[FIXED] 3.3.0 static for audio on some movie files
hi,
i am having some issues playing certain, but not all, movie files with UMS 3.3. i didn't have these issues with UMS 3.1 (not sure about 3.2 as i didn't watch any movies with that version). i did a 'clean install' when upgrading from 3.2 to 3.3.
my issue is that when playing certain movies from UMS to my PS3 i get complete static for audio but the video will play perfectly. a couple examples of the audio info for the movies that create the static are as follows:
DTS 1509Kbps 6ch (packed in an mkv file)
or
AudioCodec : AC3
AudioBitRate : 640000
AudioChannels : 6
AudioSampleRate : 48000 (packed in an avi)
however, other movies with audio info very similar play just fine. i have had no issues with any other video files but >4GB movie files (although i imagine that info is irrelevant).
all the movies which have static for audio play just fine on my computer in both WMP and vlc. i have also tried transcoding the movies with static as audio via UMS on the PS3, but that doesn't help at all.
any thoughts? debug info is attached. thanks for any help.
EDIT: my issues were resolved in v3.4.0. THANKS!
or
AudioCodec : AC3
AudioChannels : 6
- (55.4 KiB) Downloaded 497 times
Last edited by scubastevesama on Tue Feb 25, 2014 6:32 am, edited 1 time in total.
Re: 3.3.0 static for audio on some movie files
any ideas?
my debug log says:
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Parsing results for file "Random.Movie.2013.720p.BluRay.x264.mkv": container: mkv, bitrate: 6192652, size: 4689431439, video codec: h264, duration: 01:40:58.00, width: 1280, height: 688, frame rate: 23.976, muxing mode: null, mime type: video/x-matroska
Audio track id: 0, lang: en, flavor: dts, audio codec: DTS, sample frequency:48000, number of channels: 6, bits per sample: 24
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Adding new child "Random.Movie.2013.720p.BluRay.x264.mkv" with class "net.pms.dlna.RealFile"
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:mpegps v:mpeg1|mpeg2|mp4|h264 a:ac3|lpcm m:video/mpeg
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:mpegts v:mpeg1|mpeg2|mp4|h264 a:ac3|lpcm|mpa m:video/mpeg
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:avi|divx v:mp4|divx|mjpeg a:mp3|lpcm|mpa|ac3 m:video/x-divx gmc:0
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:mp4 v:mp4|h264 a:ac3 m:video/mp4
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:mp4 v:mp4|h264 a:aac m:video/mp4 n:2
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:wmv v:wmv|vc1 a:wma m:video/x-ms-wmv n:2
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:wav a:dts n:6 s:48000 m:audio/wav
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:wav a:lpcm n:6 s:48000 m:audio/l16
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:wav n:2 s:48000 m:audio/wav
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:mp3 n:2 m:audio/mpeg
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:aac a:(?!alac).+ n:2 m:audio/x-m4a
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:wma n:2 m:audio/x-ms-wma
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:atrac n:2 m:audio/x-oma
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:lpcm a:lpcm n:6 s:48000 m:audio/l16
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:jpg m:image/jpeg
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:png m:image/png
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:gif m:image/gif
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Format "mkv" failed to match supported line f:tiff m:image/tiff
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] File "Random.Movie.2013.720p.BluRay.x264.mkv" can be transcoded
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Getting player for resource "Random.Movie.2013.720p.BluRay.x264.mkv"
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Returning compatible player "MEncoder"
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] File "Random.Movie.2013.720p.BluRay.x264.mkv" is not supported by the renderer
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Final verdict: "Random.Movie.2013.720p.BluRay.x264.mkv" will be transcoded with player "MEncoder" with mime type "video/x-matroska"
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Adding "Random.Movie.2013.720p.BluRay.x264.mkv" to transcode folder for player: "MEncoder"
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Adding new child "Random.Movie.2013.720p.BluRay.x264.mkv" with class "net.pms.dlna.FileTranscodeVirtualFolder"
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] End of analysis for D:\--== Video ==--\Movies DVDR\Random.Movie.720p.BluRay.x264
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Matched support line f:mpegps v:mpeg1|mpeg2|mp4|h264 a:ac3|lpcm m:video/mpeg
TRACE 2013-12-16 17:17:59.121 [New I/O worker #1] Network debugger: Random.Movie.2013.720p.BluRay.x264.mkv http-get:*:video/mpeg:DLNA.ORG_OP=10 size=-1 duration=01:40:58.00http://192.168.1.123:5001/get/0$1$16$2/Random.Movie.2013.720p.BluRay.x264.mkv
my debug log says:
UPDATE (temporary fix):
i reverted back to UMS v3.1.0 and all the movies which were only giving static for audio are working just fine again. it appears that their was some change made between 3.1 and 3.3 that is causing this issue. i am kind of surprised that more people aren't experiencing it.
if you need any additional info to help track this bug down, i'd be happy to help in any way i can.
