Marantz AV7703.conf
MadHaTr
Marantz AV7703.conf
Post by MadHaTr »
I am making a config for the Marantz AV7703 pre amp. Looking for input. What I have so far seems to work, i've based it off the info from this marantz online manual. I'm looking for things I may have missed or better formatting. I'll include the conf, PNG and my log files in case I have some info wrong. Also how do I get the PNG file working, i used winrar to input the PNG into the resources/images/clients folder but it does't show up.
The included log file is with an empty renderers folder so I could capture the info. The help guide seems out of date.
I plan to make up a bunch of test files to see if there is support beyond what the website claims, if someone has a link to pre made ones that would be appreciated.
Thanks in advance.
Here is the config I am using.
# Profile for Marantz
# DEBUG 2020-09-24 15:32:59.427 [cling-10] New renderer found: "Marantz AV7703" with dlna details: {friendlyName=Marantz AV7703, address=192.168.0.17, udn=uuid:c632158c-b7ce-1a06-0080-0005cde154a6, manufacturer=Marantz, modelName=Marantz AV7703, modelNumber=Aios 4.025, manufacturerURL=http://www.marantz.com}
# This renderer has sent the following strings:
# USER-AGENT: LINUX UPnP/1.0 Denon-Heos/161056
# friendlyName=Marantz AV7703
# udn=uuid:c632158c-b7ce-1a06-0080-0005cde154a6
# manufacturer=Marantz
# modelName=Marantz AV7703
# ModelNumber=Aios 4.025
# manufacturerURL=http://www.marantz.com
# ModelURL=http://www.marantz.com/
RendererName = Marantz AV7703
UserAgentSearch = Denon-Heos/161056
UpnpDetailsSearch = Marantz, Marantz AV7703
#UserAgentAdditionalHeader =
#UserAgentAdditionalHeaderSearch =
LoadingPriority = 2
Video = false
Image = false
#TranscodeAudio = WAV
MediaInfo = true
# Supported audio formats:
# file format mime-type channels sample freq max bit rate
Supported = f:wma m:audio/x-wma n:2 s:48000 b:192000
Supported = f:mp3 m:audio/mpeg n:2 s:48000 b:320000
Supported = f:wav m:audio/x-wav n:2
Supported = f:aac/m4a/mp4 m:audio/x-m4a n:2 s:48000 b:320000
Supported = f:flac m:audio/flac n:2
Supported = f:alac m:audio/x-m4a n:2 s:96000
Supported = f:dsf m:audio/x-dsf n:2
Supported = f:dff m:audio/x-dff n:2
MarantzAV7703.conf
config file
(1.78 KiB) Downloaded 746 times
Marantz-AV7703.zip
PNG
(34.31 KiB) Downloaded 807 times
ums_dbg_2020-09-24-16-35.zip
packed debug files
(990.42 KiB) Downloaded 735 times
Re: Marantz AV7703.conf
Hi, this looks good. In case it is useful, here is the list of media files we use for our regression tests https://github.com/UniversalMediaServer ... t/pms/dlna
If you are happy with the config we will add it to UMS for the next release, do you think it is ready for that?
