PUS7304 stops movie after a few seconds
petete
Post by petete »
Can't play movies because for a reason I don't know the TV stops playing the files after 3 seconds or less, I'm on Windows 10 2004 and UMS 9.8.0
ums_dbg_2020-08-29-11-16.zip
(56.9 KiB) Downloaded 358 times
mgnthe54
Re: PUS7304 stops movie after a few seconds
Post by mgnthe54 »
Hello, do you have the modified UMS conf file to be able to modify the following parameter:
You must change in the UMS configuration file the line "CreateDLNATreeFaster = true" to "" CreateDLNATreeFaster = false ", to restart the program, and it will then have all the shared folders available indicating the source> UMS.
Information provided by Philips TV ...
Thank you
Bonjour, possédez vous le fichier conf modifié de l'UMS pour pouvoir modifier le paramètre suivant :
Vous devez changer dans le fichier de configuration de l'UMS la ligne "CreateDLNATreeFaster = true" en ""CreateDLNATreeFaster = false", de redémarrer le programme, et il aura alors tous les dossiers partagés disponibles en indiquant la source > UMS.
Information fournie par Philips TV...
Merci
