Scan The Folders Now
AnnieBody
Post by AnnieBody »
When I change my shared folder settings I find the only way to get the folders to update on my TV is to reboot my PC.
Can we have an additional option of 'Scan The Folders Now' in the 'Shared Content' tab.
This would scan the folders, update and send the revised listing to connected devices.
This would prevent having to reboot every time I make a change.
valib
Re: Scan The Folders Now
Post by valib »
The button is there for the long time to rescan folders when they are changed.
AnnieBody
Post by AnnieBody »
So the search button does the rescan!
Now I know.
AnnieBody
Re: [Solved] Scan The Folders Now
Post by AnnieBody »
...If only something happened when you click the button!
Another bug to report?
It works for me when I click it, we will need logs to see why it doesn't work for you
