9.5.0 Not Installing
AnnieBody
Post by AnnieBody »
As I have had a lot of problems with UMS, being told not to do this, do that etc. I decided to completely uninstall (yet again) and reinstall using the latest version.
While doing so, I intend creating a file so that others new to UMS may be steered away from making the same rookie mistakes I have.
Following this procedure 2.5.0 is not working.
The only UMS reference I can find is at C:\ProgramData\UMS but this is incomplete.
When trying to get a previous version that installs correctly I find that links to 9.4.3 and 9.4.2 default to 9.5.0.
When attempting to do the same install using all the defaults in 9.4.2 I get the same problem.
Despite being berated for doing so, when I choose my own installation folder everything is ok.
