audio codec undefined" issue reported earlier.
Best regards
fuggi
- Denon-X4200W.conf
- (3.92 KiB) Downloaded 454 times
Re: Greetings! Successful Deployment To Odroid-H2 / Debian Stretch / Denon X4200W
It would have been more precise to say: that UMS allows the X4200W to play DSD 2.8M and FLAC 192K natively. The Denon always has done that, but it can't if the file sent by UMS has already been transcoded.holografik wrote: ↑Tue Feb 11, 2020 10:10 am With a few more modifications to the renderer config file, the X4200W now plays DSD 2.8M and FLAC 192K natively: no transcoding!.
I found out that a late modification which removed UserAgentSearch was a mistake. I discovered the next day that this entry was still used. Going forward, I would normally post a correction in, yes, the Media Renderers discussion. However, since I already attached a config file in the first post, I feel obligated to correct my mistake in the context of the original attachment. No more detailed updates in this thread. If I have any, I'll post to Media Renderers and perhaps include a reference in this thread.
I also made more readable the section, Supported Audio Formats.
- Denon-X4200W.conf
- (6.53 KiB) Downloaded 461 times
-sigh- Turns out I was correct the first time. IOW, I didn't understand what I didn't understand
My entry for UpnpDetailsSearch was wrong, and it led me to the wrong conclusion.
I've found that use of UserAgentSearch doesn't work out too well when two different units with matching User-Agent headers reside on the network. In my case, it is a Denon X4200W and a Denon 4311CI. Removal of UserAgentSearch fixes the problem.
Now that recognition relies upon the very specific - and correct - UpnpDetailsSearch, all is good.
Another complication, is that the renderer config for Panasonic - Streamium matches on a very short UserAgentSearch of KnOs/3.2. This is a substring of both Denon units. IMHO, the official Panasonic-Streamium.conf should be modified to rely solely upon UpnpDetailsSearch.
Attaching what should now, finally!, be a robust config file in a multi-renderer environment.
- Denon-X4200W.conf
- (6.38 KiB) Downloaded 440 times
